Old 07-02-2009, 09:01 AM
Roger C Roger C is offline
Member
'59 2000 Red Roadster
Help needed to repair window washer. Everything works except the bulb is cracked. Are bulbs available?
Thanks, Roger.
Old 07-02-2009, 10:29 AM
Member
Also, how does one separate (non-destructively) the rubber? mounting ring from the motor for the heater fan? I have it partially disassembled now and realize that I can't get the brushes back in correct position unless I get it apart even further.
Thanks, Roger.
Old 07-02-2009, 11:54 AM
tubut's Avatar
tubut tubut is offline
Thanks, Roger.
There were so-so reproductions available in Germany a few years ago. I don't remember exactly where I got mine from (some semi-professional eBay seller, I believe). I suggest you check with OK Parts in Germany via e-mail if they have them.
Ruedi
'63 2600 Touring Spider (reassembly in progress)
'65 2600 SZ (resto project)
Maintainer of a 2600 SZ register (not the Dutch one).
Old 07-02-2009, 05:25 PM
Member
"Also, how does one separate (non-destructively) the rubber? mounting ring from the motor for the heater fan? I have it partially disassembled now and realize that I can't get the brushes back in correct position unless I get it apart even further."
Cancel this request....Motor has been repaired!
New Request: It looks like I do not have a "tap" for controlling water flow to the heater coil. Can anyone help me with finding one"
Thanks, Roger.
Old 07-03-2009, 07:16 PM
AR2000-102MX's Avatar
AR2000-102MX AR2000-102MX is offline
Member
Thanks, Roger.
You may try 190SL Parts Catalog - SL Autohaus item 184a.
Ricardo
1960 2000 Touring Spider
Old 07-04-2009, 05:54 AM
Member
Thanks Ricardo,
I also need the duct (~4.5" dia x 23" long) that connects with the heater coil box.
Great job on your car Finally my 2000 Touring Spider left the shop today...
Roger.
Old 07-06-2009, 06:01 PM
Touringspider Touringspider is offline
OKP in Munich had the correct ducting at one point a few years ago. E-mail Christian and see if they still have some.
Arno Leskinen
AROC-USA National Concours Chair
102
115
116
164LS
1972 Lancia Fulvia 1.3S
Old 09-17-2009, 10:42 PM
benicia 2600 benicia 2600 is offline
Hi
Use mga ducting same as paper type for alfa except it is black instead of cream..
regards
herve
Old 09-18-2009, 04:29 AM
Member
I do not know what 'mga' is. Please explain.
Thanks, Roger.
Old 09-18-2009, 09:07 AM
Hi
I meant use the ducting material sold for the MGA(the car) sold by Moss.
Regards
Herve
Old 09-18-2009, 06:29 PM
Ken Ross Ken Ross is offline
Moss shows the hose is 4", not 4.5". Do you have an item number.... I may be missing something...
Ken
Old 09-18-2009, 07:18 PM
Hi
You are right the mga hose is only 4 inches. It must be different than on the 2600 which uses mga material. sorry I could not be of any more hepl.
regards
Herve
