Old 04-24-2008, 12:36 PM
DanW DanW is offline
Dead Battery, trunk locked
Steve et. al.: In the process of prepping my L for resale, donation, etc. I tried to open the trunk using the dash button. Not suprsingly, the solenoid didn't "kick" as the car has been sitting for a month or so and driven very sparingly over the last 4 months.
To add insult to injury, the master key broke over a year ago and I have been using the velet key only. So, I can't unlock the trunk with the key.
Finally, I tried to fit my long jumper cables onto the positive lead located on the false fire wall. No dice, I can't even get the clips to fit into the space. Too tight.
I also tried a portable jumper battery but had the same fit problem.
Is there an emergency trunk latch release inside the trunk itself? I saw no mention of it in the owners manual.
Any other ideas?
Old 04-24-2008, 12:56 PM
jontg428's Avatar
jontg428 jontg428 is offline
The valet key can be made into a master key by grinding it down to be thinner. There is a post on this with pictures somewhere, which would help, as I cannot give you anymore details. Best of luck,
Jon
Old 04-24-2008, 01:55 PM
fetta78 fetta78 is offline
I've opened mine from the false firewall lead..........are you sure you have a good ground?
Can you have someone in the car pressing the trunk button while you hold the cable on there?
Just a thought..........
Oh, and here is a pic of the Positive lead for the those that may not know where it is.
Tucked behind the big fuse on the drivers side!!
Old 04-24-2008, 01:59 PM
sjmst's Avatar
sjmst sjmst is offline
sjmst
Yes, and check your fuse for the radiator fan after using the firewall jumping method. My cars always had burnt fuses after doing this way.
-Sam
"You're not a proper petrol head until you've owned an Alfa."
Jeremy Clarkson
1995 Alfa 164 LS
1981 Fiat Spider (original owner)
Old 04-24-2008, 03:15 PM
Thanks for the tips. Like I said, connecting to the positive fire wall terminal is futile. I''ll try to simply hold the positive in place and pop the trunk. Then I'll connect to the battery directly.
-Dan
Old 04-24-2008, 03:36 PM
Your 164 doesn't want to go. Selling or donation no wonder you can't open trunk as it has a mind of its own.
Just file down inner sides of valet key until it fits trunk lock.
Drive it once in a while once you get battery up to snuff.
As for frontal lobe terminal if your battery RED jumper terminal cable connector is that big remove both front cooling fan fuse holder and rear blower motor fuse holder from terninal board and rubber strip on top of false firewall and grip both sides of teminal lugs without touching metal in false firewall.
Attach black ground cable to engine.
There is no emergency cable to pull to open trunk.
Virginia Beach, VA
[email]sdpatchin@aroc-usa.org[/email]
[url]http://www.aroc-usa.org/tech/index.asp[/url]
[url]http://www.aroc-usa.org/[/url]
[U]Daily drivers[/U]: USA models 91 Bianco 164B 5-speed ALFA 4ME, 91 Argento aka "Quik Silver" 164B ALFA 4US w/AT, 93 Rosso 164L 5-speed - semi-daily driver with issues.
164L [U]Rescue projects[/U]: 91 Argento aka Non-QS, and organ donor 91 Nero 164L
[I]"A day without an Alfa whine is like a day without sunshine"[/I]
Old 04-24-2008, 03:38 PM
You gotta move cooling fan fuse out of the way don't jump to it. Jump to large battery terminal behind it.
Virginia Beach, VA
Old 04-24-2008, 05:34 PM
cmbenedict's Avatar
cmbenedict cmbenedict is offline
AlfaBB addict
Sort of embarrassed to suggest but I am not as mechanically knowledgeable - just learning Alfas. How about getting one of those battery jumpers that go through cig lighter (no laughing pls). As you only need enough juice to fire the lock may save you the need to grind your valet or risk jumping and burning fuses. May be worth a try.
1991 Alfa Spider Veloce
2001 BMW 530i
1967 Pontiac Firebird convertible
Old 04-25-2008, 08:35 AM
Good idea, cm. I picked up a battery charger/jumper with variable amp settings. The charger's clips are small enough to connect, so I will try at the false firewall with minimal power, just enough to pop the trunk. I can then trickle to the battery directly.
Old 04-25-2008, 11:49 AM
Thanks to all. I got the trunk popped with the charger set on 3 amps. Funny thing was that both front seat motors began running, both forward and up, and they would not stop until I reconnected the charger to the battery at 10 amps.
After about 5 minutes, I tried to start but no dice. I swapped to my high current jumper cables directly hooked up to my other car. Grrrr....vrooooooom with a belch of smoke. Good enough for me.
I hate to see the car go, but go it must. Too bad I won't be driving it in tomorrow's Ferrari club blast through the Berkshires, but I'll be sharing a Porsche Caymen and a super-duper Subi just the same.
Thanks again, everyone.
-Da
Old 04-25-2008, 03:06 PM
Tetteh's Avatar
Tetteh Tetteh is offline
Somebody save that 164L, please!!!!!!!
91 164L, 2002 Mercedes Benz ML500, 2001 Mercedes Benz E430 Sport, 90something Mercedes Benz 190
