Fuse Panel Removal Fiasco - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 03-19-2017, 12:03 PM Thread Starter
AndyG's Avatar
Hey everyone, I'm trying to replace the clutch master cylinder (or the clutch pump) as Alfa calls it, but I can't see any feasible way to remove the knee protection/fuse panel. I've gotten the left side and right side hinge screws removed but the right side is held in by pop rivets??? I wish it was easy as the book says "remove panel." Any tips?
AndyG is offline
post #2 of 5 (permalink) Old 03-19-2017, 12:11 PM
jc96's Avatar
maybe the US version is different but on ours, there is no need to remove the panel or the door or anything fuse related. 3rd pic down is just visible the fuse panel door in the up position and tucked in back, the cylinder
clutch hydraulics replacement
ciao, chris
Maintaining my tenuous strain on reality.
89 164 2l Twin Spark, 2011 Tonka Dump
Recently added: an 89 75 (Milano) 1.6 litre w/44K on the klok.
Past loves:
79 Alfetta GTV w/Spica, my 1st Alfa
An 88 Graduate. Not really love but interesting nonetheless.
A 68 BMW 1602 - man do I regret letting that one go!
79 Scirroco, ex plowed into an illegally parked house with it...
jc96 is offline
post #3 of 5 (permalink) Old 03-19-2017, 12:19 PM Thread Starter
AndyG's Avatar
Chris, the panel really only needs to be removed because it's in the way and reduces your wiggle room to almost zero. You can still see and kind of get to the MC. Thanks for the link to your post though.
AndyG is offline
post #4 of 5 (permalink) Old 03-19-2017, 12:26 PM
jc96's Avatar
sure, good luck. It's not that bad a job. Or... I'm just a glutton for punishment. ciao, chris
Past loves:
jc96 is offline
post #5 of 5 (permalink) Old 03-19-2017, 01:23 PM
Alfisto Steve's Avatar
Tips or replacing 164 clutch master cylinder under dash
Andy I have never removed fuse panel access panel (knees protection panel) to change a clutch master cylinder (m/c) which is called clutch pump in shop manual page 12-4.
AND do STEP ONE by sucking out brake fluid from brake reservoir to level below clutch m/c supply hose pick up fluid port for the clutch master cylinder which is higher than the brake master cylinder two hose ports.
Steps 7-8 on page 12-5 are bogus steps. Cross them out they do not pertain to clutch master cylinder removal.
However, I do remove the driver's seat so I can lay down on my back to work under the dash.
If you do need to remove knees protection panel to do the job, I guess you will have to drill out pop rivets where it attaches to side next to center console panel.
Looks like four screws holding the two hinges under fuse panel area are hidden by fuse panel box and it is in the way to get screwdriver on them. But you say you got those four screws out right?
Do protect the carpet with a fluid proof catch mat to catch fluid.
Virginia Beach, VA
My Maintenance Sticky:
Daily drivers: USA models - 1991 164S Black Beauty II ALFISTO;
Daughter's current ride: BB1 my 164L and Her Granddads 2002 Ford Taurus is back up.
New parts hauler but not car hauler 2004 Jeep Grand Cherokee Overland 4.7L H.O. V-8
Needing TLC non-blackbeast the 93 164L
Alfisto Steve is offline
