Old 02-11-2007, 01:51 PM
redbaron redbaron is offline
Motor mount replacement
I need to replace at least one of my motor mounts in the 164B, as it clunks when shifting and accellerating. My question is how do I figure out which ones I need to replace, and are they hard to do. The shop manual doesn't seem to mention a detailed proceedure, but rather refers to it in passing as part of engine removal...
--AaronAlfa---Mill Creek WA-----
91 164S (Engine & Parts for sale)
91 164L Auto (Parts for sale)
84 GTV6 (In the doghouse this week)
94 Audi V8 Quattro (Guzzles gas, but oh so comfy)
94 Nissan Skyline (Car speaks for itself)
03 Saab 93 Viggen (The reliable one)
Old 02-11-2007, 01:56 PM
Alfissimo Int.'s Avatar
Registered Alfa Addict
It usually is either the front passenger hydraulic, or top dog bone mount. Typically!
They are not tough to R&R.
But it could be a number of things as well. Could be suspension components as well.
Check it all out. Motor mounts are simple to check. Front is usually torn and oil all over it. Top is broken in the large and the small is torn/broken.
Easy to check is to move the motor and check for lots of play.
Hope that helps, that was the fast version!
jason
Jason Minos
<-GT Bertone, Spider, 75, GTV6, 164, all New models->.
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 02-11-2007, 02:23 PM
Usually when a motor mount clunks it is small one that upper link is attached to on rear head as rubber bushing has given up and it is metal to metal and engine will clunk when it moves back and forth.
Much easier to replace with a 3 piece poly bushing kit IAP 34061. http://www.international-auto.com/in...957594&noapp=1
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Old 02-11-2007, 05:49 PM
elite38868's Avatar
elite38868 elite38868 is offline
compratore di alfa
Send a message via AIM to elite38868
It's a PITA to do without a press. My neighbor has a 25 ton press, so I took it to him. I have a thread on that as well which I'm about to post a pic on.
Have you checked all the little exhaust hanger donuts for exhaust rubbage?
Sean
Alfa Romeo Association - Tour Director
www.alfaromeoassociation.org
92' 164S - Black
Old 02-11-2007, 07:03 PM
Only a pain if you try to install factory bushing. Much easier to go to poly bushing route on either end of upper engine mount by cutting out old ones.
Replacing "dog bone" engine bushings
Virginia Beach, VA
Old 02-11-2007, 07:19 PM
elite38868's Avatar
compratore di alfa
Steve, that's what I meant as far as getting the old ones out. I wonder how well the Alfa factory tool for doing the smaller one worked...
Sean
92' 164S - Black
Old 02-11-2007, 07:30 PM
That's why I cut through old bushing outer shell to relieve the pressed fit so you can get it out.
Virginia Beach, VA
