  #16 (permalink)
Old 05-22-2007, 03:46 PM
ChazzyD's Avatar
ChazzyD ChazzyD is offline
Parts heading my way and the nearly unobtainable submersible fuel hose in my hand from O'Reilly's.
Charles
'91 164L 5 speed 179k and counting
Chattanooga, TN - Home of the new VDUB factory!
  #17 (permalink)
Old 05-22-2007, 03:54 PM
AlfaTango1's Avatar
AlfaTango1 AlfaTango1 is offline
but this one goes to 11..
Good ole Gates Belts and Hoses! I was a DM for them for a while and they have a good bit of obscure pieces, boss was a jerk but the company was cool.
currently: 1984 GTV6 (Sabrina) 1992 164L (Jill) 1992 164S (Kelly) 1989 Spider Veloce (Julie)
  #18 (permalink)
Old 05-22-2007, 07:57 PM
jontg428's Avatar
jontg428 jontg428 is offline
I tried the O=ring trick, one thing I would tell people to use are ones that are gas-proof, AC o-rings can do this. I tried standard o-rings and when I went back to redo the job the regular rubber o-rings were melted from the fuel. Maybe its our california gas that does it
  #19 (permalink)
Old 05-23-2007, 03:42 AM
Charles
Good Find Chazzy, now be sure to reuse those special hose clamps holding old hose on tank cover to get a good tight fit.
Virginia Beach, VA
sdpatchin@aroc-usa.org
  #20 (permalink)
Old 05-23-2007, 03:44 AM
I used the metal stato-seal washers with molded neoprene rubber this time. They should hold up OK. Got them from Home Depot.
Virginia Beach, VA
  #21 (permalink)
Old 05-23-2007, 08:15 PM
ChazzyD's Avatar
Not a completely wasted endeavor, this PM. Had a broken mounting strap tab on the basket and the pad was at the bottom of the tank and not attached to the basket. Short hose was original cloth covered one and was fine but it got replaced anyway. Not too much junk in the basket but it got cleaned out as well. One more thing soon to check off the list. O, and the basket filter just pops out of the basket bowl, took me a little while to figure that out, kept trying to find a way to get to the screws. Yes, and I never get rid of the original Oetinger style hose clamps whenever working on this car! Everyone should obtain the tool to put those back on.
Charles
  #22 (permalink)
Old 05-25-2007, 07:05 PM
ChazzyD's Avatar
Feeling like the car runs even better, maybe that short hose did have a slight leakdown issue. Not a fun task but done now.
Charles
  #23 (permalink)
Old 06-06-2007, 07:23 PM
Alvis III's Avatar
Alvis III Alvis III is offline
smell
This info is great !!!!!!
  #24 (permalink)
Old 06-07-2007, 05:52 PM
ChazzyD's Avatar
After driving the car for several more days, I thought I would add that my car starts much better. I used to have to jab the gas pedal a bit when I went to start the car or it would require a second try to start it. It starts without having to do this anymore! SWEET! I definitely had a leakdown issue even with no visible split in the hose, I even disected the old short hose with a razor blade and no splitsbut tiny cracks and generally hardened rubber, so I can see how it (apparently) was not sealing well.
Charles
  #25 (permalink)
Old 05-03-2008, 03:31 PM
treborblack's Avatar
treborblack treborblack is offline
What size seals do i need please?
Driving a September 1996 super like i stole it
  #26 (permalink)
Old 05-03-2008, 05:01 PM
For what? Do you have a USA steel tank with bolts holding pump tank cover and gauge sender or Euro plastic tank with lock rings?
Virginia Beach, VA
  #27 (permalink)
Old 05-05-2008, 02:43 PM
sorry Steve i meant for the sender and pump. but it is a euro tank
Anyway on inspection it is the 90 degree elbows that have cracked. somebody elsewhere has suggested running a soldering iron over them. what do you make of that?
as i really do not want to drop the tank if it can be avoided
  #28 (permalink)
Old 05-05-2008, 06:48 PM
What? I don't think so! Might be a bit dangerous.
Are you talking about one of three rubber elbows in 60563155 vent line assembly that hook to top of tank in three different places and hidden when tank installed?
Or are you talking about fuel pressure line 60605732 and return line 60605733 "plastic" elbows going into fuel pump tank cover?
Virginia Beach, VA
