Old 06-08-2008, 01:59 AM
treborblack's Avatar
treborblack treborblack is offline
pipe under car
Looking under the car to ascertain where the exhaust is blowing, i noticed a pipe about 10mm thick that comes from the front of the car to under the passenger seat that then doubles back on it's self. What's it's purpose?
Remembering my car is rhd, it could and probably is on your drivers side
Driving a September 1996 super like i stole it
Old 06-08-2008, 02:13 AM
damonb damonb is offline
I'm pretty sure you're looking at the cooling circuit for the power steering fluid.
Old 06-08-2008, 03:37 AM
Yep, that is what it is cooling line for power steering fluid.
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 06-08-2008, 05:02 AM
multicam's Avatar
multicam multicam is offline
Multicam
While we are on the subject, and since I am replacing all the P/S hoses on my 94 LS, I'd like to ask a ? and make a recommendation.
I found that the best way to get a good tight fit is to remove the cooling tube and secure the new hoses and clamps to it, OFF THE CAR, and then feed the hose line up into their corresponding areas , reattach the cooling coil and then cut the hoses, [ to the P/S reservoir and the return feed from the rack], to length.
I have read the recommendations for hose sizes [THanks to ALL], and would propose using , 7/16 INCH 50 PSI size hose, since it is very snug over both ends [reservoir and coil] and fits better than the 1/2 INCH hose, through the rubber grommet just below the reservoir. Is this OK?
I also would recommend using, Goodyear E-Z coil 1/2 INCH Molded Hose Solution, to take the kink out of the tight loop where the 1/2 INCH hose comes up from the cooling coil and on to the rack.
The coil is attached to the under body at 4 points, two are press on, plastic channels , one is a rubber grommet with metal cover which uses a 6mm bolt, and the read one is a channel guide clip. Make sure that there are no cracks in the tube by inspecting the rubber cover to the brass tube.
Frank
Frank
Frank La Sala
1994 164 LS 5speed
1960 Giulietta Spider
1959 Giulietta Sprint
1965 Giulia Spider [parts car now]
Old 06-08-2008, 05:21 AM
multicam's Avatar
Multicam
I look up the specs. for Weatherhead Weatherhead 7/16 INCH HO57 hose .
Here is the URL:
Eaton Product Literature Library > Fluid Conveyance > Weatherhead
Frank La Sala
1994 164 LS 5speed
Old 06-09-2008, 01:33 PM
Thank you for the info
Old 06-10-2008, 10:16 AM
good news, the exhaust was only loose at the manifold, yipee as i'm skint till pay day
