Old 05-12-2008, 05:55 PM
MrT's Avatar
MrT MrT is offline
"BRAKE" and brake wear indicatiors on full-time
The manual says this is the brake wear sensors worn through to open the circuit, but I can short circuit the sensor connectors (bypassing the sensors) and nothing changes. Car is a '93L driven by my son. Brake pads are in good shape and we fixed broken sensor connector wiring fully expecting the lights to go out when we did so. Didn't happen.
Also, we found the brake sensor connectors (big nylon cylindrical connectors on the fenders under the hood) to be crumbling. I see how to replace the outboard side running down to the calipers, but is there an easy way to replace the harness side connector? I have a parts car to rob those connectors from, or I _could_ simply use bullet connectors from the parts house if I want to be able to measure the sensor resistance without pulling the wheels. OK. I'll do that. Great idea. Thanks. Gee, you guys are smart. Now if you can only be that helpful about Q#1 above.
MIchael
Old 05-12-2008, 06:12 PM
MIchael
Find and replace blown fuse(s) in fuse panels (main and maybe aux).
Connectors inside engine compartment aren't they for air bag and ABS?
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 05-12-2008, 07:02 PM
MrT's Avatar
MrT MrT is offline
Now, Steve, you know? You might just be right. I'd thought I'd traced these wires before, but I may have really mis-remembered. I'd "confirmed" this in my memory when I saw the wires snaking down to the wheel well, but I'd forgotten about the ABS sensors. Oh, well. That's what happens when you don't get the manual out. I still have to bypass the sensors down behind the wheels now. Maybe that's where the mystery lies. If so, then you'll have been once again a wealth of wisdom.
Michael
Old 05-12-2008, 07:10 PM
Michael
As for brake light if you don't have a broken wire or shorted/worn insert in brake pad it is probably a blown fuse. I had two blown fuses on my car so no brake lights and rear lights but indicator icons on dash lighted.
Virginia Beach, VA
Old 05-12-2008, 07:27 PM
MrT's Avatar
MrT MrT is offline
The funny thing is that all of the lights work, tail and front. The problem is that too many lights are lit.... Two red ones on the dash stay lit: the one labeled "brake" and the one with the circle that looks like a brake disc. Like I mentioned above, but didn't explain quite as explicitly as here, the only problem is that these don't go out. The manual says the "brake" one is for low brake fluid and that if the pair go red only when brake pedal is pressed, it's indicating contact of the brake sensor against disc. If they stay red all the time, then the brake wear sensor wire is worn through and gives open indication between the two pins. But I mustrusted my memory and have to look again about the brake wear sensor pins.
Michael
Old 05-14-2008, 07:34 PM
nocemarco nocemarco is offline
Replace the switch infront of the brake pedal...its most likely that, I had the same problem.
Old 05-15-2008, 02:53 AM
AlexGS's Avatar
AlexGS AlexGS is offline
Send a message via MSN to AlexGS
The wear light has two functional modes:
1. When the wire loop is earthed, warning light comes on. This is intended to occur when the pad contacts the disc and the pad has worn down to the wire loop.
2. When the wire loop is worn through (becomes open-circuit), the warning light comes on. This is intended to occur when the pad has worn down a long way.
Now on my previous 164, I had the same symptoms that you're having and it was because the pad warning light wires (two of) were chafed on the caliper/brake disc, etc. If the wire becomes 'earthed', then the light stays on. If the wire gets chafed right through, then the light stays on...
For some of the more recent Italian models (probaby not the 164), the pad 'loop' is replaced by a single wire. At the plug connector, the plug has a wire loop so that the circuit is always complete. Then, the light comes on only when the wire is earthed. Still the same problem of course - if the insulation gets chafed through, the light comes on.
The solution is to get some 'spaghetti tubing' (woven fibreglass insulation sold in electrical shops, as used in ovens/heaters). Cut the plug off (or remove terminals etc.) and thread the insulation over the wires. A bit of insulation tape WON'T do...
I'm not saying the other suggestions in this thread are not valid, just reporting on what caused the problem on my 164
By the way I think my 164 had the ABS-style connectors inside the wheelarch for the pad wear wires, but this varies from year to year. The real ABS connectors are on top of the suspension struts, in the engine bay.
-Alex
'91 164 3L V6 Manual, green, '01 Punto Sporting CVT, yellow, '88 Uno Turbo, white
Old 05-15-2008, 04:12 PM
twoliterlover's Avatar
twoliterlover twoliterlover is offline
Question Tail Lights Have Something Weird
My 164 repair books book ssuggests that you have the wrong size tail light bulbs which allows the current to cross flow back around through brake light and worn brake light sensors. This is NOT a joke. Do you have the right size brake light and tail light bulbs in the rear? Did you replace them with similar looking American ones?
JAY NUXOLL [email="jay@alfanut.com"], seriously Alfa diseased and ancient OLD Two Liter Lover, put together Seattle area's Northwest Alfa Romeo Club in 1965, and still feebly tries to tend a teeny sacred flame to his serpent mistress in the ALFA G'RAJ MAHAL, a home garage temple with more Alfa cars and parts than he dare list because of the disapproval of his shamed and chagrined family. (425) 641-2600.
Old 05-15-2008, 05:21 PM
MrT's Avatar
MrT MrT is offline
This is _possible_, I guess. The car was being handled by my daughter when the problem showed up quite some time ago. The lights all illuminate properly, but I'll look at the lamp type now that you've mentioned it. Thanks for the off-normal suggestion.
Michael
Articles
