Cruise Control Gremlin - Alfa Romeo Bulletin Board & Forums
Old 03-24-2010, 09:42 AM
The cruise control on my 91B automatic works reasonably well. But when I am in the 60-65 mph area and set the speed, it likes to accelerate another 5 - 8 mph. So if I want to cruise at 65, I need to first slow to about 60 and set the speed. It then adds another 5-8 to that. If I am going 55 - 60 or 65-70 then it only speeds up a couple of mph. It's just that 60 - 65 that gives it big problems.
My previous 91 had this same issue. Is this just part of the 164 experience or is there something to check out?
Randy
91 164L Auto
69 Spyder
Old 03-25-2010, 04:14 AM
gt601's Avatar
Do you just tap the set button? On mine if I set it with a tap it stays where I want it. If I push and hold it too long it will accelerate as you say.
Paul
The meek shall inherit the rear view mirror.
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
79 Alfetta GTV(smooshed and ground up)
Old 03-25-2010, 04:54 AM
Might be the first sign of a speedometer sending unit going bad. I had one do that several years ago. It got so I couldn't use the cruise control at all, then the speedometer stopped working. When I replaced the sending unit everything started orking again.
Richard2
1991 164B Silver Daily Driver
1991 164S Red rebuilt engine
1973 Berlina rebuilding a SPICA engine
1972 Berlina with transplanted 1984 engine. Daily Driver
1991 164S Black now stripped parts, parts and more parts
Old 03-25-2010, 11:07 AM
I tend to push the set button vs a tap. I'll give that a try and see what happens. The sending unit might be an issue as well. I noticed a copuple of weeks ago while cruising down the freeway that the speedmoeter was dropping down into the 40mph range. It quickly recovered and I haven't noticed any problems since, but cetainly something wasn't quite right.
Randy
91 164L Auto
69 Spyder
