Old 03-09-2009, 02:02 PM
jaro61's Avatar
water pump AR 1900 1306 engine URGENCY
Dear members,
I`ve got an urgent problem: For our 1900 TI Super we had a new motor made this winter. It is meant for racing a german long-distance cup that is starting end of march. The original 1308 engine should be preserved, the current engine is a 1306, number 10003. Today we discovered that our water pump and generator are not fitting to the new 1306 engine. Our dynamo type is Marelli with a wheel (disc) for two parallel belts. It is fitted with a double tin strap only, wheras the 1306 motor has a special fixing base eye. What we need is a second waterpump or, at least, the driving wheel for single belt plus the generator with single belt driving wheel (scintilla?). Can anybody help at once? I found a water pump on ebay Italy but it comes without the wheel.
Thank you for any reply
`55 1900 TI Super
Old 03-09-2009, 03:10 PM
Hi ,
I think I have a used RIO 2300 waterpump with single belt driving wheel and also some marelli dynamo's with / without single belt driving wheel from 102 spider.
both fit 56-58 1900 engines
rgds Franco
Old 03-10-2009, 09:47 AM
jaro61's Avatar
Hello Franco,
thanks for your quick reply. I´m not quite sure what the difference is between the 1306 and 1308 engines concerning water pump and dynamo. The 1306 dynamo we need has no special fixing post, has it? Just some minutes ago I bought a brand new pump from ebay italia and hope this will do. Sadly it has no driving wheel. If you don`t like to tear your pump and wheel off, let`s talk about an arrangement. If I may ask, it would be great to get a picture of the pump/wheel and the dynamo.
Can you post it here? My home email adress is rotenberger@t-online.de.
Thank you for your help
Jan Rotenberger
`55 1900 TI Super
