Wanted Airbag Clock Spring - Alfa Romeo Bulletin Board & Forums
post #1 of 15 (permalink) Old 03-08-2017, 08:07 PM Thread Starter
Jim G's Avatar
I need an airbag clock spring. A bad one will work. Even one that has deployed and is half melted.
I need the 2 bigger terminals that connect to the car harness and at least a couple of inches of wire. Not to the airbag.
I'm trying to repair a Alfa factory airbag tester that someone cut the 2 bigger terminals off for some reason.
Willing to pay for shipping and something for the clock spring if need be.
I just got 2 more.
Jim G is online now
post #2 of 15 (permalink) Old 03-09-2017, 10:33 PM
Lazizza's Avatar
Does this look correct? It's the wire that connects from the clock spring to the airbag.
Lazizza is offline
post #3 of 15 (permalink) Old 03-10-2017, 04:52 AM
Alfisto Steve's Avatar
Jim I have one with chassis end wire in good shape send me a PM with address.
Virginia Beach, VA
My Maintenance Sticky:
Daily drivers: USA models - 1991 164S Black Beauty II ALFISTO;
Daughter's current ride: BB1 my 164L and Her Granddads 2002 Ford Taurus is back up.
New parts hauler but not car hauler 2004 Jeep Grand Cherokee Overland 4.7L H.O. V-8
Needing TLC non-blackbeast the 93 164L
Alfisto Steve is offline
post #4 of 15 (permalink) Old 03-10-2017, 05:22 AM Thread Starter
Jim G's Avatar
Thanks. But its the other end I need.
I just got 2 more.
Jim G is online now
post #5 of 15 (permalink) Old 03-10-2017, 08:27 AM
Lazizza's Avatar
Does anyone know if the airbag clock spring out of the 164 is interchangeable with other makes/models? I'm looking to replace the whole unit.
Lazizza is offline
post #6 of 15 (permalink) Old 03-11-2017, 05:03 PM
pinino's Avatar
Not to my knowledge, but the series I and series II US-market 164 clock springs are the same. It's basically a function of the steering wheel/airbag package, both series use Kolbenschmidt-Magna steering wheels with Bayern Chemie airbags. Alfa before and after tend to have TVR.
white '92 164 S (67K)
pinino is offline
post #7 of 15 (permalink) Old 03-13-2017, 06:11 AM
Roadtrip's Avatar
Location: Rapid City SD, Black Hills of South Dakota, Queens NY
Are you sure the clockspring is bad? To test, disconnect both ends from the car wire harness and the airbag squib unit. Then jumper the airbag end with a paperclip and then test continuity at the wire harness end. If the spring tension has been released inadvertently, it can be reset.
If you're getting a code 35 (open circuit) fault code, it may be a bad airbag squib itself. That's what happened to me, although that code might logically point to a bad clockspring. If you are getting a code 35 (open circuit) or a code 36 (bad airbag squib), disconnect the clockspring wire to the airbag and substitute in a 2 ohm (NOT 2k ohm) resistor in the clockspring connector, clear codes and see if it faults again.
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #8 of 15 (permalink) Old 03-14-2017, 11:21 PM
Lazizza's Avatar
Thanks for the detailed rundown on testing the clock spring.
The airbag was replaced years ago (after being deployed by the previous owner) and the mechanic at the time never fixed the wiring. The connector that attaches to the airbag from the clock spring was fried and the mechanic just taped a new connector to the inside of the airbag housing without soldering it to the existing wires running from the clock spring. I am looking to change out the entire clock spring (connectors and all) and not have to worry about soldering wires that connect to an item as important as the airbag. This is my first time dealing with this, not even sure if I'm thinking it out clearly.
Lazizza is offline
post #9 of 15 (permalink) Old 03-15-2017, 12:49 AM Thread Starter
Jim G's Avatar
You will need the airbag computer also. As airbag deployment sets a permeant fault code that can not be cleared. With a fried clockspring I doubt they replaced the computer. I would also guess if the airbag light is not coming on they took the bulb out.
You also might need to 2 front sensors.
I just got 2 more.
Jim G is online now
post #10 of 15 (permalink) Old 03-15-2017, 03:36 AM
Jim I sent you a PM couple days ago on that melted clock spring I have that has good chassis wiring end did you see it?
Virginia Beach, VA
post #11 of 15 (permalink) Old 03-15-2017, 05:48 AM Thread Starter
Jim G's Avatar
I sent another PM. There is no record of the first PM I sent. I guess it disappeared into cyber space.
I just got 2 more.
Jim G is online now
post #12 of 15 (permalink) Old 03-15-2017, 06:15 AM
Roadtrip's Avatar
Call Larry at APE. He should have a clockspring and R22 control unit laying around.
Also go to the For Sale/Wanted topic and do a search "Parting out." There are several cars listed as being parted out in the last 9 months or so. 67Ossodisepia has one listed back in October I think.
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #13 of 15 (permalink) Old 03-16-2017, 04:42 PM
Lazizza's Avatar
The service records that were passed down to me are mostly handwritten invoices. The actual worked performed is difficult to decipher, not to mention it was done back in 2001. Currently, the airbag light flashes upon startup then remains lit.
Lazizza is offline
post #14 of 15 (permalink) Old 03-16-2017, 04:53 PM
Lazizza's Avatar
Thanks for the tip. I just Googled APE (never heard of it) and got Alfa Parts Exchange. I really need to get acquainted with the best sources for parts. Clearly, I can't rely on just one or two sources like with a traditional vehicle.
Lazizza is offline
post #15 of 15 (permalink) Old 03-16-2017, 05:54 PM
Roadtrip's Avatar
You should pull the fault codes from the airbag computer before you do anything.
John Stewart
74 Spider
91 164S
Roadtrip is offline
