09-25-2009, 10:01 AM
with my son's 164 actually sounds like it's more a rings issue...sounds like some piston slap when cold
Peter
Currently no Alfas in the stable
Previously:
'91 Alfa 75/'95 Alfa 164/'79 Alfa Spider '69 Euro 1750 GTV, '67 Duetto, '84 Spider Veloce
09-25-2009, 12:03 PM
Do you mean hot? This is pretty much "normal" with 164s with over 100-150k on engines.
Oil is cheap compared to engine rebuild or even head redo.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models - 91 164L w/AT "Black Beauty I" ALFA4ME; 91 164S Black Beauty II ALFALFA
In 230,000 mile Rehab MY91 "Bianco" 164B 5-speed [My Originale], ALFISTO
Daughter's current ride: Her Granddads 2002 Ford Taurus
Current Car hauler and Parts chaser : 2000 Dodge Ram PU 5.2L V-8
09-25-2009, 12:28 PM
FWIW, the "other red S" belongs to a guy in my neighborhood. I've not seen the car but I've met the guy and he seems honest. His Spider is very clean and he seems to take good care of it. I would agree that it will take some $$ to get it in shape but I'm guessing it has been well maintained over the years. It just gets to the point where at 145k things start to wear out at an amazing pace. Man I like Red Ss...
If you John, or anyone else would like me to take a look at it just PM me. If it ends up going for under a grand it may well be a decent deal...
Alfa Romeo : 164S:eBay Motors (item 220483001187 end time Sep-26-09 11:07:00 PDT)
09-25-2009, 01:23 PM
I had the heads recently rebuilt on my 130,000 miler and uses about a quart/600mi. That makes me think it isn't all valve seal related.
Randy
91 164L Auto
69 Spyder
09-25-2009, 02:07 PM
no I actually meant cold.....isn't piston slap more common when the engine is cold....and it goes away when the pistons expand due to the heat? I may very well be off, this is my first experience with a V6 Alfa, and with what I was told is piston slap
Peter
Previously:
09-25-2009, 04:30 PM
Could be both hot and cold I guess but "piston slap" I hear on a couple of ours is when engine is hot not cold.
I think bearing ratle more common cold than hot, at least we have one like that until oil pressure builds up after cold start.
Virginia Beach, VA
09-25-2009, 08:48 PM
Location: Rapid City SD, Black Hills of South Dakota, Queens NY
Thanks for the offer. I think that car is a good example of the problems of selling a problem car long-distance on ebay. For me, I'd say that car is about a $2.5 car, if it was decent shape with a serviceable engine and windshield. If I could buy the car locally and do my own work, it'd be more attractive at a $1k price. However, if I have to sink at least $2k in shop repairs to make the car just safe to drive, not to mention the hassle of getting the repairs done in a place far away, plus the pickup/get-home costs, then the value as it sits goes way way down.
John Stewart
74 Spider
91 164S
09-28-2009, 12:29 PM
My oil usage
As far as I can tell, my 92 S burns about 1qt per 250-300 miles, burning a little more in the city than on the highway. The confusing thing is that I have neither fouled plugs nor smoking, except a black puff on startup (never a blue puff). Think it is valve guides or rings?
Jonathan
1992 164S, 1974 GTV
09-28-2009, 12:54 PM
It is what it is but probably intake valve stem seals. If and when you pull chrome intake tubes and inspect under side of intake valve tulips and find wet carbon buildup that is the seal that is leaking.
Blue smoke on start up usually an exhaust valve stem seal leaking I think.
I get that about every 20-25 starts if leaking valve stem seal valve happens to be open valve on shut down is my theory.
I get black puff sometimes on full accel out of on ramp onto interstate at wide open throttle.
Virginia Beach, VA
09-29-2009, 10:24 AM
I suspect that puff of black smoke upon full acceleration would be soot/carbon being blown out of the cat and exhaust system.
Del
Seattle
89 Milano
91 164S
94 164LS (Q)
72 Morgan 27
09-29-2009, 11:56 AM
Yeah, my car was dialed in far too rich when I got it due to a bad O2 sensor, so that is definitely the puff that I am getting. I will need to replace the catalytic converter in the next couple weeks due to the coming of the telltale death rattle. Any ideas on what to use/where to get it?
Jonathan
1992 164S, 1974 GTV
10-01-2009, 08:34 AM
The auction expired on that red 164. Last bid was for $4150. I emailed the seller to ask what his real price is. Emailed back and said he had $17k into the car and wanted in the "high 20s." I know some sellers have some pretty unrealistic expectations, but I think that's pretty delusional. Even the newer LS's on ebay are getting no bids with starting bids of $5-6k.
John Stewart
74 Spider
91 164S
10-01-2009, 08:45 AM
High 20s? VERY delusional
Charles
-'91 164L 5 speed 213k miles and counting  -'04 Volvo XC70 -'89 Volvo 244 "the Brick"
10-01-2009, 09:28 AM
Outright Insane. Unfortunately this is not a Collectors Edition 164. Nor a rare Q with low miles found in a basement garage. Heck Not even a Q4 which can fetch High $20's in the US. high 20's with 94K too my goodness. $4100 for it would have been fine, I think more like $2500
Good luck with that one.
10-01-2009, 10:34 AM
said he had $17k into the car ........
tell him to take his $17K suitcase full of money out of the truck and deduct that amount from his sale price expectation.
Loud pipes save lives.
1973 GTV - bought 3/06, intend to keep forever
1969 GTV, #AR1530021 - sold 10/72, guess didn't intend to keep forever
Current project: '69 Corvette bought in '73, DD '73 - '80, in storage 1989-2002, now apart
