typical LS stuff not too bad
0. Air bag light can only bereset with Marelli tester. The llght automatically starts flashing around 100K miles as a warning to get your system checked. With the tester, takes 5 minutes to reset the light
1. THe AC is really OK as long as it is well maintained. You will need to find out whats wrong with it -- might just need a flush and recharge!
2. Might be a dirty switch. It usually is. Take it apart and spray elec contact cleaner in there
3,4, 5 -- same. switches get dirty when not used and they need to be cleaned up
Cruise-- sounds like the switch on the brake pedal is bad - new switch is about 30 bucks I think -- might just be out of alignment or unplugged
Sunroof -- clean the switch again
All in all this is an afternoons work to get things to the point where you can elimininate the cheap stuff and move on. Depending on whether you need new switches (doubt it but possible) youre looking at 100 =200 bucks give or take at the mechanic? If you DIY you can do it all except possbily the AC and the air bag. Most folks without access to the tester just live with it
hope this helps!
goats
74 GTV with 10548's and Ingram pump speedo been around at least twice!
1995 LS Q runners squadra chip Auto Green/tan 157K 100% LCD
1995 LS 5 speed Green /tan 34K Q runners 100 % LCD!
Bent up car GONE in dumpster sold for metal scrap!
2004 Tacoma 4 door TRD (wifes car/kid hauler)
Mission Vsi, Mission Mod 2, Mission D2
radio flyer
