when it rains it pours! - Alfa Romeo Bulletin Board & Forums
 6Likes
post #1 of 37 (permalink) Old 02-07-2017, 10:45 AM Thread Starter
goats's Avatar
Got everything buttoned up, turned the crank over by hand a few times, recheck tensioner gap, etc. Start car and its blissfully quiet on the belt side of the motor. Unfortunately there is a horrific tapping from the driver side, sounds like #3 on the top end, and obvious miss. Pretty sure its not coil arc as it sounds way more metallic. I am always careful about stuff dropping into intakes/etc and as always as soon as I removed the runner I stuffed paper towel in the intakes there. Likewise when I removed spark plugs I looked first ; then blasted air to clear out any residue. Unfortunately it sounds like either a broken spring ; dropped valve, or something in the combustion chamber there that doesn't belong. Bummer
I'll give it a rest; remove plenum once again and try a borescope and/or compression test. Maybe this weekend,,,,
Between this; work; kids hockey; spider ; GTV; family I'm not sure when I'll get to it. Don't really relish pulling the rear head on this ....
sheesh! Patience is the one thing that I need continual help on!
goats
74 GTV with 10548's and Ingram pump --speedo been around at least twice -- [B]needs new oil rings[/B]!
1995 LS Q runners Auto Green/tan [B]230K[/B] 100% LCD paint absolutely SHOT!
1995 LS 5 speed Green /tan 48K Q runners squadra chip 100 % LCD -- nice tight car
Misc parts laying around for 24V and 2Liter- always need more it seems
2004 Tacoma 4 door TRD (wifes car/kid hauler)- 172K
Mission Vsi, Mission Mod 2, - 20+ years of hockey on these!
radio flyer- rusty from disuse!
goats is online now
post #2 of 37 (permalink) Old 02-07-2017, 04:43 PM
horsewidower's Avatar
I hear you.
I walked away from the LS a couple of weeks ago because I was about to reach for a gallon of gas and a match.
I'm ready to start beating my head against it, again.
brianthegood likes this.
STILL learning.
But wait there's more: View my 164LS thread:
horsewidower is online now
post #3 of 37 (permalink) Old 02-07-2017, 05:28 PM
Push hard and live
DPeterson3's Avatar
What's the difference between a 164 and an Alfasud?
The 164 burns longer.
Don P
Carson City, NV
Past Alfas...
Current Alfas
And past...
1946 Luscombe 8A
And present...
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #4 of 37 (permalink) Old 02-07-2017, 05:41 PM
LMAO
probably true
STILL learning.
post #5 of 37 (permalink) Old 02-07-2017, 05:59 PM
Haven't we all been there so many times....
Worse experience was over Christmas when I thought my Honda Odyssey TBelt service would be a cakewalk.
Four days later, two lost bolts....have no idea where they went in there....pulled it apart again because the YouTube instructional video left out a few vital steps.
Other videos only dealt with tear down and assumed one would reassemble backwards which really does not work.
I now understand why Ody dealer TBelt service runs around $1400.00.....but glad I did it as I now know what goes on inside there.
It also cost me less than $300.00 for belts, water pump, coolant, pulleys etc.....
I appreciate so much the AlfaBB, CARDISC, EPER and the Digest and of course not least of all Alfisto, Alfissimo, Pinino, Roadtrip, Chazzy, Del, Goats and so many other experts on this Forum who make owning an Alfa a pleasure.
Ta,
Neville.
goats likes this.
donliznev is offline
post #6 of 37 (permalink) Old 02-07-2017, 10:55 PM Thread Starter
goats's Avatar
OK more tonight -- removed rear plenum again and did compression test (cold) on ALL cylinders. 200 +/- 10 on all, and importantly NO BAD NOISE when cranking with motronic relay pulled during compression test. took out all plugs and borescoped -- saw nothing unusual, ran my magnet down there with nothing coming back up. Put back together and fired up -- NO BAD NOISE but a clear misfire. After a while as the car got hotter, the tap-tap-tap returned. Still a misfire.
and a mystery. Might I have a bad plug? They are all brand new--- maybe a bad coil again? By the way I rang out the entire upper harness with no issues noted. And I am 99% sure the timing is spot on. I can check again I suppose........
