Old 05-27-2008, 03:19 PM
ChazzyD's Avatar
ChazzyD ChazzyD is offline
Wipers forgot where to park?
So today I turn my windshield wipers on to wash the windscreen. Went to turn them off and they stopped about 10" too high. Tried turning them on and off several times with the same result. I'm thinking I should just remove the arms and then bolt them back down in the fully parked. Is that going to fix them? We will see. Anybody have that happen before. Has it skipped a stepper tooth and is now stopping on another?
Charles
'91 164L 5 speed 180k and counting
Chattanooga, TN - Home of the new VDUB factory!
Old 05-27-2008, 04:16 PM
Craig's Avatar
Craig Craig is offline
75/Milano manuals for all
No, no , no! If you do that and they then try to stop in the correct position they will try to drive under the hood somewhere.
Take the wiper motor gearbox apart and clean and re-grease the copper tracks.
Craig,
1988 75 TS, 1989 164
Old 05-27-2008, 04:39 PM
Craig's Avatar
Best pic I can find (but it's not an Alfa):
Craig,
Old 05-27-2008, 06:38 PM
ChazzyD's Avatar
Ok, Thanks Craig. I will drive the Volvo tomorrow since I think it's going to rain. I'll take the wiper motor apart and see what is up with it. I have had issues with the wipers before, but not recently. They tend to go past the pillar on the driver's side and still park low, or did until today. Maybe they are now working correctly, now that I adjusted them and they seem to work fine (they don't go too far and they park correctly). But I am afraid that they will do what you are saying they may do and try to dive down too far now that I have taken them off and reset their position? I have no experience taking one of these apart but I'll give it a go.
Charles
Old 05-27-2008, 06:49 PM
Craig's Avatar
The last one I did was over 30 years ago but it should be pretty easy.
Don't put the arms back on afterwards until you're happy that it's working right, you don't want to damage the spline/knurling.
Craig,
Old 05-28-2008, 09:24 AM
AlfaTango1's Avatar
AlfaTango1 AlfaTango1 is offline
but this one goes to 11..
There is a chance that one arm has become loose but I doubt both,there is a nut obviously on both arms. You can adjust but if you do, make it in small increments maybe five inches at a time. I replaced a whole motor assembly about a year ago and it can be a big pain with the blower motor in the way. If the stopper is not lined up correctly it can and will act like yours is so if you pull the unit out make a mental or psychical note of the proper orientation of the stoppers.
currently: 1984 GTV6 (Sabrina) 1992 164L (Jill) 1992 164S (Kelly) 1989 Spider Veloce (Julie)
Old 05-28-2008, 10:12 AM
ChazzyD's Avatar
I'm assuming I have to pull the whole wiper rack out to get the motor out?
Charles
Old 05-28-2008, 10:24 AM
AlfaTango1's Avatar
Yes and it sucks without taking the blower motor out. Well you could disconnect the motor but that would even harder in my opinion.
Old 05-28-2008, 02:05 PM
ChazzyD's Avatar
So it's another job that takes the better part of a day to do.
Charles
Old 05-28-2008, 07:52 PM
Del Del is offline
Had to do this with our Milano. The contacts rubbing on the swash(?) plate inside the gear case, not the motor itself, needed to be reshaped due to wear and regreased. Not easy to get the wiper gear out on that one as well.
Del
Seattle
89 Milano
91 164S
94 164LS (Q)
72 Morgan 27
Old 05-29-2008, 06:19 PM
ChazzyD's Avatar
Thanks all for the advice. I got after it this evening after work as the Volvo ain't real fun to drive. Pulled wiper rack which required some finnigling. Had to remove plastic cover tray, unscrew both large wire harness connections to make room, remove relay cover, remove wiper arms, remove 4 bolt plastic covers, remove plate at middle of car where false firewall brace is, hunt for the one bolt up underneath, behind motor at real firewall. Now wiggle the whole rack out. 20 mins. tops! Opened up vinyl weather shielding and popped open the gearbox case, bent up the three contacts therein which looked good but hoped that they would get a sure contact now. Spread some of the grease around in there onto the worm gear. Installation reverse of removal and all that jazz. THEN discover the smallest arm is half broken in two! This is the one with the slot in it for adjustment of sweep, connected directly to the motor swing arm. Great, pull it all back out, 10 mins. tops this time! Pull out welder and lay a bead or two, put it all back. Turn on and off a few times, and then mounted the wiper arms at park position, works perfect. They set up when on intermit and then park when off and they no longer go too far at the windshield pillar either. Sweet. Took the time to grease the plastic pop on joints too, just pry them off clean, pack with fresh grease and pop back on. Also cleaned out the leaves and such while I had the rack out, there was a lot up under the heater box, like always.
Charles
