Old 05-11-2008, 01:27 PM
Craig's Avatar
Craig Craig is online now
75/Milano manuals for all
Fuel smell
G'Day Guys,
This is a good news story.
I have been suffering from a fuel smell only noticeable when reversing with the drivers (RHS) door open and was expecting to have to drop the tank and check vent hoses.
Checked around the filler one more time and finally found this:
The big hose clamp on the left is the filler pipe.
I have to say it was a pain to get two hands into this area to replace the rubber hose but as usual, you get there in the end.
Overall, very happy that I didn't have to drop the tank.
Craig,
1988 75 TS, 1989 164
Old 05-11-2008, 06:52 PM
jontg428's Avatar
jontg428 jontg428 is offline
Nice work Craig, dropping the tank is not so bad, but it is time consuming, and it helps to have another person with you to reinstall the rear sway bar. Glad your car is back to being fuel smell free!
Old 05-12-2008, 05:52 AM
ChazzyD's Avatar
ChazzyD ChazzyD is offline
When I first took possession of my car, I had to replace the entire filler neck. My car had never had the recall neck installed and the large filler tube on a USA car anyway, is mainly a fairly thin, molded rubber item and was badly cracked. The gas cap is originally a female cap and changes to a, more normal for the U.S., male cap with the recall item. I don't remember that T fitting on a U.S. car, BTW. That seems to be an area that warrants an inspection every so often, especially if you have the old style female gas cap, the rubber filler is likely "toast" by now (but my car was probably the only one left like that) .
Charles
'91 164L 5 speed 180k and counting
Chattanooga, TN - Home of the new VDUB factory!
Old 05-12-2008, 07:04 AM
Alfissimo Int.'s Avatar
Registered Alfa Addict
Charles
It's a twin Spark which has a bit different fuel system than the 3.0L V6 models.
I would just replace the hose with fuel grade hose as that hose and piece is N/A.
Jason
Jason Minos
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 05-12-2008, 07:37 AM
Tetteh's Avatar
Tetteh Tetteh is offline
ChazzyD, my 164 has also not had the recall neck installed. No one seems to have the new replacement neck. Where did you buy yours? (Oops, sorry. Did not mean to hijack this thread!)
91 164L, 2002 Mercedes Benz ML500, 2001 Mercedes Benz E430 Sport, 90something Mercedes Benz 190
Old 05-12-2008, 10:26 AM
ChazzyD's Avatar
Alfa Parts in Berkeley, CA. It is currently on their site, Fuel filler recall kit, 60897545 for $159.
Charles
Old 05-12-2008, 11:14 AM
Bandman Bandman is offline
Hmmm. My '91 164 have the problem of that when I fuel up, the automatic fueler shut off, cuts off resulting in having to do it manually and add the gas verrrrrrrry sloooooooowly. Is it a "neck problem" of a recirulation vent problem? (BTW: I aslo have the gas smell, too and I wonder if that could play into it.)
Old 05-12-2008, 01:03 PM
Craig's Avatar
Nope, sorry, it's a 3.0l V6.
I guess you guys would call it a Euro version (plastic tank and filler etc.) but it's probably an Aus/Swiss emissions version.
Craig,
Old 05-12-2008, 05:26 PM
MrT's Avatar
MrT MrT is online now
Originally Posted by Bandman View Post
Hmmm. My '91 164 have the problem of that when I fuel up, the automatic fueler shut off, cuts off .... (BTW: I aslo have the gas smell, too and I wonder if that could play into it.)
Where in VA are you? There are several 164 cars here in S.E. VA near VaBeach.
But, more to the point, the 164s we have all require you to hold the filler nozzle at an angle, generally 90 degrees clockwise rotated from the naive upright position. Then they fill pretty well up to within a gallon or so from full.
