03-12-2008, 07:19 PM
lopey idle
i have a 91s w/120,000 miles. it was parked for 3 yrs with a bent valve and i recently pulled the heads and had them overhauled. i drained the tank, pulled the fuel pump and cleaned the tank. fuel pressure is 40-45lbs. new plugs, fuel filter, dist cap, mech tensioner, checked every hose for vacumn leaks, and i pulled the cam covers 3 times checking valve timing. its dead on. i get a trouble code 1223, but i have checked everything i can think of. i am running out of ideas. help! it idles when warm like a hot rod chevy. george
03-12-2008, 08:07 PM
1223 Lambda probe regulation faulty
According to the Alfa Digest Page the 1223 is a Lambda probe regulation faulty. Maybe replace o2 sensors.
03-12-2008, 09:02 PM
Re:
my cardisc shows as inner lambda adjustment out of range. i replaced the o2 sensor about a year before it broke and i got mad and parked it. i may go ahead and buy another one. possibly def from sitting?
03-12-2008, 10:37 PM
no matter how bad an o2 sensor is it will NOT make the car idle that bad. Since you took the heads off, look for vacuum leaks. That code doesn't mean a bad o2, the o2 just sees a very lean or a very rich mixture. put a volt meter on that o2 and it should read about .7 of a volt, thats point 7 of a volt. then check the throttle position switch and make sure that small ground strap on the rear head was reinstalled, umder the throttle body..Have fun Jim
93 164s, 88 quad, 81 spider, 78 alfetta gtv, 87 2.5
87 3.0, 88 3.0, 87 testarossa, 03 dodge hemi 4x4
03-13-2008, 12:11 AM
Might not hurt to do a compression check, if the heads were rebuilt by some yahoo they may have done a bad job.
03-13-2008, 12:51 AM
Faulty injector. Sticking or rubbish in needle & seat causing bad spray pattern.
03-13-2008, 05:35 AM
George Schweikle
As a long shot, check the fuel pressure regulator. I had one fail on a GTV-6 years ago, and the car ran very rich with a lopey idle (it ran fine at higher RPM). At idle, the regulator should allow excess fuel to return to the tank. Remove the fuel line after the regulator, and run a longer line to a container. When the engine is started, there should be a stream of fuel running into the container.
In my situation, the temporary fuel line on the GTV-6 had no "returned" fuel apparent. Performing the same check on my wife's Milano filled the container quickly.
George Schweikle
Scuderia Non Originale
03-13-2008, 11:12 AM
i have isolated all vacumn lines, sprayed around manifold base, i have not checked fpr or o2 sensor. afm hose is new. i will check tonight and then see about having the injectors cleaned. it runs very well above idle and valve clearances are ok
03-14-2008, 10:50 AM
injectors
fuel pressure regulator is good. i ran a injector test 1444 to actuate the injectors. using a stethoscope, a couple of injectors sounded low and dull while the others were fairly loud and clear. gummed up? the car sat nearly 4 yrs.
03-14-2008, 11:26 AM
I've never replaced an injector for being gummed up...Check o2 readinds and the throttle position switch also ground strap...................
03-14-2008, 04:41 PM
I had this code too and I changed the spark plugs, wire, cap rotor and lambda probe and it still flashed the code after. I found out it was my intake hose from the air cleaner to the plenum. It had cracks in the rubber everywhere there was a seam. Once I duct taped it the 1223 is now gone and she idles fine.
03-14-2008, 04:48 PM
I bought a used engine that had been sitting on a shelf for years and all the injectors were bad. It would only start to show signs of life after shocking each one with 12V directly. Once I put a spare set of used injectors in, she fired right up. So if they have been sitting for a long time unused, they can become clogged to the point of failure. Make sure all the connectors are clean though first before condemning them.
Charles
'91 164L 5 speed 180k and counting  '04 Volvo XC70 (momma's new ride!)
Chattanooga, TN - Home of the new VDUB factory!
03-14-2008, 04:51 PM
Like i said a 1223 code is not a bad O2. And 164guy a cracked air tube is more then likely very soft engine mounts...Change those first then air tube, Which I have the "S" and "L" air tube and engine mounts.....Thanks jim
03-14-2008, 10:54 PM
idle
hi jim. new motor mounts, plenum hose, all the consumables replaced. i have not checked the o2 sensor yet so i guess thats the next item to check before i start replacing anything. george
03-18-2008, 05:39 PM
problem solved
i pulled the fuel rails, had the injectors cleaned, cleaned all contacts, and now it idles perfect, even cold. i will for now put away the lighter fluid i threatened it with. thanks for all the responses. george
