Old 10-03-2009, 01:44 PM
Lightbulb how to remove windsheilds
get a can of ...easy-off.... oven cleaner,, spray the edges of the windsheild, let soak in spray some more..this will soften the bond on the windsheild to the body, then wire it off....
don't follow me,i'am lost
Old 10-03-2009, 03:25 PM
ke3ee's Avatar
Robb Senior Member
Send a message via Skype™ to ke3ee
I Doubt it. I watched them install mine and its hard rubber set. He used a hot knife to cut my old one out after destroying the molding.
Projects Fail in the Beginning not in the End
93 164L 5 speed
91 164L auto
Old 10-03-2009, 03:30 PM
i have tryed it at local pick and pull for fun, on a audi 5000(1986)
Old 10-03-2009, 04:03 PM
Alfissimo Int.'s Avatar
Registered Alfa Addict
Audi 5000 and a 164 are totally different. Not that easy to remove. I have tried once with wire and professional window sealant softener and I almost got it but it still cracked. The top is the pain.
Jason Minos
<-GT Bertone, Spider, 75, GTV6, 164, all New models->.
http://www.alfissimo.com Alfa Parts
Tel: +1 480-858-9156
Contact@alfissimo.com
jason@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 10-03-2009, 04:06 PM
how bout removing the car from the windsheild
Old 10-05-2009, 07:13 PM
just tried removing mine with a professional windshield heater that actually heats the sealant and the windshield still cracked! going for my lungs when this car is done.,,
Old 10-06-2009, 08:45 AM
pauliecarzz....going for my lungs???
Old 10-06-2009, 09:41 AM
going for my lungs...lol. meaning ive spent a ton of $ on this car already and who needed to deal with a windshield which is super expensive for these cars.
Old 10-06-2009, 06:23 PM
ChazzyD's Avatar
The windshield is the biggest deal breaker on these cars at this point with trim unavailable and the windshield itself costing so much. A very hard problem to overcome if you have a busted one or even a heavily scratched old one. I'm thinking about polishing mine with an Eastwood kit to shine it back up. It is a very good question, how to salvage one along with its trim? May not be any easy way, unfortunately.
Charles
'91 164L 5 speed 190k miles and counting -'04 Volvo XC70 -'89 Volvo 244 "the Brick"
Chattanooga, TN - Home of the new VW factory!
Old 10-06-2009, 06:31 PM
i remember the trick i was useing to get the windsheild out of that audi.. easyoff oven cleaner,, spray let soak in re spray.. thread a piano wire in start cutting the sealent away.. as i was doing this, i was shoving in popcycle sticks in to prevent the sealend/gasket from re sticking to it self.. lots of popcycle sticks..
Old 10-09-2009, 05:44 PM
Cut away a portion of the gasket in order to get some small diameter nylon rope from exterior to interior and use the rope along the perimeter to unleash the gasket from the interior around the frame by pushing the gasket with a dowel where the rope has breeched. It's a slow process and yes installation is the reverse of removal-of course you don't want to cut your new gasket. It helps to have a friend on the other side as well. Good luck-Ciao.
Old 10-10-2009, 05:16 AM
Gasket?
What gasket? 164 uses a urethane-based adhesive on the windshield, and the glass is said to contribute to the overall strength of the structure. I have watched pros change my 164 windshields 3 times, and they are always surprised by how difficult the process is made by the surrounding metal trim. It would take hours to remove one intact and I doubt any pro would have the patients for it, or be willing to try it again after cracking one in the process. Also beware of the scratches in the windshield frame when they remove the glass as that becomes a great starting point for rust.
