Old 03-12-2009, 11:57 PM
san francisco/bay area
alfa 2600 gas gage sending unit
Hi
does anyone have a source for new gas gage sending units for the 2600, or does anyone has a source to restore the units to new condition?
Regards
herce
PS: Afra and OKP do not supply this item
Old 03-13-2009, 03:08 AM
Redmerlin's Avatar
fuel sender
Herve
I am sure alfaholics or classic alfa in the UK will have something. They always say they only do 105 series cars - but the Veglia senders are the same I believe on the 106. Just check the resistance range and you may have to bend the arm. This is my next project
All Veglia gauges on Alfas I believe work 240 ohms empty/min , 100 ohms 1/2 , 30ohms full/max
A full calibration is ( this is from a DeTomaso web site!)
liters R (ohm) gauge
> empty ~2k empty-- lamp on
> 5 321 empty- lamp on
> 10 272 empty+ lamp goes out
> 15 234 1/16
> 20 208 1/8+
> 25 180 1/4-
> 30 160 1/4+
> 35 135 3/8
> 40 115 1/2-
> 45 100 1/2+
> 50 88 9/16-
> 55 75 3/4-
> 60 60 3/4
> 65 48 3/4+
> 70 27 4/4-
> 75 3 4/4+
> 80 2.5 4/4+
Alfaholics sell an electronic sender
Quote from their web site - "If you have early Veglia gauges, we can supply a special electronic sender that is compatible with them as original, as fitted to Max's GTA Replica" listed at the end of the new products section.
Also search posts for fuel sender and fuel sender issues, you may be able to repair your old one
Cheers
Ian
Old 03-13-2009, 03:59 AM
Redmerlin's Avatar
fuel sender
Herve
I have just checked the parts manual - the sender is listed as
102.00.32.050.00 which means it is common to the early 2 litre but not the 105.
1st option
Heinbrand do list the sender - HEINBRAND AUTOMOTIVE . If you can make your way through the German
Look under "Benzinversorgong" fuel system?- item 1 - price "auf Anfrage" - on enquiry? they do speak English if you call .
This is also a great web site for 2600 parts - if you can stand the prices!
If you look under 105 section you will see the senders are different mechnically - but porobably could be modified
2nd option
G. Häckner GmbH - Ersatzteile für Alfa Romeo
German website - difficult to navigate
Look under
On-line shop
Classic technik
Filter
Kraftstoffsystem
Tankgeber
Or type "106 tankgeber" in search panel and press "los" search?
You will also then get call for a price
Call Ludwig Mai - he speaks good english
info@haeckner.com
Tel. + 49 - (0) 9721 38802-15
Fax + 49 - (0) 9721 38802-22
Ian
Old 03-13-2009, 09:48 AM
Thank you Ian for all your valuable infos. I e mailed Haeckner asking them for price and availability.
Regards
herve
Old 03-13-2009, 11:43 AM
tubut's Avatar
The fuel sending unit has been NLA for quite some time (but it's still worth checking if Reoriginals has any left). OKP used to have an exchange program for refurbished fuel senders (no longer listed on their web site but worth sending an e-mail inquiry).
A while ago, I posted in the Yahoo newsgroup a description of the fuel sending unit with suggestions for repair (carefully bead blasting the corroded mechanism goes a long way).
The 106 fuel sender is 90 Ohms. I haven't played with 105 senders yet but thought using a simple low-power op amp as voltage follower and impedance converter may do the trick to use the 105 sender with the 106 gauge.
Either way, please let us know what you find out!
Ruedi
'63 2600 Touring Spider (reassembly in progress)
'65 2600 SZ (resto project)
Maintainer of a 2600 SZ register (not the Dutch one).
Old 03-13-2009, 01:00 PM
Redmerlin's Avatar
fuel sender
Ruedi
Thanks for your notes
Sorry then the calibration I showed is wrong. inverted for a Jaeger or VDO gauge . Also not 240 ohm range - 0 out of 2 - I'll do more research before I post next time.
From your note -empty I assume is full resistance 90 Ohms - Full is zero
I intend to go the clean up route on my sender as your notes. The only small problem I have is the sender unit on my tank does not align with the hole in the floor - so I may have to take the tank off!
Ian
Old 05-22-2009, 04:01 PM
Photo of fuel sender 2600 spider?
Hi,
My fuel sender is missing the arm and float!
Does anyone have a photo of the complete fuel sender?
Or an old one I can buy?
John
Old 05-22-2009, 04:21 PM
tubut's Avatar
Here are some pictures of my fuel sender (not for sale) when I removed it from the tank. There are also senders with plastic floats. So far, I haven't measured the length of both arms yet (to determine the mechanical parameters for empty and full) or compared it to Giulietta, 105 or 116 fuel senders yet (which may require some simple electronics to emulate the 90 Ohm variable resistor).
Ruedi
Old 05-22-2009, 07:06 PM
Thanks so much.
Very kind of you.
J
Old 07-03-2009, 07:27 AM
Member
Picture of my '59 2000 Fuel sending unit for johnrdm and tubut
Am I right in thinking that the arms should slide in response to the float?
If so, how do I free up the action? A solid connection needs to be reestablished at the lever pivot once the slide is freed up.
I suppose any reasonable kind of float could be used to make it work.
Thanks in advance for any comments.
Roger.
Old 07-03-2009, 08:57 AM
Yes the arms should move.
It appears that the brass spindle has frozen in the aluminum housing - this seems a common problem.
I used a map torch (carefully) plus penetrating oil inside and out (be careful as the oil will tend to catch fire - not good) to free up my spindle, but in my case the steel lever was still attached to the spindle.
In your case it sounds like the steel lever is moving on the brass spindle, and that is a problem, as you have no leverage to unstick the spindle (you can't use the little arms inside as they are too weak).
Perhaps you could carefully solder a piece of steel over the lever and spindle end, to allow you to slowly and carefully wiggle the spindle free?
I found a float in a junkyard - modern closed cell foam - fitted with only minor tweaking.
Don't you just love old cars?
John
Old 07-03-2009, 10:09 AM
tubut's Avatar
John's approach seems to be sensible. You may also want to consider repeated hot/cold treatment (heating up the spindle area and then shock it with freezing spray) to see if it comes lose with little force.
Ruedi
Old 07-03-2009, 11:12 AM
Redmerlin's Avatar
What is a map torch?
  #14 (permalink)
Old 07-03-2009, 11:19 AM
Actually it's MAPP - its similar to a propane torch but a fair bit hotter.
John
  #15 (permalink)
Old 07-03-2009, 01:40 PM
Member
Thanks everyone, have not got it loose yet....taking my time about it.
Sent an email to Rebuilt Fuel Sending Unit Specialist after seeing an ad at the top of this page with inquiry as to what it would take for them to deal with it. Got this response:
Hello Roger, Yes the arms should be moving with the float. Cost of repair is hard to say but expect it to be in the 95.00 to $125.00 range plus any parts if needed. I hope this helps and have a great holiday.
Thank You,
That Sending Unit Guy!
Dan O'Hora
A Division of Tri-Starr
1-800-216-4940 8:30-5:00 PM EST. M-F
Has anyone dealt with them?
Happy 4th, Roger.
