Old 10-14-2006, 03:44 PM
karlcchen's Avatar
karlcchen karlcchen is offline
Location: The Universes, Commute between 11th Dimension and San Jose, CA, USA
94 Dashboard Wiring Compatibilty
I have run into problems in my 94 164LS wiring transplant:
I have finished dashboard wiring transplant of my 94 164LS from another 94.
My 94 164LS production date is "April 1994" with automatic transmission. I don't know the dashboard wiring I got is automatic transmission or not. Does manual and automatic has different wiring?
I have finished all the connection except a/c. But I think it is good enough for a test of electric connection and intrument panel. After turn on ignition switch, coolant temp gauge swing all the way to ro the right at highest temperature indication with red warning light on. If I press the "Test" button, the coolant temperature gauge swing left and right in high speed five-ten times per second, like a windshield wiper, and not all indicatioin lights are on when tested. Except this, most of lights and auto transmission display works. I haven't try to start it yet.
I have noticed the 94 dash I got looks a little bit different from my 94. For example on top of the dash for defrost, there is no extra openings. Also the defrost ducting pipes are not compatible. But most of electric wirings and connectors looks the same except I noticed a few wires are a little bit thicker now. I want to know if there is an wiring update or an intrument panel during 94 year.
Karl
Old 10-14-2006, 10:21 PM
quadrifoglio's Avatar
quadrifoglio quadrifoglio is offline
Was the donor dash/wiring from a '94 LS (from the U.S.)?
Tim Annett
Cincinnati
'04 Jetta GLS 1.8t
'99 Laverda 750 Sport Carenata
Past Cars in order of appearance:
1965 Sunbeam Alpine IV
1983 Spider Veloce
1985 GTV-6
1987 Spider Quadrifoglio Verde
1986 Spider Veloce
1990 VW Corrado G60
1994 164 Quadrifoglio Verde
2000 BMW 323i
1995 164 Quadrifoglio Verde
Old 10-14-2006, 11:43 PM
karlcchen's Avatar
The doner was from a 94 US 164. I need to ask Alfa Parts Exchage to find out more details. But since there are only two version of 94, LS or Q? Then I think it must be a LS.
I did find in the glove box the name of last own. There is a receipt of AC recharging service with his home address (Salt Lake City, Utah) and home phone. Car model is showing as 1994 Alfa Romeo 164.
I guess the doner must have been totaled, hopefully the owner survivied.
Karl
Old 10-15-2006, 06:28 AM
APE has had a couple of wrecked Q's in their yard for a few years. I can't imagine that many people want to purchase 164 dash boards so I would be that it came from one of these cars. However I was curious if maybe you had purchased it in Europe and the wiring had come from a TS or Turbo or something. I can't for the life of me imagine that the LS and Q are that different. The only discrepancy that I can' think about is that of the Automatic tranny idiot light and the gear selection readout just above the odometer. Both of these only mean anything if one is an auto and one is a stick.
Tim Annett
Cincinnati
'04 Jetta GLS 1.8t
1983 Spider Veloce
1985 GTV-6
1986 Spider Veloce
1990 VW Corrado G60
2000 BMW 323i
Old 10-15-2006, 07:01 AM
Alfissimo Int.'s Avatar
Registered Alfa Addict
Karl
Is temp sender hooked up? Polarity would typically keep the needle to one side, so I am assuming it is not this but could be?
Orange-black/brown are coolant temp wires into cluster from sending unit.
check pin 7 @G151
check pin 4 @G150
Check ground G283
try those for now.
Wiring between 94-95 are fairly the same. If out of a Q there may be some extra wires but the loom should still work.
I am thinking you have a ground problem. You have a resistance problem in this line.
Finish all connections then try again.
BTW, why in the world are you doing this?? Was there a problem with your dash and wiring??
If not, seems like your putting yourself through misery just to update your dash and wiring?
Jason
Jason Minos
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 10-15-2006, 09:41 AM
karlcchen's Avatar
My 164LS wires slowly melted inside dash board and started short-circuiting each other. Because all these wires are tightly pack in a bundle, one burning wire started melting other wires, until ONE FINE DAY smoke coming out of dash board. And I could not turn off the car with horn is on by itself with fuel filling door pop open by itself, all kinds of electric devices is turning on and off all by themselves with ignition switch turn off... I have to disconnect battery fast, fortunately I have battery quick disconnect installed. If it wasn't for that, the car would have caught fire. Maybe that wasn't so bad either, then I will not be doing the rewiring work! Insurance company will take care of the car.
I will have a write up of how and why my 164 wires short circuit themselves in another email. I think I have found how it started long time ago...
Karl
Old 10-15-2006, 10:37 AM
Oh! Also the Q has the electronic struts so it is possible that the wiring harness you recieved had these hook-ups. Could it be possible that some of the connections are incorrect because of these discrepancies?
Tim Annett
Cincinnati
'04 Jetta GLS 1.8t
1983 Spider Veloce
1985 GTV-6
1986 Spider Veloce
1990 VW Corrado G60
2000 BMW 323i
Old 10-15-2006, 01:55 PM
karlcchen's Avatar
After oil and coolant change, I fire the engine up. Then I found voltage gauge that is not working, not moving at all. Alternator is charging though fine.
Karl
Old 10-15-2006, 02:08 PM
Karl,
Could the harness plugs that connect to the gauge cluster be swapped from side to side?
Something is hooked up wrong causing all your symptoms. Do your tachometer and speedometer work? How about the odometer? Guage cluster lights?
Tim Annett
Cincinnati
'04 Jetta GLS 1.8t
1983 Spider Veloce
1985 GTV-6
1986 Spider Veloce
1990 VW Corrado G60
2000 BMW 323i
Old 10-15-2006, 04:59 PM
Originally Posted by quadrifoglio
Karl,
OK, I have had some wires go up in flames too. That just plain sucks!
If looking at the cluster from behind (BTW Q/LS clusters same, just light up different things)
All GREEN harnesses should be on the left side. All WHITE on right.
Coolant is green harness on bottom.
Make sure they are correct.
Ciao!
Jason
Jason Minos
Old 10-15-2006, 07:02 PM
jontg428's Avatar
jontg428 jontg428 is offline
Man after reading this post I am checking the wires under my dash in my 164 pronto!
Old 10-15-2006, 10:15 PM
karlcchen's Avatar
I checked connectors, they are all correctly connected.
I need to borrow someone's working instrument panel to test.
Karl
