06-30-2008, 05:40 AM
Originally Posted by Alfisto Steve
Looks like P11 acturator in door maybe the problem and brown-white or purple-white wires. Do doors lock OK using passenger door lock?
There is another connector inside door, too that actuator wiring hooks to it.
I haven't tried with the passenger lock. only the lock from inside. But if i remember right it doesn't work from the passanger side either.
Is there another connector in the door? Beside the one that you obviously see when you take the trim of?
06-30-2008, 08:27 AM
If passenger side doesn't work either G168 must not be a problem maybe wiring at controller N11 under glove box or lock channel in N11.
Door connectors in back bottom section when lower panel off.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models - 91 164L "Black Beauty" and 91 Argento aka "Quik Silver" (daughter's) 164B w/AT 1QUIK AG
Resting 91 "Bianco" 164B 5-speed
Spring Revivial: 91 "Old Blue" 164L w/AT
Rescue projects: Organ Donor 91 Old Nero 164L
SOLD 91 Argento 164L w/AT aka "Quik Silver 2", 93 Rosso 164L 5-speed
06-30-2008, 10:15 AM
Ok thanks. Then i know where the connector is located in the doors.
And the N11 is located under the glove box then.
06-30-2008, 02:52 PM
N11 is technically in front of the glove box. If you open the glove box door you will see a couple of access panels. Pop those off and you can get to the two screws that hold the aux. relay panel and related stuff. Remove the screws and then reach up under the dash (in front of the glove box) and pull down this mass of electronic stuff. The N11 is one of the plug in modules.
Now, can someone please explain how to get the darn thing back in place! I have been under the dash for an hour to no avail. I think removing the glove box door would do the trick but I haven't yet looked to see how that comes off. It might also be a two man job but whatever, its got me beat right now.
- Rich D.
I like Alfas
09-02-2009, 12:56 AM
Location: Don't see many Alfas in my town :D Especially not 164 QV
question
is the n11 door lock unit a small box with 5 connectors by Jaeger? Or is that thing the unit for the power windows?
Does it actually say N11 on it?
thank you
Alfa Romeo-tutto il resto.... è noia (F. Califano)
09-02-2009, 04:05 AM
never mind, I found the N11
Opened it, cleaned it and FOR NOW it seems to work again
let's hope it stays like this
11-01-2009, 09:49 PM
driver's door won't unlock
Hi folks,
I don't normally post on the 164 forum, as my car is usually reliable.
This time, though ...
My driver's door won't unlock, using any of the mechanisms. Key in the driver's door will activate the central locking and unlock the other three doors. Similarly the other ways of triggering the central locking. The interior 'pin' on this inside of the door moves, but it doesn't look like far enough. Pulling the pin won't unlock the door.
My guess is that there is a gear or a rod that has worn to the point where it can't get traction on the actual lock mechanism.
But the key problem is: if the door won't unlock, I can't open it, and if I can't open it I can't dismantle it to identify and repair the problem.
Any advice on how to get the door open?
regards,
Anthony White
http://fastandpretty.blogspot.com/
11-01-2009, 10:14 PM
Membro Maggiore
Whoa Anthony!
It seems like it would be a simple fix except you can't get to it! You have a thorny one! I hope Steve has a plan as I am lost on this one. Did you try a Slim Jim, as we call it here in the states? Steve may know if that will work or not, and where to place it and pull on it if that will work. It's going to be inconvenient to say the least. Good Luck. Let us know how you fix this one.
Larry
Waco,TX
Hartselle, AL
Director, Alabama Branch, SNO
Help for the Confused and Incorrect since 2009
Legion President of The Confused and Incorrect by order of both the Illinois Alfa Chapter and the Illinois Ferrari Chapter Directors of SNO
"Larry wants to know why everyone is trying to make him feel like he's the one that's confused."
11-02-2009, 12:40 AM
Okay, some luck.
It turns out that you can evetually dimantle the door while it is still closed. A couple of screws under the arm rest, and another behind the door release lever, and you have enough movement to gently start levering things open.
A little more levering, finding a few more screws that could be undone with a bent screwdriver, eventually it came apart enough that I could open it.
Beyond that, it just seemed to be sticking -- I lubricated everything, adjusted some of the nylon bushes, and it's working like new.
regards,
Anthony White
11-02-2009, 06:21 AM
I am glad you got it "fixed" and it wasn't a broken spring inside the mechanism as that is a real problem that Mr. T addressed when it happened to him on a 164.
I practically almost had to use C4 to get door open on a Mi16 Peugeot when a spring broke in latch but haven't had that happen on a 164 yet.
Virginia Beach, VA
12-07-2009, 11:18 AM
Member
ALARM 164L heated seats
I turned the alarm on today and wanted to see if the remotes worked, the remote led lights up but nothing happens when I press it, after a few minutes the siren started going.?? All the fuses are good as far as I can see,pulled and re seated them all.
the led flashes on the side console and the lights all flash with the siren but the remote isnt doing anythg?
Im also trying to get the heated seats going? any threads on that..again all fuses look good.
rs
R Simiriglio Currently,91 164L 91 164b,81 Spider*New Addition Feb 2010, 73 Fiat 850*
Previous,63 BJ8 MK3 Austin Healey*76 Spider,79 Spider, 90 Quadrifoglio.3 vettes and tons of other american and foreign steel.M/C's also
