Old 10-12-2006, 11:34 PM
karlcchen's Avatar
karlcchen karlcchen is offline
Location: The Universes, Commute between 11th Dimension and San Jose, CA, USA
What's this square button for?
I can't find any connector to connect to this square button under left-hand side of steering column cover. What's it for?
Karl
Old 10-13-2006, 12:14 AM
Richard2 Richard2 is offline
Is this a 12V? it looks like the button for the engine codes.
Richard2
1991 164B Silver Daily Driver
Old 10-13-2006, 03:40 AM
Here is process you use that "Easy Button" for on 91-93 Alfa 164:
http://www.digest.net/alfa/FAQ/164/diag.htm
Here is the process you follow on 94-95 models, but no easy button you use accelerator pedal instead:
http://www.digest.net/alfa/FAQ/164/94motron.htm
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 10-13-2006, 03:47 AM
I notice you have easy button steering column fairing with a 94-95 seat underneath it. Is this fairing off a 94-95 model or 91-93 model?
Virginia Beach, VA
Old 10-13-2006, 04:37 AM
164TD's Avatar
164TD 164TD is offline
In Europe this used to be the button to open the "refuel"panel.
This was used, I think from '87 to '90.Then, with a new interior, and new switches all over the car, this switch moved to the centerconsole.
Arjen
Old 10-13-2006, 06:36 AM
v6junky's Avatar
v6junky v6junky is offline
Arjen
I concur!!
GTV 1.8 TS | Rosso | Zender Milano
164 Zender Alfa Sport V6 24v | QV Mod | Nero
Old 10-13-2006, 08:02 AM
karlcchen's Avatar
It is a 94 164LS.
This is the right side round push button. It does have a two-wire connection. I don't remember what it is for too.
Karl
Old 10-13-2006, 08:18 AM
Alfissimo Int.'s Avatar
Registered Alfa Addict
Originally Posted by karlcchen
It is a 94 164LS.
Karl
key release...this is something you use everytime you turn off the car and get out!!
Jason Minos
http://www.alfissimo.com
Contact@alfissimo.com
Alfaparts@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 10-13-2006, 08:23 AM
Karl
self diagnostic button. Possibly some one replaced it with a 1991-1993 cover.
No wires to it?
Or yes?
Jason Minos
Old 10-13-2006, 10:18 AM
karlcchen's Avatar
Thank you everyone. As said I can't find the wire to the square button. I will probably use it for Rocket Launcher for 008 agent duty or
How about this Italian Air Horn: Freight Train Is Coming...
Karl
Old 10-13-2006, 12:17 PM
Amazing what different versions of this car have had configured to do different things.
Virginia Beach, VA
Old 10-16-2006, 01:53 PM
164TD's Avatar
The square button, when it was still in use:An 1988 Twinspark.
Often the button was hit getting in or out of the car, leaving the fuellid open.
Mostly the reason why they relocated it.
Arjen
