Old 10-14-2006, 04:10 PM
karlcchen's Avatar
karlcchen karlcchen is offline
Location: The Universes, Commute between 11th Dimension and San Jose, CA, USA
92 164S a/c temperature control plastic shaft broken
I was wondering why temperature control is not working! Any solution?
Karl
Old 10-14-2006, 04:16 PM
karlcchen's Avatar
Now it is broken, I noticed at coldest setting, stepper motor position doesn't push door far enough to coldest setting. I could use a long stick to move the door further. Maybe that's why 164 has weak A/C? Always mixing with warming air?
Karl
Old 10-14-2006, 05:43 PM
Time for winter and manual shutoff valve in supply hose to heater core neat outlet from rear of head for summer weather until you can pull out blower motor.See Bob's (Black Alfa) show and tell for his pictures and our write ups.
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 10-14-2006, 08:23 PM
karlcchen's Avatar
If someone can change the temperature control to manual, same one used on older cars.
Karl
Old 10-15-2006, 12:05 PM
Broken lever was your temperature control.
Virginia Beach, VA
Old 10-15-2006, 01:50 PM
karlcchen's Avatar
I mean have a level inside the car that connect to the temperarure level. so I don't have to climb out of the car when I am driving - not that it can't be done. Image how people would freak out when they see me pop the hood open and climb out of the car to adjust my tempature level with cruise control set...
Karl
Old 10-15-2006, 04:32 PM
You will need to get a cable, vacumn or electrical motor control valve you can install in coolant hose to heater.
Virginia Beach, VA
Old 10-16-2006, 12:21 AM
164TD's Avatar
164TD 164TD is offline
I would recommend not to do so, the initial cooling of your engine(until the thermostat opens) is via the interior heatexchanger.This flow ensures a even temperature rise of the engine.Blocking this flow will in the end get your engine.
Are you sure it isn't just a matter of the circlip that jumped off?
In this case it will only cost you a rainy sunday and it will grow you ego by 200%!
Have a look with a dentist mirror.
Arjen
Old 10-16-2006, 08:28 AM
karlcchen's Avatar
Blocking the coolant flow at rear (to heater core) is a bad idea, not because of cooling though, but of heat distribution. Circulation makes engine heat up evenly before thermostat opens. This also makes heater start working before thermostat opens, but no engine designer is counting on using heater core to cool engine. Drivers have "free will" not to turn on heater (no air passing it) at all. It is OK to by-pass the heater core with another hose as long as circulation is maintained.
I just want a manual control of temperature not AUTOMATIC tempature control with a mind of its own. A cable mechanism will do it. This is an "UPGRADE" to automatic temperature control.
Karl
Old 10-16-2006, 09:18 AM
karlcchen's Avatar
Another thing that is of upmost importance: even though thermostat is not open when engine is cold, coolant flow inside cylinder block maintained thru heater hoses and thru coolant reservoir at that time. Localized coolant inside cylinder block can boiled over in certain hot spot. So do not block the coolant flow ( to heater), it is not just for heater, it is used for coolant circulation too. It is ok to by-pass heater core with another hose.
Karl
Old 10-16-2006, 09:20 AM
Point of information: Small coolant lines enter and exit throttle body from engine rear head to heater hose outlet that goes to heater core and from throttle body go back to coolant tank so small flow always present back to inlet of water pump from coolant tank lower outlet. You can stop water flow to heater core so no big deal. Besides, water circulates throughout engine in a closed loop fashion anyway until thermostat opens.
Virginia Beach, VA
Old 10-16-2006, 09:30 AM
karlcchen's Avatar
That's right. You should see coolant flowing out of small hose into reservoir when engine is running. The samll hose is also the highest point in cooling system, it is used to get rid of trapped air inisde the cooling system too, but not always working ferfectly. I think this kind of design is very typical of european cars of the era, US and Japanese cars are of different design.
Karl