Gas smells come from several sources. Low on firewall at right side of engine compartment are two rubber splices on fuel supply and return lines. They leak with aged cars. I've replaced ours when monkeying with engines. The hoses on the engine also can be leaking. Craig recently found a fuel smell source from a disconnected line at the fuel filler behind the carpet in the trunk. Others have found plugged tank ventilation valves in the vapor recovery circuit. There are many sources in cars this age.
Michael
Old 05-12-2008, 06:47 PM
Looks like this is your car's EURO version of plumbling and lower line 6 to tee 3 in your picture.
Looks like top line 6 shoud be going to valve 2 in your picture do you have a line going to it?
Two different configurations in picture and looks like you have some of both?
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 05-12-2008, 08:58 PM
pavanbabut's Avatar
pavanbabut pavanbabut is offline
Send a message via MSN to pavanbabut Send a message via Yahoo to pavanbabut
Michael
Do ya mean that by doing this we can do automatic filling without holding the nozzle?? I always had problem with 93L but not with 95Q while doing automatic filling. As soon as I set it up for automatic filling, it just cuts off and then I have to hold it manually at an angle in upright position and fill it manually. Sometimes its annoying even when I do that it cuts off. -Pavan
1995 Alfa Romeo 164Q (136k)/5spd - Mr.Hottie
1993 Alfa Romeo 164L (150k+)/5spd - Mr.Dependable
1992 Subaru SVX (80k)/4EAT - #0211 - 4.44 Final Drive - My Baby
Old 05-13-2008, 04:01 AM
We hardly have the automatic cut off problem in VA as most pump handles have had that device removed to protect something - maybe the environment?
Virginia Beach, VA
Old 05-13-2008, 05:47 AM
AlexGS's Avatar
AlexGS AlexGS is offline
Send a message via MSN to AlexGS
When supermarkets started selling petrol here - just a few years ago - I noticed that the new pumps had "that device removed" as well. I asked someone in the business and they told me that, when there is no 'forecourt supervision' (in other words, people fill up their own cars and swipe a card to pay) the self-cut-off is not allowed. Why? Apparently people would leave the pump handle in the car, forget about it, and drive off. I kid you not. It's amazing who we share the roads with...
...mind you, I once pursued a Chinese lady after she drove out of the supermarket filling station with her fuel cap on the roof and fuel sloshing from the tank. I followed her to the traffic lights - much flashing of my headlights etc. had no effect at all - but the red light kept her stopped just long enough for me to knock on the window and refit the petrol cap.
Speaking of petrol caps, my 164 cap is plastic and screws onto the outside of the plastic filler neck. I wonder if that is the 'recall' type or not...
Cheers,
-Alex
'91 164 3L V6 Manual, green, '01 Punto Sporting CVT, yellow, '88 Uno Turbo, white
  #14 (permalink)
Old 05-13-2008, 05:51 AM
ChazzyD's Avatar
Alex, sounds like you have the older style filler/cap.
Charles
  #15 (permalink)
Old 05-13-2008, 06:31 AM
Alex Csank's Avatar
Alex Csank Alex Csank is offline
Trogdor the Burninator
Send a message via AIM to Alex Csank
Rick,
Have you checked the fuel line connections in the trunk and at the firewall? Also, I seem to recall a fix that Alfisto Steve wrote about some months back...unfortunately, I can't find it right now.
Steve - I believe that Bandman's car is a '91 US version 'L'. What is your advice?
Cheers,
Alex Csank
Chair, Alfa Century 2010 - The AROC USA ALFA Centennial Convention
E-mail: alfaromeodriver@cox.net or alfacentury2010@gmail.com
Mobile: (757) 636-9513
82 Spider Veloce (Desideria - Kathleen's)
84 GTV6 Maratona (Mona - resto project)
88 Milano Verde (Trogdor The Burninator)
"My name is Alex and I am an Alfaholic."
Alfisti are always welcome in our home!
Digg this Post!Add Post to del.icio.usBookmark Post in Technorati
