  #46 (permalink)
Old 01-28-2008, 11:55 AM
Scott in MN's Avatar
Scott in MN Scott in MN is online now
Originally Posted by BlackAlfa View Post
It looks like it is the hose going from the rear valve cover to the oil separator. This is a molded hose. If you use a straight hose, it will collapse at the bend. In a crunch, yes you can go to a parts store to see whether you can find a hose with a bend (19mm or 3/4" ID should be the size). You can even use a straight hose with a spring like device (that you can find in stores) to prevent the hose from collapsing. Also, keep in mind that if you use coolant hose they will not last long because they are not designed to resist oil!
I just replaced this hose on mine using a 3/4 in hydraulic hose and a nylon barbed 90 degree elbow, both from the local fleet farm store.
____________________________________________
Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?
  #47 (permalink)
Old 07-01-2008, 05:07 PM
jrreeve jrreeve is offline
Simple idea...verify everything that you replace, is indeed a known-good asset, even if it's new.
Bad plug wire going to the number 6 cylinder. Lesson learned...the hard way.
Rob
'91 164S
