10-16-2006, 11:31 AM
compratore di alfa
Speedo sensor
Hi guys,
What are the usual signs of the speedo sensor going out? Mine works so randomly and nothing effects it. I have checked the wiring and it's good.
Thanks!
10-16-2006, 03:41 PM
My speedo drops needle to peg once in awhile and then comes back after a bit and works for weeks on end before it does it again. Last winter on cold mornings it did it more often but since it works 99 44/100% of the time I haven't worried about it yet.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
10-16-2006, 05:00 PM
compratore di alfa
Hmmm, that's odd. See, mine isn't affected by road conditions or weather, it's just random. It works 8% of the time if I'm lucky. Should I try replacing? $80...
10-16-2006, 06:17 PM
It is only money. See troubleshooting procedure in wiring diagiams for it. You should have 12v in and about 3.5 or 5v out as I remember and they want you to test S model with car on lift in gear and measure voltage and/or wavelenght on a scope.
Virginia Beach, VA
10-16-2006, 07:46 PM
Location: The Universes, Commute between 11th Dimension and San Jose, CA, USA
A new speedometer sender solved my problem a long time ago.
Removal and installation speedometer sender is a bit tricky, and there isn't a lot of speace to work on. Don't over tighten.
Karl
10-17-2006, 04:44 PM
compratore di alfa
How tight should these be? Also, will any voltage come out without the moving, but the car turned on?
10-17-2006, 07:12 PM
It is a magnetic electric (sine wave signal?) generator turn by differential. A scope maybe able to pick up the signal but not measurable (too low average voltage) for multimeter. I don't know the torque specs, but just tight enough so it not come loose, It only grip a few very fine threads, so don't need to be too tight.
Karl
01-08-2007, 03:03 PM
compratore di alfa
Does anyone know if 60508215 is for manual or automatic?
01-08-2007, 04:00 PM
Registered Alfa Addict
60508215 is out of production, old number (K0/K2 catalogs 87-92 164/164 T)
7624310 is what you need ($60.00)
Jason
01-08-2007, 05:05 PM
Is that one JFK has in his Store? If price is right it should work OK.
Virginia Beach, VA
01-08-2007, 07:51 PM
compratore di alfa
I think so, I was just trying to determine if it was auto or manual...
