Old 03-31-2008, 04:36 PM
rkundrat's Avatar
rkundrat rkundrat is offline
Alfa User
clutch engages low
So it's always had a little play, maybe 1" of travel before I felt the resistance of the clutch disengaging. Recently this floppy travel before engagement has grown. The pedal now moves 1/2 - 2/3 of the way to the floor before the clutch begins to disengage. Seems to sit lower if it's colder or the car has sat a couple days. I'm still able to fully disengage and shift properly, but I'm worried my luck will run out soon. When in the range of the clutch being disengaged/engaged, the pedal has a very strong return, above that point, only the pressure of the return spring on the pedal itself. The clutch does fully engage and holds very tight, never any slipping. I was thinking master or slave cylinder, but if were one of the two, how do I determine which is the culprit??? Thanks!
Ryan
1992 Alfa 164S
2005 VW GTI 1.8t
2003 Ducati Monster 800S i.e.
2002 Ducati Monster 620 i.e.
ryan kundrat jewelry
Old 03-31-2008, 05:15 PM
jol's Avatar
jol jol is offline
As the slave more often is the one, try it first It's cheaper aswell and not too hard to change.
Peter Strandberg
164 3.0 -89, 33 Sw 4x4 -89
Old 04-14-2008, 05:24 AM
rkundrat's Avatar
Alfa User
Okay, so I didn't take my own advise and preempt a non-working clutch. Started her up this morning and clutch won't disengage. Pedal goes nearly to the floor and does not return on it's own. Luckily I was able to get a loaner car, but I'm at work with no access to my cardisc. Does anyone have p/n for the slave cylinder? Is there anything else I should replace when doing this? I've not done one before, but it seems fairly straight forward (well more so than the master.) Thanks!
Ryan
1992 Alfa 164S
2005 VW GTI 1.8t
Old 04-14-2008, 06:14 AM
164S clutch slave cylinder
For 164S I think the current part number for clutch slave is 71738465 was 60801577 IAP 05759. Kit for slave is 9940854 and hose to slave to bypass damper if installed is 60608470 IAP 06282
71738465 is now supposed to be number for all 164 models.
Clutch master is 60511530. IAP 05754
I would order slave, kit and hose. If you want to be sure order master too.
Did you inspect pedal to be sure it is OK?
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 04-14-2008, 07:08 AM
rkundrat's Avatar
Alfa User
I have not inspected the pedal, good thought Steve. I will check for cracks and elongated pivot point tonight.
I had the damper bypassed about 8 years ago (meaning hose is 8 years old.) Should I still replace hose 60608470?
Is Kit just to rebuild old slave cylinder?
Also, do I need a presure bleeder or can I do it with a helper pushing the pedal? (What am I saying, perfect opportunity to get another tool!)
Ryan
1992 Alfa 164S
2005 VW GTI 1.8t
Old 04-14-2008, 11:22 AM
I would bet a new hose just to be save. Pressure bleeders are nice and makes the job of flushing out/bleeding both clutch and brake hydraulic systems a lot easier.
Kit is to do slave and it maybe all you need that way if nothing else you will have a spare slave or kit. I know Difatta has kits and hoses as I have gotten them from them before.
Virginia Beach, VA
Old 04-14-2008, 01:27 PM
Alfissimo Int.'s Avatar
Registered Alfa Addict
Usually the kits are for Bendix/Bonaldi Slave cylinders.
I would replace the hose. If you have newer after-market slave, kit may or may not work.
New slaves are not expensive
Jason
Jason Minos
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 04-15-2008, 06:35 AM
rkundrat's Avatar
Alfa User
Thanks guys.
Does anyone know if there is a braided stainless clutch hose available for the 164? Thought I read or heard about this once before. I figure if I'm replacing it anyway...
Ryan
1992 Alfa 164S
2005 VW GTI 1.8t
Old 04-15-2008, 08:11 AM
Thanks guys.
No. But I have one. I did not like it. Made the clutch very hard to push in. Under heavy traffic my calf muscle got huge.
I would just replace with the rubber one. As long as you be careful not to hit it if your working in that area it should last a good long time.
Jason
Jason Minos
Old 04-16-2008, 05:12 PM
rkundrat's Avatar
Alfa User
So I got into replacing the slave this evening. Was going fine until I tried to get the slave out of the bracket (damn new england rust...) I hammered, pressed in vise, even heated with my jewelry torch. Nothing. I think I'll have to wait until I can get to a garage to have someone press it out for me. Anyway, while trying to control my bracket frustration I decided to inspect the clutch pedal pivot. I have not removed it but did not notice any abnormal play when pressing it slightly and inspecting the mount and pivot points. I DID, however, notice some brownish fluid on the clutch mounting bolt... I'm beginning to think I may be in this for a slave and a master. Luckily I ordered both, should I just do the master, or try bleeding the system through after finishing the slave?
Ryan
1992 Alfa 164S
2005 VW GTI 1.8t
Old 04-16-2008, 05:46 PM
Was your slave leaking externally? If not then master maybe going bad.
Virginia Beach, VA
Old 04-16-2008, 05:56 PM
rkundrat's Avatar
Alfa User
The boot was completely torn on the slave, but I didn't notice any fluid... I'm thinking the master is the problem too... I guess I'll plan on starting that as well. I seem to remember reading that removing the seat is the easiest way to work on the master?
Also noticed a oily film inside the afm and rubber intake hose when I pulled the airbox. Is that something to be concerned about? (btw I use a stock alfa paper filter, not k&n with the oil.)
Ryan
1992 Alfa 164S
2005 VW GTI 1.8t
Old 04-16-2008, 06:52 PM
peglegtom peglegtom is offline
Had the same problem on my 164Q and it was the Slave
I replaced just the slave cylinder after the clutch pedal went to the floor on Thanksgiving. Had some problems bleeding the system with the normal pedal push procedure, but got the air out by removing the slave from the bracket and holding it as high as possible, then doing the pedal push procedure. Use a C-clamp to hold the rod and piston in the slave when you do this. A normal C-clamp works a lot better than one of the "squeeze" types!
I also had a problem getting the slave out of the bracket. (I bought my car from someone that used it as a daily driver in MA). Finally got it out by removing the slave and bracket assembly from the trans. and then heating the bracket with a propane torch. I also applied a lot of P-B blaster prior to this without sucess. The torch worked wonders, but I wouldn't do it under the hood.
Hope this helps!
(2) 67 Duettos (currently being made into one decent driver)
97 Ford Taurus SHO (my daily driver)
99 Jeep Grand Cherokee (need something to haul the boat).
And a new Nero & tan 95 164 Quadafilorio as a second daily driver (at least in the summer!)
  #14 (permalink)
Old 04-17-2008, 03:01 AM
rkundrat's Avatar
Alfa User
Hmmm... Maybe I just need to get it really cooking. My jewelry torch is a small direct flame, so perhaps a bit more heat is in order...
Ryan
1992 Alfa 164S
2005 VW GTI 1.8t
  #15 (permalink)
Old 04-17-2008, 04:01 AM
I am sure seat removal will help as my friend did it on his Milano
Oily film is normal because one hose from oil seperator hooks to intake hose.
This is part of the "positive crankcase vent" (PCV) system.
Virginia Beach, VA