At least, at this time, seems like no 'mechanical ' issue maybe but ???
goats
goats is online now
post #7 of 37 (permalink) Old 02-08-2017, 04:44 AM
Alfisto Steve's Avatar
You got a sticky lifter?
horsewidower likes this.
Virginia Beach, VA
My Maintenance Sticky:
Daily drivers: USA models - 1991 164S Black Beauty II ALFISTO;
Daughter's current ride: BB1 my 164L and Her Granddads 2002 Ford Taurus is back up.
New parts hauler but not car hauler 2004 Jeep Grand Cherokee Overland 4.7L H.O. V-8
Needing TLC non-blackbeast the 93 164L
Alfisto Steve is offline
post #8 of 37 (permalink) Old 02-08-2017, 10:54 PM Thread Starter
goats's Avatar
OK here's the skinny -- and I still cant believe it
As I said I checked compression, rechecked timing, etc and when I got everything back together its still got a horrible miss and very loud clicking. When I just did compression, no noise.
When I R/R tbelt, I put in new plugs PFR6B and a new set of coils in the back. I usually do this if I have coils in stock -- which I did; a new set of 6. I Always have plugs in stock, got em from Rock Auto on sale a few years ago.
Long story short -- one each bad plug and bad coil -- BOTH NEW! Plug has hairline crack in insulator that you can't see until it arcs over. Coil -- primary side was good, but high voltage side has intermittent OPEN which led to no spark, and when it did spark, it arced badly from the insulator-- THIS IS A BRAND NEW COIL I've had in stock for 5+ years. Note -- Coil and plug NOT MATED on back bank.
I knew the ignition modules were good and I did ring out the upper harness on the bench during the course of tbelt change. So the combination of bad plug (causing the miss) and bad coil (causing a miss as well as a huge arc which sounds atypical for an arcing coil , it is the source of the bad tapping sound) caused me to R/R rear plenum at least 5 times, maybe 6 but I FINALLY found them both and got it right. Motor is whisper quiet now at idle and steady as a rock, just went for a little Italian tuneup and I am back in business.
Total here -- new tbelt idler, new tbelt tensioner bearing, new serp belt idler, new tbelt, 6 new spark plug well gaskets, and I will say 12 hours of tbelt change time, and 12 hours troubleshooting this ignition mess.
Moral of the story-- just cause its new doesn't mean its good. I'm good to go belt wise another 30K miles.
horsewidower, Allan and CathalICCI like this.
goats
goats is online now
post #9 of 37 (permalink) Old 02-27-2017, 09:36 PM
It looks like I may have a very similar problem on my 24V 164. I just completed a timing belt change. One of the valve lifters had developed some noise (the car had been off the road for various reasons for 3 months) on completion of the job. I thought I'd do some gentle revving to 3000 rpm on a warmed up engine to see if I could rectify it, after 5 cycles over several minutes I went to drive home and hey presto I'm only on 5 cylinders. The car then intermittently ran smooth and rough for the next 10 minutes. My first worry was that the new timing belt had slipped a tooth, but I know the tensioner and all pulleys were good and we spent a great deal of time getting the tension right. We also used cam locks so I know the alignment of the cams was perfect. I also figure given the car intermittently runs on 6 then 5 cylinders it's more likely to be a coil / plug / short problem.
My first question is this... is it safe to disconnect the injectors sequentially to narrow down the cylinder affected? I've read this is fine but my retired mechanic neighbour is worried it might damage the ECU.
It seems the problem is on the back row of three cylinders, ie under the plenum so it will have to come off again on Friday. We'll do a compression test at that time and then check the resistance on the coils and clean everything out, plus add a good coating of dielectric grease around the coils. I appreciate the coils may test normal even if there is a fault given it intermittently runs smooth. I'll make sure the connectors under the air box get another clean - I last did this a year ago.
Do any of you have any other questions? We always check for air leaks on reassembly and I know I have none. I'm pretty sure the AFM is okay also. The plugs are NGK iridiums and have done less than 5000 miles.
1993 164QV
DanNZ is offline
post #10 of 37 (permalink) Old 02-27-2017, 10:12 PM
Del
"I'll make sure the connectors under the air box get another clean"
use the grease there as well.
