02-29-2008, 04:02 PM
This home boy whipped by daughter's 164
Happy Hour here as I am whipped after changing out seized a/c compressor on Sara's 164B. I found one compressor piston swelled in cylinder bore and two metal reeds broken off on for suction (think chain saw 2-cycle engine design).
Fellow Alfisti (chapter prez) gave me his old compressor that only had a bad coil for clutch. I installed good coil, new shaft seal from tractor supply (Harold's Electric) in Walla Walla, WA and new clutch pulley bearing from Koyo USA in Memphis. I may have to purge system, install new receiver dryer and expansion valve to be safe (only money).
Sara has learned who to drive 93L 5-speed since her A/T was down for seized compressor. Amazing what desire for non-parental mobility (aka taxi service) can do.
I did Sara's alternator regulator, too as brushes were worn badly.
Will test drive tomorrow if I get time. State inspection and tags run out tonight. Always something more to do.
Fellow Alfisti have a nice weekend!
Virginia Beach, VA
sdpatchin@aroc-usa.org
02-29-2008, 09:31 PM
Member
Thanks for the pictures. Appreciate it.
95 164LS Manual
16" European Alfa Wheels
European Headlights
Goats LCD
Jason's aluminum radiator
Stebro Exhaust
02-29-2008, 10:16 PM
I once had a compressor split the casing 3/4 of the way around.
Richard2
1991 164B Silver Daily Driver
03-01-2008, 06:41 AM
Who makes that?
Hey Steve..........can you be my Dad??
Thanks for the write up and pics!
Mark in Kentucky
92 164 S (Hers)
86 Spider (Mine)
76 Alfetta GT (Unclaimed)
Alfa National 2008 Track Photos:
http://msmithphoto.smugmug.com/
03-01-2008, 06:52 AM
Don't do it Steve!! He'll drink all your booze!!
I'm getting ready to go to the shop and align the 164 AFTER I remove the stupid poly bushing From IAP that don't fit. Going back to stock. It never seems to end with the stupid little things. Can you imagine what it would cost if you had to pay someone to do all this stuff?
I hope that when it comes time for her to leave the nest she'll find someone who is as handy as you or you'll be fixing more cars.
Paul
The meek shall inherit the rear view mirror.
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
79 Alfetta GTV(smooshed and ground up)
03-01-2008, 07:42 AM
Am I to young to be your dad or are you to old to be my son?
Virginia Beach, VA
03-01-2008, 07:49 AM
Resting up after back bender day.
Paul
I am too fast for him to drink all my booze.
I, also, am going back to stock lower suspension arms. I got a new OEM set from Difatta recently that I was going to put on my daughter's car but her car's control arm bushings were still fine.
I have been running front and rear poly bushings on my lower front control arms for about 5 or 6 years but the conditions of the roads around here are getting so bad my teeth rattle. After driving Rosso and Quik Silver so much Originale will be going back to being truly originale at least on suspension arms.
Did you see the ebay listing for a 3 pak deal in Orlando all running?
See my post on it.
Virginia Beach, VA
03-01-2008, 07:52 AM
Who makes that?
See my post on it.
SOLD........to gprocket up in Michigan.
Poly is great on my Spider, I guess from the feedback I'm getting from gt601 and others the 164 will remain stock.
Mark in Kentucky
92 164 S (Hers)
86 Spider (Mine)
03-01-2008, 10:55 AM
I can't even imagine what the wife would do to me if she found out that I bought 3 more Alfas. I would be dead! I guess I better get off my butt and finally head to the shop.
Paul
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
03-26-2008, 07:00 PM
Converted to R134a
Well, nice day for it so I removed hoses, condensor, etc today and purged evaporator, condensor, and hoses with a/c cleaning solution and compressed air, Replaced expansion valve, receiver dryer and removed old R12 valve cores and installed NAPA R134a low and high pressure adapters.
I had already replaced compressor with a good one that had new shaft seal, clutch pulley bearing, and 6oz of ester oil.
Installed new green orings on fittings and hooked up everything, pulled vacumn on system. Then I charged sytems with 4 cans of freon and one can of dye. I got 35F air out of dash and proper low and high side pressures. so it looks like system a go for summer ahead.
Virginia Beach, VA
Reason: added more info
03-26-2008, 07:21 PM
I have been very happy with my 134 conversion on the 164. Now that I have a vacuum pump and everything I need, I will have to do the same to the old 240. Volvo sells a 134 conversion kit at a reasonable price, that will make that conversion a little easier than the 164 was, fortunately. Evaporator, receiver/dryer, main A/C hose with valve, exp. valve, complete o-ring kit, oil and decals for ~$285.
Charles
'91 164L 5 speed 177k and counting  Chattanooga, TN
'89 240DL Sedan "The Brick"
03-27-2008, 11:38 AM
Paul
She's so lucky to have a Dad like you! I found out what it cost to "pay someone to do that stuff" right from the get go. It was well worth it, but after 30 years of exotic machinery, I finally went Lexus. Now I have to find my drama elsewhere. With the money that I save on Alfa repairs, I can afford to do that, but I still miss the tempermental diva!
KayGotz
03-27-2008, 01:32 PM
I remember that so well. I traded a well worn 1980 264 cu in V8 Chevy El Camino even for a 86 GTV6 in 1999 from a car dealer. Car was brokered at Auto auction, etc but I tracked it back to second owner who had spent a ton of money on it. He said he finally sold it to get a Miata WITH A WARRANTY!
Virginia Beach, VA
03-27-2008, 04:07 PM
Yep...It's like being married to a sex symbol....Exciting, entertaining and beautiful, but after years of drama, a predictable engineer-type starts looking real attractive.
Now, I just check out the Alfas at car shows, then go home in the Lexus, knowing that it will get me there in time for dinner!
KayGotz
03-27-2008, 06:32 PM
Reliability is soooo boring! Actually my 164 has been a very reliable mount, if it were not I would have sold it long ago. Sometimes you just have to invest deeply, the return on your investment is always worth it.
