12-04-2010, 09:40 AM
Head gasket and bearings for 2600
Hi,
I am rebuilding my 2600 motor (rings broken on several pistons).
I believe Fiat 1500 bearings can be used for the main bearings and that Jaguar bearings can be used for the con rods.
Does anyone have any more info on this (or other equivalent bearings).
The head gasket was two-piece with small o rings around the oil feeds to the head. I understand that the later style gasket is one piece. I have read on this forum that some owners have had problems with the new one piece gasket, but that the two piece gasket was prone to problems.
Any opinions on this?
Also is this gasket available in the US, or do I have to get it from OKP or Heinbrand?
FYI: Vintage Imports (Ohio) is currently advertising timing chains on Ebay (12/4/10)
Best,
John
12-04-2010, 11:51 AM
John,
Somewhere amongst my boxes I have a set of (what I believe are) 2600 big end bearings, all new, but there did seem to be too many in the packet for one engine  . Can you dig out a part number for me? Any idea how thick these bearings should be for standard and oversize?
LINK to all parts I have advertised on the BB so far. Plenty more! Just ask.
12-04-2010, 12:45 PM
Push hard and live
The correct bearings are available from a variety of sources for $350 - $600. While this may seem high compared to more mundane cars, it is a pittance compared to the rest of the costs of a correct overhaul. If there is a proven and direct interchange, then why not, but I would be alert for small differences such as tang size and location, location of oil feed holes, bearing construction (they aren't all the same), edge chamfer and so on. I can imagine a Jag bearing, for instance, stating that the saddle ID was X.XXX inches and originally designed in Imperial units, whereas the Alfa was N.NNN millimeters. A quick conversion reveals they seem to be the same, but when one realizes that the bearing "crush" is measured in ten-thousandths of an inch (X.XXXX"), all those digits to the right of 25.4 start to make some degree of difference.
I would recommend buying from one of the known sources and being reassured that the parts were truly correct.
Don P
Carson City, NV
Past Alfas...
Current Alfas
1971 Alfa Montreal (see above comment regarding rationality)
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
12-04-2010, 01:24 PM
Hi Alex,
Big end (connecting rod) bearing part numbers are:
Std: 1306.16.006
1st Oversize (+10 thou?) 1306.16.006 M1
2nd Oversize (+20 thou?) 1306.16.006 M2
Not sure the thickness of the (I presume standard sized) ones that are in there (which are in good condition) as the motor is at the machine shop, but when I next go there I can measure them.
John
12-04-2010, 02:40 PM
alternative bearings
I have researched bearing alternatives extensively and my findings are on the yahoo 2600 board at http://f1.grp.yahoofs.com/v1/4Ln6TJK...20bearings.xls
I actually agree with Don although the Jaguar and Fiat alternatives may have been used when new bearings were unavailable , the cars now have such value that it is probaly worth paying the high price for the right parts rather than paying a machinist to convert alternatives.
The best lead I did find was King Bearings who list an alternative to the original Vandervell bearings
Vandervell King
Con rod set VP206 CR4362CP 4 cylinder
Mains Vp91024 MB7114CP 6 cylinder
inquiry@kingbearings.com
However their prices were similar to european suppliers ( high!) But they may have a US stockist
Hope this helps
Ian
12-04-2010, 02:44 PM
piston rings
NB Piston rings are std stock at Deves .com
cars parts
12-04-2010, 10:41 PM
Thanks Ian,
I am a member of that user group. I tried your link - it did not work, but I found your file.
If I find any additional info I'll let you know.
What about the O-rings underneath the liners - are these special?
Best,
John
12-05-2010, 02:03 AM
liner O rings
Yes and no
2600 is 83mm bore and later 2000 (105 series) is 84mm - So O rings from the later car should work.
For the 2600 they are available from Heinbrand / OKP etc
Mine are held in with gasket selant - done by a "professional" not me
06-17-2011, 02:56 PM
Anyone got the part number for the later one-piece head gasket? My part manual only shows the two part.
John
Virus Alfa- well and truly infected.
sales at alfaretro dot com
06-17-2011, 03:09 PM
ex-"rogue Super Mod"
From what I understand, the one-piece gasket was never supplied by Alfa Romeo. Rumor has it that a Boeing engineer in the 1970s was fed up by failing head gaskets and designed one based on modern materials. I'm not sure if this story is true.
One way or the other, I heard stories that the holes in some gaskets do not line up with the holes in the head (the water passages may be a different on S1 and S2 heads), so it's important that you check this immediately and hopefully make arrangements with the supplier prior to purchasing that you can return the gasket if the alignment is not satisfactory.
I hope others chime in on this topic also and share their experiences.
Ruedi
'63 2600 Touring Spider (AR 191437, the car that started the 2000/2600 International Register, reassembly in progress)
ex-'65 2600 SZ (AR 856043, resto project)
Maintainer of a 2600 SZ register (not the Dutch one).
06-18-2011, 12:31 AM
I have a New Old Stock one piece gasket that has the Alfa Romeo logo all over it (see pic). However, the water passage comment may be correct- they are much larger and a different shape to the ones created by Elring today.