Del
Seattle
previously owned since 1964:
Del is online now
post #11 of 37 (permalink) Old 02-28-2017, 04:27 AM Thread Starter
goats's Avatar
Yes, you may have shorted/ intermittent coil. Here's what I did in more detail-- let the car run ( will run in even 4 cylinders but not well) and first, use long screwdriver up to your ear other end on injectors. Check em all for click click. Then take off front cover and one by one, remove connector to spark coil. Should hear motor beat miss. Verify fronts as good in this fashion. Then once you know fronts are good, remove rear plenum and access back. Swap both coils and plugs front to back ( i.e. 1 goes to 4, 2 to 5 etc). Swap as a matched pair coil and plug. You might take out upper harness and ring it out ( coil inputs only). You can do it in-situ as well, from big round connector to each coil plug. Make sure when u swap that all gunk is cleaned out of spark plug well. NO DIELECTRIC GREASE YET. So now the 'known good' fronts are in the rear and vice versa. Repeat the drill. You will find the bad actor. 90+ percent it's not a lifter making that noise.
Once you do this ( hopefully once but in my case was 5 times or so) u will find the bad actor. Make sure the upper harness ground ( acorn nut just fore of big round black connector) is tight with three washers.
Once the car is running well, and only then, if you are so inclined, apply tiny amounts of dielectric grease wherever you please. Tiny amounts.
Dielectric grease itself will not fix this problem and may well interfere with your troubleshooting. It's use as a prophylactic against moisture is widely documented. But until you find and fix the underlying issue do not apply prophylaxis measures!
I'm pretty much a stickler on this and have refused to work on cars before where this stuff was all over the place. Just makes the "finding and fixing" three times harder.
goats is online now
post #12 of 37 (permalink) Old 02-28-2017, 08:55 AM
Del
It's a lot cleaner to just line the coils with Mylar sheet as I did. I for one use that grease only on cleaned connections.
Del
Seattle
Del is online now
post #13 of 37 (permalink) Old 03-02-2017, 01:33 AM
Thanks very much for your advice Goats, it is greatly appreciated.
Would sequentially unplugging the injectors serve the same purpose? I'm a little worried - I tried disconnecting each injector last night and the engine ran even rougher with each one disconnected. I figure if the problem is related to one cylinder and coil pack then disconnecting the injector to the problem cylinder should have resulted in no change on that particular disconnection. I'm paranoid now that maybe the cambelt did skip a tooth after all! I'm weighing up starting the engine again and listening with the screwdriver "stethoscope" vs just removing all the cam covers and checking cam alignment with the cam locks.
1993 164QV
DanNZ is offline
post #14 of 37 (permalink) Old 03-02-2017, 03:30 AM Thread Starter
goats's Avatar
Dan, if you did remove power to each injector and the car started to run rough (er)with each sequentially removed, yes you've effectively done the same. Key question is though, in your earlier note you said that car would run good/ then bad. Was the car misfiring when you started your checks? Coil packs can be quite intermittent depending on lots of things including ambient humidity.
I'd do as your gut says. Pull the timing covers off the front and verify your timing marks on the pulleys.
If you did loosen the cam-to-pulley interface to get things to line up ,and even if not, it's possible ( but not super likely) that the cam pulley taper has slipped -- worst case scenario so don't worry about this yet.
Search for my thread Dusty Rhodes Hard Times, read it thru, and come back after running thru it.
Cheers bob
goats is online now
post #15 of 37 (permalink) Old 03-03-2017, 02:46 AM
Thanks for the additional sage advice.
I'd forgotten I had a brief period of smooth running after the problem started, so yes agree not the cambelt (thankfully).
We pulled the coil packs and plugs this morning and discovered the problem... At the same time as the timing belt change we did a coolant flush. I honestly don't think one had ever been done before, all sorts of crud came out. I removed both drainage plugs from the block (we made a cut down 22mm socket welded to a 1/4" extension to reach the rear one - several skinned knuckles later). Since this flush condensation had collected in all the back spark plug wells. The #1 plug had rust all over the contact with the coil pack. We cleaned everything out added (sparingly) dielectric grease and also added a local product called "Seal Well" to the new coolant. This was recommended by a local engine reconditioner. I should add we did a compression check and all was well.
The car now runs well. We'll see how things go over the next week.
Does anyone have experience of condensation in the spark plug wells on the 24v 164?
1993 164QV
DanNZ is offline
Replace with
