  #31 (permalink)
Old 04-13-2008, 07:27 PM
Craig's Avatar
Craig Craig is offline
75/Milano manuals for all
G'Day Paul,
Originally Posted by beatle_bayly View Post
Is there a valve in the ZF to regulate transmission fluid flow through the cooler (like an engine coolant thermostat) ???
That's what the plumbing diagram shows.
Craig,
1988 75 TS, 1989 164
  #32 (permalink)
Old 04-14-2008, 04:46 AM
Alfisto Steve's Avatar
Originally Posted by Craig View Post
G'Day Paul,
It is ON the front of tranny not IN it. Part of plumbing for oil cooler.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Rescue projects: Organ donor 91 Nero 164L w/AT, 91 "Old Blue" 164L w/AT
  #33 (permalink)
Old 04-14-2008, 05:12 AM
Craig's Avatar
Oops,
That's what I meant
Craig,
  #34 (permalink)
Old 04-15-2008, 03:01 AM
nenna69 nenna69 is offline
Junior Member
Send a message via Yahoo to nenna69
Cool 166 sportronic trasmission
Anybody there can tell me how to top up the oil of the 166 sportronic trasmission? Also where can I buy a service manual for the 2001 166> Thankyou.
  #35 (permalink)
Old 04-15-2008, 05:46 AM
Try this ebay listing:
eBay Motors: 1999-2006 Alfa Romeo 166 (item 140141164720 end time Apr-18-08 11:27:32 PDT)
Virginia Beach, VA
  #36 (permalink)
Old 04-15-2008, 05:00 PM
Junior Member
Thankyou Steve.
  #37 (permalink)
Old 05-08-2008, 05:17 PM
Arrowhead Arrowhead is offline
Thanks Alfisto Steve, Linda, and Nat for the valuable information.
Another 164 lives to see another day !!
I had this problem for about five years and finally made the above phone calls.
Nat overnighted the parts and both Stewarts from APC installed the spring with ease.
The transmission shifts flawlessly now, I should have done it years ago.
While generally a lurker, I have upgraded my account to Gold Subscriber to thank those mentioned.
I encourage others to upgrade as well.
Thanks again !!
  #38 (permalink)
Old 05-15-2008, 07:04 PM
drubie drubie is offline
Bruno transmission death
1989 model, 4 speed auto.
I know I should have changed the tranny fluid last year when I got the car (it was starting to turn black) but I was so happy I got it registered I just drove it.
Then, it started making a sharp noise with a clunk when changing up.
Then, one day when it was hot, it forgot how to change out of first but fixed itself.
Then, the other day, it forgot to change out of first until I backed off, then it lost drive altogether until stopped, when it found first again (drove home at 6000rpm which was kinda cool).
I'm not sure where to start - I guess I'll flush the fluid and change the filter first and see what happens - I have a new filter handy. It doesn't seem like it fits the failure modes detailed in this thread though - unless leaking governer seals would cause this problem (fingers crossed).
  #39 (permalink)
Old 05-15-2008, 07:09 PM
Hope all goes well for you but "thou shalt not forgo scheduled maintenance'.
Black fluid not a good sign.
Virginia Beach, VA
  #40 (permalink)
Old 05-15-2008, 07:16 PM
Yeah, I hear you on the black fluid. If I was to take a guess, I'd say one of the clutches is burned out and the clutch material has gummed up a valve somewhere. Might be an opportunity for a 6 speed conversion :-)
  #41 (permalink)
Old 05-18-2008, 11:37 PM
Hmmm.
Drained 3.5l of filthy, black, not very slippery tranny fluid (not burnt smelling though). Poured in some Shell Dexron III on special at your local friendly K-Mart.
Test drive reveals: still busted.
What's my next step? I'm thinking that I will drain the fluid again, pull the filter out of the bottom and pop the top off to have a look at the easily reachable pieces as detailed further up in the thread. However, I think this transmission is stuffed and I'll need to source another one or rebuild it.
The craziest thought that went through my head was to yank the engine, buy a broken GTV6 and build a 3.0l road rocket, but I like this car too much. Anyone got a second hand tranny in oz they want to sell for cheap?
  #42 (permalink)
Old 06-15-2008, 03:14 AM
Junior Member
spring for auto
Enzo,
Did you source the springs in Australia ? If so, from who/where ?
Sorry for the delay. I found the spring at Beninca Motors in Surrey Hill-Melbourne, cost AD $ 30 If you neede more help, please let me know.
  #43 (permalink)
Old 07-15-2008, 07:04 PM
164 tranny info
Bumping up again.
Virginia Beach, VA
  #44 (permalink)
Old 09-07-2008, 07:42 PM
danny164l danny164l is offline
AT Running hot??
Hey guys I changed my tranny oil Saturday because the cooling fan when it came on it didnt turn off and I bypassed the thermo so oil always runs through cooler all the time. It doesnt heat the engine to much at all either so I was wondering that maybe I put the two sensor plugs on wrong sensor and need to switch them. I put the L shaped plug on bottom of thermo where big brass nut is and the straight plug on top. Is this right?? BTW the old fluid was pretty clean you know the normal wear and tear. But not brown or burnt really bad just the normal color of used tranny oil nothing out of the usual. But when I went to clean the filter it was pretty much full of crap looked like dirt or dust it was dark brown the oil itself was pretty clean. The Magnet had no metal shavings nothing just the usual stuff of when you wipe your finger on it your finger gets black. The tranny itself shifts even smoother now that I changed fluid. I changed the fluid back in August of 2006 and added here and there because it has a little leak nothing big though just the usual little drops from old age no puddles though. Tranny runs great I was thinking of getting a bigger cooler for it to cool it down a little more but cant find the right AN fittings with the right NPT I measured the Plumbing Bolts and the O.D. measure is .545 counted the threads and it looks like it 14. I called Nat Wentworth at Erickkson Ind. He couldnt really tell me what the threads were. AAhh yea guys just a heads up Erikkson Ind. DOES NOT SUPPLY the pressure lines that go to the cooler. Its why Im trying to modify the cooler with aftermarket braided lines because the one on my car are old and leaky or always wet. If any of you guys can get that right AN fitting or the the NPT of that tranny thread it will be a big help. Also If I need to switch the sensor plugs please let me know. Thanks
Keep it Lookin Good Pal.
  #45 (permalink)
Old 11-09-2009, 09:55 PM
pazzo22 pazzo22 is offline
I steve is possible install a 5 speed trasmission on a automatic 164s
Thanks Phil
