Yep. If you want a new one, you've got to have them fully custom made now, no one in Australia sells them. Used is a case of following ebay or similar like a hawk & buying a car with one fitted... then remove & onsell car.
Custom made should set you back in the vicinity of $6-800 plus engineering certificate if required from what i've found through my investigations.
I have a picture of one made by Witter in the UK, but their bolt-on flange isn't legal here, so will need modifying to suit our market. No dimensions, but bolt hole locations are listed in the owner's handbook.
The bar's specified maximum towing capacity is listed at 1250kgs, with a 50kg nose weight. At that weight, you'll more than likely pull the bolts through the boot floor (so it obviously isn't recommended).
