Old 05-13-2008, 09:39 AM
ke3ee ke3ee is offline
How to tell if theres air in your cooling system
How can you tell if there is air in the cooling system and if so how to bleed it with the bleed bolt on the thermostat ? Robb
Old 05-13-2008, 10:36 AM
Alfissimo Int.'s Avatar
Registered Alfa Addict
Bring car up to temp, Loosen bolt with 14mm socket, if air comes out let it bleed until water comes out, then close. If water comes out then system is fine.
But I like to make sure even if water comes out right, close it up wait a few and try once more to see if you get air. nothing more to it than that.
For the most part the system is self bleeding if there is a little air in it, but for large pockets do the above.
Ciao!
Jason
Jason Minos
<-GT Bertone, Spider, 75, GTV6, 164, all New models->.
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
