Old 04-20-2008, 05:47 PM
itapol itapol is offline
a/c compressor sys??
does the a/c have a relay or just the 10a fuse and 40a fan fuse? My system is fully charged but the air does not get cold....And I cannot not hear a click under the dash or at the compressor?
Old 04-20-2008, 06:36 PM
It has two relays one for blower motor and one for a/c compressor clutch.
If blower motor works then both fuses OK.
To test a/c clutch relay and a/c clutch, remove rectangle cover over frost switch near expansion valve on evaporator box behind false firewall and with key on and a/c auto switch on, ground gray-black wire going to frost switch. Relay in dash behind speedo should click and engage a/c clutch whether you have freon or not.
How do you know freon fully charged if compressor won't engage? How much pressure do you have in low side (blue hose on gage set)?
Virginia Beach, VA
[email]sdpatchin@aroc-usa.org[/email]
[url]http://www.aroc-usa.org/tech/index.asp[/url]
[url]http://www.aroc-usa.org/[/url]
[U]Daily drivers[/U]: USA models 91 Bianco 164B 5-speed ALFA 4ME, 91 Argento aka "Quik Silver" 164B ALFA 4US w/AT, 93 Rosso 164L 5-speed - semi-daily driver with issues.
164L [U]Rescue projects[/U]: 91 Argento aka Non-QS, and organ donor 91 Nero 164L
[I]"A day without an Alfa whine is like a day without sunshine"[/I]
Old 04-21-2008, 05:13 PM
Check low side with guage is the green zone. Both fuses are not broken/separated..There is no click under speedo when go to ac mode via auto and lo temp...where is the clutch relay location and what part name and markings?
Old 04-21-2008, 05:40 PM
Alfissimo Int.'s Avatar
Registered Alfa Addict
Check the 12V to the compressor and the ground.
I have had the compressor 12V loosen and come undone, therefor having the same issues you are having.
My bet it is something simple.
Jason
Jason Minos
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 04-28-2008, 06:07 PM
IS the clutch relay the large off white one under the speedo? what are the markings?
