Old 12-20-2004, 01:26 PM
medioman medioman is offline
91 164S leaking on cold starts
Thought I'd throw this issue out there (an easy one for most Alfisti I'm sure). Lately, we've had cold weather (for Columbia, SC at least). It's been in the 20's and 30s the last few mornings. I always let the car idle for several minutes to warm up. The last few mornings I've noticed a small amount of oil leaking from (maybe) slightly behind the oil pan. I get a slight burning oil smell. It only happens in the a.m. on a cold start. It won't do it the rest of the day.
I'm thinking it may (or must) be a gasket someplace. Someone said valve cover gasket, but I'd think I'd see more evidence topside.
That's #1; #2 is, is it anyone else's experience that the shifter is very notchy when cold? My 86 spider was too, but not to this degree. On that topic, I cannot find the freaking dipstick for the tranny fluid either.
Any random thoughts or advice are, as always, appreciated. ....
Old 12-21-2004, 06:20 AM
Alfisto Steve's Avatar
Oil leak onto exhaust is probably rear main seal or cigarette seals for rear main cap. Live with it unless it becomes unbearable. Check pan bolts for tightness but don't over torque. Mine does leak on exhaust once in a while but always seems to go away for months at a time.
Dip stick for 5-speed located in top of differential case between where two axles meet case. Look directly back and under air flow meter and below slighly to cars left side of where shifter attaches to gearbox. If you have a long arm with out a Pop Eye forearm you can reach it.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Old 12-21-2004, 07:23 AM
Thanks Steve. Always glad to be advised to live with it, because it does not require me to do anything! I'm thinking maybe this is an oil pan gasket now, and I will check the tightness of the bolts soon. Since the problem seems minor and it's very dependent on cold weather, I'll just watch it for now.
Thanks also for the pic of the transmission fluid dipstick. I'll have another look. BTW, if it is low, where do I add fluid? (Hopefully, Santa will bring me the Cardisk this year). Thanks and Merry Christmas.
Old 12-21-2004, 10:15 AM
papajam's Avatar
papajam papajam is online now
with the Librarian
Add the fluid thru the dipstick hole with a looooong funnel.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 12-21-2004, 11:33 AM
BlackAlfa BlackAlfa is offline
164 tranny and diff. use ATF and not gear oil. If it has gear oil then it probably will be hard to shift in this cold weather.
When I did the oil change, I inserted a long clear plastic tube into the dipstick hole to fill the tranny. Somewhat slow but did the job. Warm up the fluid to get it flow faster!
Some people open up some bolts (or something like removing the back up light sensor) on top of the tranny to fill it.
Bob
Old 12-21-2004, 08:40 PM
There is a "fill plug" in front of bell housing at clutch release arm pivot point. I use it. It is either a hex head plug with gasket or pipe thread plug that takes a allen wrench to remove. I have seen both types. You still need a long A/T tranny type funnel or small tube but easier and faster than using dip stick hole.
Virginia Beach, VA
Old 12-22-2004, 06:56 AM
Steve - what is that large square hole on the topside of the bell-housing for?
Old 12-22-2004, 09:38 AM
alfar0meo's Avatar
alfar0meo alfar0meo is offline
Send a message via AIM to alfar0meo
Had the same problem in the winter until I switched to synthetic in the gearbox. I went with Red line D4 ATF, and the gearbox never feels "slushy" anymore in the cold.
[B][COLOR="Red"]Massimo[/COLOR][/B]
91' 164S/02' Jeep Wrangler SE
Old 12-22-2004, 08:08 PM
Square hole over flywheel is alternate location for engine timing marks but mostly was a Euro Spec thing. I use timing mark/pointer on front pulley/front cover.
Virginia Beach, VA
Old 01-14-2005, 07:58 PM
Finally got into it
Finally was able to get to the tranny dipstick. If my arms were any bigger I would not have been able to get it out (my lack of exercise finally pays off). It does look low to me. I believe the current oil is synthetic but not sure.. is it OK to add a little Dexron III / Mercon if it has been changed to a synthetic previously?
Also, I do see what looks like a fill hole on the front of the bellhousing (front-side of the car). It looks like a screw in plug that you could remove with a decent sized Al. wrench.
PS what is the capacity for tran fluid? Thanks!
Old 01-14-2005, 08:12 PM
Transaxle capacity is about 2 quarts. I am sure you can top off with Dextron but if you get a chance you probably should drain and refill with one type. I just filled mine through hole near clutch arm. I have allen plug and I believe size was 8 or 10 mm.
Virginia Beach, VA
Old 01-14-2005, 08:49 PM
Thanks Steve. The operation shall begin immediately....
Old 01-17-2005, 11:55 AM
Talking Follow Up
As it turned out I did not have the proper allen wrench, so I went through the dipstick hole with a very long funnel. Not easy, but it worked. To anyone looking for the dipstick in the future let me emphasize that it is much farther back toward the firewall then it would seem to be. Go to the firewall at about the middle of the windshield and look straight down. Thank you to Steve & everyone else that weighed in on this!
