I may be a heretic here but electricity is one area where I think originality should be sacrificed for safety. You can keep the orignal fuse block and 8 amp fuses, but convert the hi-amperage circuits to relays with separate supply feed from the battery feed or alternator terminal.
To be safe, the wiring should be re-done from headlight/foglight all the way back to the relays in addition to new feed wires.
One of the best benefits from new circuits is that they will take a load off the column and dash switches, thus preserving their life. They also will allow you to match wire size to loads and fuses. Use a heavy gauge (14) for the supply feed; 16 should be fine for the leads from relays to lights. Relays and in-line fuse components are available at most auto stores.
Here's a pic of a little relay panel with circuits for high & low beam and fog light...it's mounted on the existing panel where the horn relay is. To keep things looking more "original" you could of course use just black wire, but then it might be a good idea to use labels on the wires to identify them in case you ever needed to go back and trouble shoot.
Note also the shrink tubing to insulate each wire spade just in case anything vibrates loose. The fuses are not shown- they're "in-line"- spliced with quick connectors.
David
74 GTV
64 2600 Spider
