03-23-2008, 05:54 PM
Bleeding 164 brakes
My 164 needs new front brake hoses. I am trying to decide whether or not to tackle the job myself in view of the fact that it has ABS. I have done a million brake jobs on non ABS cars. Is this a job for someone with a pressure bleeder or can I do it myself? I don't want to find myself unable to get a pedal and then having to pay for it to be towed to my Alfa mechanic anyway. Any advise will be greatly appreciated.
1988 Alfa 75 3 litre
1988 Alfa 33 1.7 TI
1990 Volvo 480 Turbo
1984 Alfa GTV 2000
1992 Alfa 164
03-23-2008, 08:23 PM
If all you are doing is replacing the hoses, it doesn't matter if it has ABS or not.
1.Can you find someone to pump the pedal while you bleed the brakes?
2. I made a really cheap pressure bleeder out of an inner tube and a second 164 brake reservoir.
3. Are you replacing the rear hoses? If so , the rear wheel you are bleeding must be raised up and not lower as when you use the jacking point. The rear balance valve must be actuated to get fluid to that brake cylinder.
4. Bleeding the front brakes is straight forward.
Richard2
1991 164B Silver Daily Driver
03-23-2008, 08:27 PM
Registered Alfa Addict
Do it yourself.
You need a partner for the pedal. The rear brake valve needs to be in a normal level position for the fluid to bleed.
1. Begin at the corner furthest from the driver and proceed in order toward the driver. (Right rear, left rear, right front, left front.) While the actual sequence is not critical to the bleed performance it is easy to remember the sequence as the farthest to the closest. This will also allow the system to be bled in such a way as to minimize the amount of potential cross-contamination between the new and old fluid.
2. Locate the bleeder screw at the rear of the caliper body (or drum brake wheel cylinder.) Remove the rubber cap from the bleeder screw – and don't lose it!
3. Place the box-end wrench over the bleeder screw. An offset wrench works best – since it allows the most room for movement.
4. Place one end of the clear plastic hose over the nipple of the bleeder screw.
5. Place the other end of the hose into the disposable bottle.
6. Place the bottle for waste fluid on top of the caliper body or drum assembly. Hold the bottle with one hand and grasp the wrench with the other hand.
7. Instruct the assistant to "apply." The assistant should pump the brake pedal three times, hold the pedal down firmly, and respond with "applied." Instruct the assistant not to release the brakes until told to do so.
8. Loosen the bleeder screw with a brief ¼ turn to release fluid into the waste line. The screw only needs to be open for one second or less. (The brake pedal will "fall" to the floor as the bleeder screw is opened. Instruct the assistant in advance not to release the brakes until instructed to do so.)
9. Close the bleeder screw by tightening it gently. Note that one does not need to pull on the wrench with ridiculous force. Usually just a quick tug will do.
10. Instruct the assistant to "release" the brakes. Note: do NOT release the brake pedal while the bleeder screw is open, as this will suck air back into the system!
11. The assistant should respond with "released."
12. Inspect the fluid within the waste line for air bubbles.
13. Continue the bleeding process (steps 11 through 16) until air bubbles are no longer present. Be sure to check the brake fluid level in the reservoir after bleeding each wheel! Add fluid as necessary to keep the level at the MAX marking. (Typically, one repeats this process 5-10 times per wheel when doing a ‘standard' bleed.)
14. Move systematically toward the driver – right rear, left rear, right front, left front - repeating the bleeding process at each corner. Be sure to keep a watchful eye on the brake fluid reservior! Keep it full!
15. When all four corners have been bled, spray the bleeder screw (and any other parts that were moistened with spilled or dripped brake fluid) with brake cleaner and wipe dry with a clean rag. (Leaving the area clean and dry will make it easier to spot leaks through visual inspection later!) Try to avoid spraying the brake cleaner DIRECTLY on any parts made of rubber or plastic, as the cleaner can make these parts brittle after repeated exposure.
16. Test the brake pedal for a firm feel. (Bleeding the brakes will not necessarily cure a "soft" or "mushy" pedal – since pad taper and compliance elsewhere within the system can contribute to a soft pedal. But the pedal should not be any worse than it was prior to the bleeding procedure!)
Easy
03-24-2008, 05:49 AM
The only thing specifically pertaining to the 164 is, when you bleed the rear, the suspension must be loaded to get the rear calipers to bleed. There is a weight biasing valve in the rear that will prevent bleeding if the wheels are hanging.
Charles
'91 164L 5 speed 179k and counting
Chattanooga, TN - Home of the new VDUB factory!
03-24-2008, 01:13 PM
Thanks for the help guys. You have given me the confidence to do the job myself and hopefully save some money. I'll let you know how it goes.
1988 Alfa 33 1.7 TI
1984 Alfa GTV 2000
1992 Alfa 164
03-24-2008, 01:40 PM
Be sure you have some correct size brake line wrenches 11mm, 13mm 15mm; 17mm to loosen rigid line flare nuts while holding hose ends.
Such as these: Craftsman 5 pc. Wrench Set, Nut Metric - Model 42013 at Sears.com
Also have some PB blaster aka Liquid wrench or WD-40 spray and spray fittings before trying to remove hoses.
Virginia Beach, VA
sdpatchin@aroc-usa.org
03-25-2008, 12:47 PM
compratore di alfa
Don't forget to make sure the rear hubs are raised up as if it was sitting on level ground so that the proportioning valve sends the full amount of fluid.....
03-26-2008, 10:06 PM
I put a new master cyclinder in our 164Q and didn't have any problem bleeding the brakes. I have done lots of systems the old fasioned way (single handed no less) but this time bought a vacuum bleeder from Griots. It seemed to work just fine.
91 164L
71 Mangusta
95 164Q
67 S1 E-type FHC
(a little lime on the side
with my pasta please)
03-27-2008, 07:51 AM
Charles
I replaced the back rotors and pads on the back myself once and had some one help me blead the brakes, the only problem was that I did NOT have 'load' on the rear when I was bleeding them... One of the rotors to nearly white hot before I noticed the burning, luckily it was only a short test drive.
Yep... listen to the guys that know what they're doing this is a great forum.
03-27-2008, 08:01 AM
I replaced my front rotors and pads and bled all four wheels until I can see clear fluid running out. But, still the pedal feels soft, I mean its not spot on, you need to push it lower gradually to get the full braking effect. Is there something else I need to look at to get rid of this??
-Pavan.
03-27-2008, 09:06 AM
-Pavan.
Sounds like there is still air in the system. Follow the procedure above. If you bled correctly most likely a bad MC.
Soft pedal is 98% of the time Air still trapped in the system. You may have to pump the pedal 10-20 times to get all the air out of the system while keeping the tank full of fluid as well.
You must make sure that when the pedal is at the bottom you CLOSE the bleed screw and then let up on the pedal. You must also make sure the hose on the nipple is tight so that air does not leak back in.
I think you need to do it again to verify the MC is not bad.
12V or 24V
Jason
