Old 05-13-2008, 03:08 PM
ke3ee ke3ee is offline
Map Lights in overhead console dim ?
Both of my map lights are dim. First is that normal ? If not possible wrong bulbs ? or?
Old 05-13-2008, 03:14 PM
Yes normal. If you have sun roof model go to Home Depot and get some 7w 12v landscape walkway lighting bulbs and replace yours. WHAT A DIFFERENCE 7W bulbs make.
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 05-13-2008, 03:19 PM
I do, I will and tnx again Steve
Old 05-13-2008, 04:51 PM
Alfissimo Int.'s Avatar
Registered Alfa Addict
I run a similar one as well but in an LED.
If you want to go a bit more high tech.
I found if someone left that 7W bulb from home depot on it would melt the lens plastic.
LED makes no real heat, much brighter and less energy consumed.
Here is where I bought mine:
LEDtronics: Energy-Saving LED Light Bulbs and LED Lamps for All Industries
Ciao!
Jason Minos
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 05-13-2008, 04:59 PM
are they or is there a direct plug in LED without mods ?
Old 05-13-2008, 08:33 PM
Yes, take out the bulb, and match it up. The pictures of the bulbs are in true size so you can match it up to the right bulb and get an LED which plugs right in. No MODS!
Sorry I cannot remember the bulb number.
I think it is:
Instrument / Dashboard / Cabin Interior LED Replacement Lights
T3¼ (9mm) Miniature Wedge Based Bulb
they are pricey but if there is enough people interested we can do a group purchase to cut the cost.
I have LED's in my instrument cluster as well.
Jason
Jason Minos
