#16 (permalink)
Old 06-24-2008, 09:32 AM
Originally Posted by pavanbabut View Post
This time its not about locking up, but today morning all of a sudden I feel my steering became light. It still works, but there is no tightness that I feel all the time which gives more feedback.
Now its all light, and it takes little more rotation to turn the wheel. The only bad things about the rack is, the mount bushings are bad and the driver side boot is bad.
You better check those mount bushings you say are bad if rack moving in mounts that will give you light feel and more movement of wheel.
Virginia Beach, VA
sdpatchin@aroc-usa.org
  #17 (permalink)
Old 06-29-2008, 05:48 PM
pavanbabut's Avatar
pavanbabut pavanbabut is offline
Send a message via MSN to pavanbabut Send a message via Yahoo to pavanbabut
Here r the pics that I took on both end of the rack and they r not good... is there anything else I can replace while I am there, so that I can order all the parts at the same time??
1995 Alfa Romeo 164Q (136k)/5spd - Mr.Hottie
1993 Alfa Romeo 164L (150k+)/5spd - Mr.Dependable
1992 Subaru SVX (80k)/4EAT - #0211 - 4.44 Final Drive - My Baby
  #18 (permalink)
Old 06-29-2008, 06:20 PM
164 rack boots, TRE; mount
Boot kit for rack with oval boot 9943835 all parts marked A in picture
Check ball sockets for play inner tie rod ends (under boots) 9945565 L/H (driver's side), R/H 9945566 (hard to find) passenger side. You can use 9945565 both sides but may need spacer on passenger side.
Outer TRE 60511622 (2)
Rubber mount driver's side 82388352 ITEM 7 in second picture.
If passsenger side worn out you need to drill mounting clamp apart and make need mount from some rubber/neoprene flat stock/split piece of hose, etc.
If hoses are leaking or chaffed you need to replace them too. See my post on return or supply steering hoses.
Power Steering Leak
If pressure hoses you will need to have them made or buy new if possible.
Virginia Beach, VA
  #19 (permalink)
Old 06-30-2008, 08:35 AM
pavanbabut's Avatar
Thanks steve, looking at all those parts and their prices, do you think its better to get a reman rack for around the same amount from Jorgenauto and get new TREs rather than working on this rack?
-Pavan.
  #20 (permalink)
Old 06-30-2008, 08:46 AM
-Pavan.
It maybe a better call. Which car are you working on 12v or 24v? Just besure they send you a 5-sp not AT rack so you don't lose right turning radius.
Virginia Beach, VA
  #21 (permalink)
Old 06-30-2008, 10:16 AM
pavanbabut's Avatar
Its 12v which I use as daily driver, 24v has no problems and runs great [!!knock on wood!!] , expect less gas mileage than 12v (DUH!).
-Pavan
  #22 (permalink)
Old 06-30-2008, 10:47 PM
washout39 washout39 is offline
What are your powersteering flexible pipe lines like ?? Since if they are old they start breaking down and you start getting bits of rubber floating round in your powersteering system, this starts clagging up the system especially all those small pipes to the powersteering rack.
  #23 (permalink)
Old 06-30-2008, 10:56 PM
pavanbabut's Avatar
Not sure, since its r pretty much congested in there, I was not able to check them thoroughly unless I took the rack out which I havent done yet .
  #24 (permalink)
Old 07-14-2008, 08:30 AM
pavanbabut's Avatar
Is there an easy way or some technique to replace steering rack other than the one mentioned in service manual?? Is there any write-up on that??
thanks,
-Pavan
  #25 (permalink)
Old 07-14-2008, 10:17 AM
Alfissimo Int.'s Avatar
Registered Alfa Addict
thanks,
-Pavan
Not sure if there is a specific one but it goes like this.
Drain the fluid, undo all lines.
Remove driver side wheel and arch plastic shield.
Drop subframe to reach rear bolts, I use a shorty socket wrench and long 13mm socket to get to the front along with a ratchet 13mm wrench, easy.
Remove clamps, passenger side is clamped together so you need to chisel it off from the bottom bracket...usually. Not always the case if the rack has been done before.
Remove tie rod ends from hub.
R&R through driver side wheel wheel.
I think you can figure out any small details I may have left out.
Check inner tie rods as well.
Jason
Jason Minos
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
  #26 (permalink)
Old 07-17-2008, 08:15 AM
pavanbabut's Avatar
I havent lowered subframe before, could someone tell me what needs to be done to lower the subframe other than the bolts that hold the subframe??
thanks,
-Pavan
  #27 (permalink)
Old 07-17-2008, 01:18 PM
This is how I did it: Rosso Rescue Project Steering Rack Update
Virginia Beach, VA
  #28 (permalink)
Old 07-24-2008, 08:19 AM
pavanbabut's Avatar
Where can I get these gaskets (7) #10261150 from if I had to replace or do we need to replace them or can we reuse the old ones.
thanks,
-Pavan
  #29 (permalink)
Old 07-24-2008, 06:39 PM
thanks,
-Pavan
You should be able to reuse them as is but if they leak you can anneal them with a propane torch to soften them up again or try Di Fatta Brothers - Alfa Romeo and Fiat Parts Sales and Service , etc., BB vendors or local parts store.
Virginia Beach, VA
