Old 03-28-2007, 08:03 PM
sainato59 sainato59 is offline
95LS CRAZY problem..HELP
ok so lately the 4-way flashers have been turning on by themselves and if i do not catch it in time, it kills the battery...someone help meee...
Bad relay?
Bad 4-way switch?
a short somewhere?
bad LCD panel?
any one ever experience this?
any one know what's going on?
any imput is appreciated...thanks ahead of time guys
1973 GTV 2000(Red)
1974 GTV 2000(Burgundy)
1978 Alfetta Sport Sedan(Dark Metallic Red/Burgundy)
Daily Drivers:
1988 Milano Verde(my son's-Black)
1995 164 LS(Black)
At my House in Italy:
2001 156 1.8 Twin Spark(Black)
Parts cars, let me know if you need any parts:
1979 Alfetta Coupe
1987 Milano Gold
Old 03-28-2007, 09:06 PM
goats goats is offline
Bad LCD Controller
Hi
I;ve repaired quite a few of these. There are a series of solder joints in the Climate Control Module that eventually go bad (yet another bell-ringer from Bosch). I can fix it for you --PM me.
goats
74 GTV with 10548's and Ingram pump speedo been around at least twice!
1995 LS Q runners squadra chip Auto Green/tan 157K 100% LCD
1995 LS 5 speed Green /tan 34K Q runners 100 % LCD!
1995 LS 5 Speed black/black (bent up -and being devoured for parts -- will be a carcass in one month!)
2004 Tacoma 4 door TRD (wifes car/kid hauler)
Mission Vsi, Mission Mod 2, Mission D2
radio flyer
Old 08-27-2007, 01:58 AM
GBABINI GBABINI is offline
Please Help Same 4 Emergency Light Problem
Dear Alfista
i bought my first alfa,a 95 164 LS a month ago,
it is a very nice car but it started doing the same problem you posted,flashing lights going on crazily ...my mechanic first disconnetted the alarm,then removed the relay for all the blinkers! (we are waiting for the emergency blinkers new button as he believes that the fact that is located below the air conditioning vent caused to expand and shrink too much,as i live in las vegas)
your help in how you solved the same problem will be greatly apprecciaated
ciao
gabriele
Old 08-27-2007, 08:29 AM
goatster goatster is offline
You need to send it to me for repair
please PM me. This is repairable by me in my shop with my specialized equipment. It is the CLimate Control Module that has a problem (and its not the switches) and I have repaired many of these. Do all your LCD segments work? send me a PM please
bob
Old 08-27-2007, 11:49 AM
Del Del is offline
Goats
I assume that if I have one of your rebuilt 94-95 modules, this problem has been fixed as well.
thanks,
Del
Seattle
89 Milano
91 164S
94 164LS (Q)
72 Morgan 27
Old 08-27-2007, 01:30 PM
Hi Del
A friend in UK figured out the 'intermittent flashers' thing about 2 years ago, he and I have traded fixes over the past few years. Since then, I have checked every unit that I have rebuilt/upgraded for the problem (as preventative). If I upgraded your module prior to 2 years ago (approx) you may have a latent issue-- but I doubt it. As usual with Alfa, it seems to be a 'bad batch" of solder joints and surface mount process. Unlike the display ribbon, its not a design failure but a lack of process control, and a quality failure.
bob
Old 08-27-2007, 05:01 PM
Del Del is offline
Ok, will keep that in mind. Had a Sony tv once which suffered from cold solder joints everywhere. It was common for the first of the big 32+ inch tube tv's, pre wide screen. The local tv repair guy said that the Sony's all would end up not working right due to poor workmanship and quality control. Can't get away from it it seems, no matter where the stuff is made.
Del
Seattle
89 Milano
91 164S
94 164LS (Q)
72 Morgan 27
Old 08-27-2007, 06:29 PM
Goats
thank you so much for the reply
i apologize for getting back to you so late but i just got back from work
my cell is 702-591-1422,i am really mechanically impaired so i have no idea even what the lcd is or how to disingage it and send it to you,i guess speaking in person is the best way
thanks a million
gabriele
