05-05-2008, 08:58 PM
Chattering relay in dash?
have an odd problem here. it apperas that a relay/ electrical device behind the instument cluster is chattering away all of a sudden. it also seems to chatter faster under harder accelleration. no noticable performance loss. anyone have any ideas?
One does not own an Alfa Romeo, you are entrusted with her.
05-05-2008, 09:32 PM
Where exactly does the noise appear to come from? The relays are in the fuse box under the dash. I had relays on my 1984 GTV rattling like mad and it turned out to be caused by the power wire on the thermo fan shorting against the radiator mounting. If your noise is coming from behind the dash it might be one of the air con stepper motors. There are three of them and the nylon gears wear and start to tick. I have one on the left hand side doing that. The fix is to replace the gears with brass ones. This is a bit of a bugger of a job and not one I have yet attempted. One day I will have to grit my teeth and get into it. Many people on the BB have done the job and can offer advice. Here are a couple of links to info that I have collected:
Alfa 164 Service Bulletins
alfapro.com - access methods
Good luck!
1988 Alfa 75 3 litre
1988 Alfa 33 1.7 TI
1990 Volvo 480 Turbo
1984 Alfa GTV 2000
1992 Alfa 164
05-14-2008, 02:29 AM
Does this look similiar to the problem I described in this thread? :
clicking relay & loss of power
It was several months ago, and now my problem is back again-came as unexpectedly as it went away back then. I haven't been able to pinpoint the solution. In fact usually there is no significant loss of power, the engine sometimes even tries to increase rpm, which results in a cut-out and hiccup. Everything else is perfect, idle, starting an so on. It happens when keeping the accellerator slightly depressed.
I tried disconnecting things, and came to a state when it doesn't happen.Either I have to disconnect AFM, or Idle Actuator. I cleaned AFM ( the magnetic stripe inside as well) and sprayed the Idle actuator inside with compressed air-this was all I could do without removing it.No good.
Anyway, next week I will have the car connected to an Alfa tester which I hope will shed some light on this mystery.
For now IAC and AFM are the first ones to blame, though car doesn't show any othe symptoms of them beeing faulty.
I found some more posts decribing more or less the same problem:
Subject of this Thread: "Relay?"-- Powered by DCForumLite -- www.sitedeveloper.com
164 Discussions - ECU Inspection
BTW, which model is Your car ? It seems to happen mostly on 24V cars, but mine is 94' 12V Euro, which uses the same motronic 1,7
E.T.
05-14-2008, 09:02 AM
Which year/model 164 do you have and LHD or RHD? North American model or Euro?
Virginia Beach, VA
sdpatchin@aroc-usa.org
08-13-2008, 05:17 PM
talk about a delay
ET the problem sounds similar to yours in that it hicupps at light acceleration . Steve its a US model '91 S. It's not in the fuse panel its sounds as if its directly behind the tach. It went away for a month or so and has just come back with a vengance. Any help would be appriciated. Thx
08-13-2008, 07:55 PM
Four relays behind instrument cluster on 91-93 12v 164 are, a/c compressor clutch relay, radio, high beams and if a/t model gear signal for engine ecu.
WARNING If you remove instrument cluster to access relays do not turn on power with instrument cluster connectors disconnected because you will induce a fault into air bag computer and it is hard to clear.
Virginia Beach, VA
08-14-2008, 02:59 AM
HI, the good news is that I finally got rid of the problem, for 99% !
to cut it short : it's the EVAP -fuel fumes recirculation valve. It is located in left fender well, you need to lie down and look for a two-wire Bosch connector plugged into a little solenoid valve which is attached to a little canister. For more convenient acces you can remove the left headlamp.
This worked for me, I haven't supplied this info to the forum since I have not fitted a new valve yet, so not 100% sure if it won't come back. Although, the old valve is broken for sure- it has 4 KILOohms of resistance and should have about 50 ohms, and obviously doesnt click when supplied with +12v.
So now I have it disconnected and the car runs great. I also disconnected the fumes line that comes from the back of the car to that canister to release pressure from tank, I know it polutes more but it's temporary until I fix it.
As I wrote in my post above, I had my car conected to a computer which showed no errors. Probably because the valve still had resistence, so ECU recognized it as beeing operative.ECU starts to operate the valve when the car warms up a bit and under conditions which let the fumes to be sucked and burnt, namely under acceleration -which is exactly when my car started to hiccup and click. Ecu supplies constant +12v and swithes ground momentarily a few times over several seconds to open the valve and let fumes into the intake manifold. I suppose while switching ground and facing huge resistance of the valve, the ECU went into some uncontrolled state and switched the ground between the A/C relay which I heard chatter at high rate. I have no idea how exactly that might hapen, but to me everything seems to correspond.Now it also looks reasonable that when i disconnected AFM or IAC the car wolud not try to operate EVAP due to switching into pre-programmed default fuel map ( limp home mode ).It was quite misleading.
At first I suspected the valve was shorted internally, which would even be more likely to cause strange behaviour of the ECU, but luckily it isn't. I learned that in some Hondas this valve beeing shorted would cause the ECU to fry...
I hope this solution will also work for you, though I think 91-93 US cars use different part number and different motronic ECU.
Please let us know, it seems to be an example of a very rare failure.
E.T.
