Just put in my used door handle today and here are some tips. Be sure to remove any screws you see first. The first portion of the arm rest (the one that has the mirror control in it) slides forward to remove (after you remove a small self tapping screw behind the interior door handle). This is the smaller part of the rest, the one you do not put your arm on. There is another screw behind this panel after you remove it, it is much bigger, so get that one undone and out of the way. Undo all the screws to the lower panel and remove the wires that light up ground when you open the door. Then remove the lower panel, and a few big screws underneath the arm rest. Work the upper one to give you just enough room to get to the nuts (8mm) that hold the door handle in place (read pull the panel out a bit). It is a tight spot to work in, and a pain in the neck. There is a clip that hold the upper portion of the arm rest to the door, but I could not get that loose for the life of me so I just worked in the confined area I had. The rest is just plain trying to get the nuts off, then putting it all back together. Do not bother removing the plastic panel behind the handle, it is a waste of time! Most of this job requires feeling with your hands to figure out just where these parts go. The only part you need to be concerned about is a little rod that goes from the handle to that actuator on the latch mechanism. Its trial and error. I recommend connecting the rod to the handle first, then guiding it to the mechanism, easier said then done. After all of this, screw everything back together and enjoy your new handle *(took me about 3 hours for a first time job). Now if I only would have got a new one........ Part 2 when this used one fails!
