Old 11-06-2009, 02:09 PM
History of the 2600 engine?
Can anybody tell me (and others are interested I am sure) what the history of the Alfa 2600 engine is? When was it originally mooted? By whom? When did it first run? Etc? Ruedi?
David B
Old 11-06-2009, 03:19 PM
tubut's Avatar
From post #63 of this thread (which mentions several 2600 protoypes):
Originally Posted by tubut View Post
Reading through Giuseppe Busso's "Nel cuore dell'Alfa" this week, I found some interesting references to 2600 development on p. 87-89. Apparently, talks started in 1955 about developing a 6-cyl engine. The purpose was to refresh the 1900 product line and compete more directly with Lancia. The engine was supposed to share much technology with the Giulietta 4-cyl engine. The development project was assigned to Ciaccia and was well underway but mid-1956, but eventually a 2 liter 4-cyl engine was chosen instead of the 6-cyl engine and the 102 series created. In 1957, the 5-speed gearbox was developed for the 2000 but with the 2600 engine clearly in mind. Busso hints that the weight of the 102 cars was too high for the 2000 engine, which leaves room for speculation if, like the gearbox, the 102 bodies were designed with a larger engine in mind also. Finally, in 1960, when the focus was on relatively small cars, Satta gave the OK to start developing what became the 106 model line.
As mentioned in other discussions concerning the capabilities and power of the 2600 engine, I believe Alfa may have wanted to get the engine to rev to 10,000 RPM but had problems to get the engine to behave the way they wanted (an engineer mentioned in an interview they encountered third-order harmonics on the crankshaft around 7,200 RPM that lead to flywheels breaking off on the engine test stand). Aside from marketing considerations, another possibility for the later introduction of the 6-cyl engine may have been issues with casting of alloy block and header (getting consistent quality and sufficient yield).
Ruedi
'63 2600 Touring Spider (reassembly in progress)
'65 2600 SZ (resto project)
Maintainer of a 2600 SZ register (not the Dutch one).
Old 11-06-2009, 05:53 PM
Oh yeah, 10,000 rpm - rock and roll!
"Flywheels breaking off" not so good...
Old 11-06-2009, 06:11 PM
Many thanks Ruedi. You mentioned a little of the history when we met but I am a history buff and like to know these useless bits of information.
The "problem" with the engine shedding flywheels at 7200rpm intrigues me. It could have been solved with modern harmonic damper technology but does the "problem" really exist? Some of you recall Adrian Ratcliffe racing "Piggy" at untold rpm for many seasons. I can confirm this since I was the only other person to race "Piggy". Ratters instructions were to use 8000rpm and no less-this I did whenever possible and if you think it sounded glorious outside the car you should hear it inside! That is one of the reasons I am now using a 2600 engine in my 1948 sports racer project.
Old 11-06-2009, 11:51 PM
the 2600 is strong, smooth and can take a beating. I feel like it should have a propeler on the grill ready for take off. There is a book on the greatest car engines and the 2600 is featured as one of the best. I do not remember the tiltle so if anyone knows the name of the book please let me know. This one is in LA, any insight on this?URL="http://www.carandclassic.co.uk/car/C111399/#"]
Old 11-07-2009, 12:37 AM
tubut's Avatar
The source talking about the 3rd order harmonic is credible but the problem was only mentioned in passing (I received a partial transcript of the interview or citations with respect to this subject matter a few years ago - but I do not recall the name of the engineer off the top of my head). Because the 2600 engine was not the focus of the taped conversation, there were no details revealed about the design of the engine or the problems encountered during development.
I must admit I'm not sure whether the 7,000 RPM was mentioned in the interview of if Adrian mentioned it as a rough spot that required some guts to get through and keep the hammer down things are smooth again on the other side. I recall Adrian mentioning the possibility of thrust reversal in the intake runners in that RPM range and, when I heard about the harmonic, thought the harmonic may have been what Adrian had encountered (or a combination of thrust reversal and the harmonic). I guess you'll be able to tell us more when you try it on your engine?
Ruedi
Old 11-07-2009, 09:18 AM
I don't think you would have problems with 'thrust reversal' at 7000+rpm. The airflow would be so fast it couldn't occur. The last time I chatted with Ratters about this he mentioned that he used an unmodified Solex manifold with Weber carbs and never felt it was worth going to the trouble of modifying the manifold to de siamese it. It was probably 25 years ago that I raced "Piggy" so my memories are vague - except for the 8000rpm, the sound and the lousy handling!
