Old 03-25-2008, 12:48 PM
MVP MVP is offline
Bearing Replacement
I know this has been talked about on this site 100 or so times but I still have to ask. Has any one found a replacement bearing inside the idler for the pulley for the alternator and ac belt? Just the bearing not the hole unit
THANKS FRED
Old 03-25-2008, 01:10 PM
Alfissimo Int.'s Avatar
Registered Alfa Addict
THANKS FRED
If your referring to the idler pulley on the serp belt, yes. I have the bearing.
I use a SKF bearing filled with Krytox grease. This grease out performs standard hydrocarbon grease by 400˚F and triple the load bearing. grease bonds to surfaces to protect them and the bearing should last for about 5 years or more without needing a re-pack.
Bearing alone with Grease: $79
re-packs -$17.00
I have had great success with the grease in all my idler pulleys I have packed for the 164 and other vehicles.
I guarantee the bearing will not fail. If it does in the first year I will replace it. I still may depending on the problem after the 1st year.
Jason
Jason Minos
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
