Brake parking lights - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 02-06-2012, 06:57 PM Thread Starter
naubar74's Avatar
Hello
On my dash one day my brake and park light comes on when I brake. I thought that my rear lights didn't work. But they still do. I also found that when i brake the brake and parking light comes on the dash but when I put on the left or right signals the light comes off.
Has anyone had this problem. I have a 1991 164s 5speed in red. I love it.
naubar74 is offline
post #2 of 9 (permalink) Old 02-06-2012, 07:14 PM
zaid's Avatar
Send a message via Skype™ to zaid
your lucky! your indicators work atleast, unlike many others! (excluding me! :P :P
Colombo, Sri Lanka
'95 164 TS 2.0L since 2001
zaid is offline
post #3 of 9 (permalink) Old 02-06-2012, 08:15 PM
Alfisto Steve's Avatar
Originally Posted by naubar74 View Post
Hello
N41 rear lamp control unit bolted to pasenger side footwell light probably or wiring to it.
Virginia Beach, VA
My Maintenance Sticky:
Daily drivers: USA models - 1991 164S Black Beauty II ALFISTO;
Daughter's current ride: BB1 my 164L and Her Granddads 2002 Ford Taurus is back up.
New parts hauler but not car hauler 2004 Jeep Grand Cherokee Overland 4.7L H.O. V-8
Needing TLC non-blackbeast the 93 164L
Alfisto Steve is offline
post #4 of 9 (permalink) Old 02-07-2012, 01:17 PM Thread Starter
naubar74's Avatar
Hi steve
thanks for helping me. I was just wondering wouldn't it be a ground problem?
and what is the unit that you are talking about and what does it do?
can i fix it myself ?
thanks
naubar74 is offline
post #5 of 9 (permalink) Old 02-07-2012, 03:37 PM
Rear lamp control unit is ECU that interconnects turn signals and brake lights which both use same element in the 1157 bulb of which there are two in each rear tailight on NA spec 164 models.
Virginia Beach, VA
post #6 of 9 (permalink) Old 02-07-2012, 05:23 PM Thread Starter
naubar74's Avatar
is there something i can fix myself?
or do i have to replace the unit?
how much does a used on cost?
thanks
naubar74 is offline
post #7 of 9 (permalink) Old 02-08-2012, 01:45 AM
When you say brake and park lamps come on what icons exactly are you saying come on?
The two red icon words BRAKE and PARK?
Virginia Beach, VA
post #8 of 9 (permalink) Old 02-08-2012, 06:47 AM
Classic failure symptoms for this unit. The black box version seems to be better made than the original white box. Some claim to have fixed the unit by re soldering the cracks in the connection paths on the circuit board. It is unlikely to be an external connection failure.
1991 Alfa Romeo 164L 5 spd
Michael Smith is offline
post #9 of 9 (permalink) Old 02-08-2012, 08:20 AM
ChazzyD's Avatar
Re: N44, some have had success resoldering joints on the printed circuit board after opening it up (or replace it altogether if you can find one). Some have found a wire to come loose in the connector at N22, causing lights to not work. And then others have had success, cleaning and checking the function of the relay at the false firewall under the flimsy black cover near the wiper assembly. Investigate all those possibilities, but do check to see if your brake lights are actually working or not, most importantly. Another common fault is a corroded bulb socket/contact if your lights are not working and warning lights are flashing (as they should be in that case).
Charles
-'91 164L 5 speed 229k miles and counting
-'04 Volvo XC70 -'89 Volvo 244 "the Brick" - 2004 Ford Explorer Eddie Bauer 4.6 V8
ChazzyD is offline
