Old 04-25-2008, 08:00 PM
Richard2 Richard2 is offline
Has Anyone Seen One Worse Than This?
I bought this red 164S 4 years ago with a bad engine. I haven't look at it and needed some parts for the engine I'm building to put in the red car so thought I'd see if I could use the cams and maybe a couple of rods.
Well, here's what I found. My oh my. Bad engine indeed!!!
Richard2
1991 164B Silver Daily Driver
Old 04-26-2008, 05:00 AM
So what's wrong with that just a little scrap metal and no compression!
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 04-26-2008, 07:12 AM
I have the piston pin, so maybe I can weld the piston back together and it's good to go? Maybe a couple of hose clamps to secure the liner pieces?
That was #1, some metal pieces had migrated to #3 and bent the intake valve there also.
Richard2
Old 04-29-2008, 10:00 PM
AlexGS's Avatar
AlexGS AlexGS is offline
Send a message via MSN to AlexGS
I think maybe get the angle grinder out and modify the block/crankcase so that you have a three-cylinder. Good for economy. Honda are doing it these days, but for some reason they keep the other cylinders there 'just in case'. Why? Save weight!
12V V6 has 192bhp so 6V I3 should still have over 90bhp, enough to push the 164 around
Also you'll have a spare set of injectors. Doubling the airflow meter output shouldn't be too hard so that the ECU is happy... or maybe have two injectors squirting into each inlet port. I have to admit that the chromed intake tubes won't look quite as nice with only three. And, you'll have a twin-spark distributor.
-Alex
'91 164 3L V6 Manual, green, '01 Punto Sporting CVT, yellow, '88 Uno Turbo, white
Old 04-29-2008, 10:16 PM
elite38868's Avatar
elite38868 elite38868 is offline
compratore di alfa
Send a message via AIM to elite38868
Newsflash, Alex, we north american's have 6 cylinders, so I guess Richard will have to settle for a 5 cylinder...
Sean
Alfa Romeo Association - Tour Director
www.alfaromeoassociation.org
92' 164S - Black
Old 04-29-2008, 10:23 PM
AlexGS's Avatar
I meant to cut the engine in half!
That's why I quoted power of the V6... I have a V6 too, y'know...
Honda have made their new V6 run on three, four, or six cylinders (that was what I was referring to), but I just thought maybe the same could be achieved, with a weight saving, through a careful modification... with the fuel and ignition caveats that I pointed out...
Volkswagen meanwhile make a VR5, so yes you could go down that route, but VW's is a much narrower angle than 60-degrees; I think there might be a problem with the firing intervals of an Alfa V5.
-Alex
Old 04-29-2008, 10:26 PM
elite38868's Avatar
compratore di alfa
LOL, just giving you a hard time, buddy.
There are many cars here that have V8's, but only run on 4 of the cylinders unless more power is demanded.
Sean
92' 164S - Black
Old 04-30-2008, 02:06 AM
AlexGS's Avatar
Cheers
Yeah, Chrysler are pushing their 300C here - big-engined cars are not in vogue right now, so they're making a big thing of the V8 that makes itself a four-cylinder...
I knew of someone locally who wanted more power in their FIAT Bambina, so they cut a FIAT 128 engine in half to make a big-ish two cylinder. I never quite knew why, as the power output must have not been a lot more than the air-cooled twin, but they did it and proved it could be done.
-Alex
