ball joint - Page 2 - Alfa Romeo Bulletin Board & Forums
 2Likes
post #16 of 28 (permalink) Old 03-11-2017, 11:10 PM
Bored Member
jc96's Avatar
ahhhh, I don't have ABS so I don't have the ABS ring Mr Del. I use that tool for alot of different things around the joint here. In my case, IIRC, there is only one direction to attack the ball joint but once attacked, it succumbs. ciao, chris
add: rereading, it sounds like you have the joint disconnected from the arm already. I find it easier to seperate the joint and knuckle first then separate from the arm. But my set up might allow this whereas yours doesn't
Maintaining my tenuous strain on reality.
89 164 2l Twin Spark, 2011 Tonka Dump
Recently added: an 89 75 (Milano) 1.6 litre w/44K on the klok.
Past loves:
79 Alfetta GTV w/Spica, my 1st Alfa
An 88 Graduate. Not really love but interesting nonetheless.
A 68 BMW 1602 - man do I regret letting that one go!
79 Scirroco, ex plowed into an illegally parked house with it...
jc96 is online now
post #17 of 28 (permalink) Old 03-11-2017, 11:40 PM
Evgeny 164's Avatar
Yes, it's a question !! Under the arm or above the arm. On my car - under. And so it was always, the car was bought new from the dealer. But on all Fiat Croma and early 164, which I repaired, it stood on top.
For removal use a fork and a hammer.
Alfetta 2.0 ,76 Ex / Alfa 75 2.0 TS,91 Ex
Alfa 164 3.0 24V Super,95 / Alfa MITO 1.4 ,09
Evgeny 164 is offline
post #18 of 28 (permalink) Old 03-12-2017, 04:46 AM
I really can't remember what I use on the ball joint, but do it still connected to the arm. I've got both the heavy black HF tool and a pickle fork. When one doesn't work, I quickly switch to the other.
Richard2 is online now
post #19 of 28 (permalink) Old 03-14-2017, 08:40 AM Thread Starter
I checked my three 1993 164L's, the ball joints are all mounted on the underside of the A-arm, I think at least two are the original ball joints. However, Jason does provide some convincing evidence that they should go on the topside of the A-arm. Functionally I dont think it matters much, but as I said earlier, topside mounting would avoid pinching the boot.
Rick1803 is offline
post #20 of 28 (permalink) Old 03-14-2017, 09:57 AM
pinino's Avatar
" topside mounting would avoid pinching the boot."
This may be precisely the reason why the ball joint was mounted—at the factory—in either position, it depended on the batch of ball joints that they currently were using, some may have had fat boots, others slim.
white '92 164 S (67K)
pinino is online now
post #21 of 28 (permalink) Old 03-14-2017, 10:02 AM
Bored Member
jc96's Avatar
you know, living in Italy, it could be they did it however they felt like at any given time. Or sometimes it was after wine break or really who knows.... stuff here follows little orderly logic most of the time. ciao, chris
Alfissimo Int. likes this.
Past loves:
jc96 is online now
post #22 of 28 (permalink) Old 03-14-2017, 10:22 AM
Del
I wonder, are there any with ball joints mounted on top from the factory? Sounds like most if not all came with them on the bottom.
Del
Seattle
previously owned since 1964:
Del is online now
post #23 of 28 (permalink) Old 03-14-2017, 11:10 AM
Bored Member
jc96's Avatar
I'd also wonder, if they were supplied by an outside vendor or vendors.... ciao, chris
Past loves:
jc96 is online now
post #24 of 28 (permalink) Old 03-15-2017, 09:16 AM
Alfissimo Int.'s Avatar
Some comparisons. Far right is OEM TRW (NOS) ball joint. Other 2 are not FRAP! One made in Italy and one made in UK.
Jason Minos
Tel:+1 928-526-0549
e-mail: contact via website form please
Alfissimo Int. is offline
post #25 of 28 (permalink) Old 03-15-2017, 09:31 AM
I think it is one of those things alfa does like Chris mentions. So many strange things came out of Alfa.
Looking at parts catalog too, looks as though the ball joint should be on top, otherwise my thinking would place the ball joint under the control arm as to be in proper location.
Jason Minos
Tel:+1 928-526-0549
post #26 of 28 (permalink) Old 03-15-2017, 10:36 PM
Evgeny 164's Avatar
Pictures can not be trusted.
Part catalog MOOG - is clearly visible from below.
post #27 of 28 (permalink) Old 03-15-2017, 10:55 PM
Evgeny 164's Avatar
Part catalog SIR - from the top
post #28 of 28 (permalink) Old 03-15-2017, 11:13 PM
Evgeny 164's Avatar
Under
Alfa Romeo 164/SUPER ATTACHMENT FRONT
VEMA-top
I agree with Chris.
Replace with