David B
Old 11-08-2009, 05:05 AM
is anyone in search of the book 62bertoneblue mentions above? It would seem a worthy effort to see what information can resurrected on the history and assessment of this engine to add to our 2600 "lore."
David
74 GTV
64 2600 Spider
Old 11-08-2009, 09:27 AM
I spent quite a bit of time on the net looking for it last night-the only possibility I came up with is "Legendary Car Engines" by John Simister. It mentions Alfa Romeo in the write up-I have a used copy coming.
Does this sound familiar 62bertoneblue?
Old 11-08-2009, 12:44 PM
tubut's Avatar
I can see that the Jano-designed 6C 1500/1750/1900 and 8C 2300/2600 engines that were used in Alfa's race cars in the 1920s and the 8C 2900 engine used in the 1930s may have achieved legendary status but the 106 2600 engine has nothing in common with these engines.
I don't think much exciting development for Alfa 6-cyl engines happened thereafter. The 6C 2500 engine is certainly OK for a pre-war design, but post-WWII the Maserati's A6GCS and Jaguar 3.8 engines outshone anything the 6C 2500 and 106 engines had to offer. Much of this had to do with the success of the 1900 and Giulietta engines and the transition from chassis+body to unibody design and Alfa Romeo's shift to lower-cost and bigger market segments.
A notable exception in 6-cyl design is the 3.5 liter 6C 3000 engine, which according to Fusi's "Tutte le vetture..." produced 275 HP @ 6,500 RPM in the 1953 Mille Miglia version. The power curve Fusi shows on p. 490 (an engineering drawing, not a dyno curve) shows no roll-off at the top end, which gives me the impression Alfa engineers had hopes the 6C 3000 engine would rev higher -- maybe as high as the 1.5 liter 8-cyl Alfa 159 Grand Prix engine of 1951 which produced 425 HP @ 9,300 RPM.
The previously mentioned interview with an Alfa engineer that touches on the issue of 3rd-order harmonics on the crankshaft of the 106 engine clearly indicates that Alfa tried to get the 106 engine to rev much higher and, when they were unable to solve the problem within the budget or time allocated, capped the engine at 6,500 RPM.
Ruedi
Old 11-08-2009, 01:22 PM
Thanks Ruedi, I agree that "legendary" and "106 series" do not go well together!
However, the book was only $5....
I note in Peter Hull's "Alfa Romeo, A History" that the dimensions of the Disco Volante engine as run in the 1953 MM was 88x98 mm which would preclude any very high rpm use from that particular engine.
David B
Old 11-10-2009, 03:02 PM
" Legandary car engines" could be the one. It was at a Borders Books in San Francisco about 3 years ago. It very well could be based on the pre-war Alfa's, I remember a photo of a straight 6 alloy dual overhead beauty. The 2600 engines are quoted as being bullet proof and John Lennon owned one, does that count a little for semi legendary?
Old 11-10-2009, 05:53 PM
tubut's Avatar
"Bulletproof" would be quite a bit of an overstatement for 106 engines -- at least at the time they were introduced: The 2-piece cylinder head gasket was prone to failure, which wasn't cured until new materials and 1-piece gaskets became available in the '70s or '80s. These engines also suffered from burnt valves, most often on cylinders 5 and 6, which many blamed on the Solex vacuum membrane and butterfly valve bearings failing but may actually have been the result of leaks in the vacuum circuit for brake booster which allowed false air entering the circuit and leaning the mixture to the point of valves burning through on some cylinders.
Ruedi
  #14 (permalink)
Old Yesterday, 03:33 PM
OK, "Legendary Car Engines" has arrived and it does not have any info on the 2600 engine. It does however, have a very nice chapter on the four cylinder Alfa and also a Chapter on the 8C 2300. Also featured in the book are Bentley, Bugatti, Bristol/BMW, Jaguar, Aston-Martin, Coventry Climax and Ford, Chevy and Rover V8s, plus Porsche 911 and VW. Very nicely presented, great photos and some of those wonderful Bob Freeman illustrations that we all miss. A good buy at $5!
  #15 (permalink)
Old Yesterday, 03:45 PM
Relating to Ruedi's post regarding burnt valves on cylinders 5 and 6, due to problems with the brake booster, perhaps one should consider taking the vacuum from the intake plenum (via a new fitting tapped into the underside of the plenum).
Would the vacuum in the plenum be sufficient?
J
