Old 03-28-2008, 09:13 PM
Aquino(FR)'s Avatar
Aquino(FR) Aquino(FR) is offline
help... running rough/ idling problem suggestions?
I recently replaced the sparkplugs/wires/cap and rotor and igniton coil on my 91 164s and the car still seems to run rough. To be more specific, the car runs rough and when the car is warmed up it starts to idle high like around 1500-2000. On numerous occasions, I would have to rev the engine a couple of times before it idles normal again. The car is still at the mechanic shop and he still has to diagnose it. He said that he will do a fuel pressure test and then do a compression test in making sure the engine is ok. The reason behind the compression test is because it almost seems like its running on 5 cylinders but we could be totally wrong..
He also indicated that it could be the O2 sensor. In otherwords, process of elimination at this point to determine the problem.
Is their any additional information I can pass on to the mechainc that will further help him pin pointing the problem??
He also noted which I have heard as well that once the car is warm you hear a knocking like sound in the car. I thought it was the tappets but he thinks it may be a piston?
Any suggestions would be greatly appreciated!!
[SIGPIC][/SIGPIC]
1991 Alfa Romeo 164S
1968 Mercury Cougar
1969 Fiat Spider
Old 03-28-2008, 09:19 PM
AlfaTango1's Avatar
AlfaTango1 AlfaTango1 is offline
but this one goes to 11..
Was it running like this before?
currently: 1984 GTV6 (Sabrina) 1992 164L (Jill) 1992 164S (Kelly) 1989 Spider Veloce (Julie)
jol's Avatar
jol jol is online now
Check that the timing belt hasn't slipped or vacuum leaks
Peter Strandberg
164 3.0 -89, 33 Sw 4x4 -89
Old 03-28-2008, 09:25 PM
Aquino(FR)'s Avatar
These symptons started about a couple of months ago... The mechainc did not mention the timimg belt but I will ask him.
What would be the best method at checking for vaccum leaks for this car?
[SIGPIC][/SIGPIC]
1968 Mercury Cougar
1969 Fiat Spider
Old 03-28-2008, 09:59 PM
oz3litre's Avatar
oz3litre oz3litre is offline
Some of the V6s seem to have this knock when hot. There was a thread on it here once. My Alfa mechanic, who is one of the best, says it is something to do with the tolerance on one of the main bearings or the crank and that it is nothing to worry about. He once put new bearings in a 2.5 that was doing it and it didn't make any difference. You will find that it goes away just off idle speed if that is what it is, because it loads up the crank. It doesn't knock on the over run or under load. Using a good quality heavier oil helps. I use a 25W/60. I don't think those engines like the thin oils some of the new engines use. In fact most of our club members use thicker oils in any of the old engines, including the twin cams.
1988 75 3 litre, 1990 75 3 litre Potenziata, 1984 GTV 2000, 1992 Alfa 164 3 litre, 1990 Volvo 480 Turbo
Old 03-29-2008, 12:37 AM
jontg428's Avatar
jontg428 jontg428 is offline
I believe the knocking is just piston slap, nothing to worry about
Old 03-29-2008, 08:55 AM
Aquino(FR)'s Avatar
He replaced the fuel pump not too long ago but from past threads Ive read that good fuel pressure is 48psi but what is good compression? I will find out from the mechanic today what these are..
[SIGPIC][/SIGPIC]
1968 Mercury Cougar
1969 Fiat Spider
