08-24-2009, 05:35 PM
Blown fuses
Ref: 1994 164
We keep blowing the 10 amp fuses for the tail lights. They are number 1 and number 2 in the fuse panel under the steering wheel.
Here's how they are listed in the manual:
Number 1: Right front marker light and left tail light - License plate light - Cigar lighter
Number 2: Left front marker light and right tail light - Marker light indicator - Instrument panel lighting - Vanity mirror light
They usually fail together.
If there is a methodical way to troubleshoot this problem I'd like to know about it.
Any help would be appreciated. Thanks.....
08-28-2009, 02:20 AM
Check the front and rear bulbs for rust/corrosion. You might want to try the lighting control unit under the glove compartment.
LENARD I buy Alfa Romeo cars
http://www.alfabb.com/bb/forums/alfa...omeo-cars.html
Current
Black 88 Celica Alltrac #2
91 164 L auto, 95 164 LS, 91 164 L, 84 Spider Veloce,
92 164 L 19k miles, 93 164 L auto, 91 164 L auto, 94 164 LS auto,
94 164 LS, 91 164 L, and my baby
95 164 Q4 Recaro six speed (see link)
http://www.cardomain.com/ride/2537319
08-28-2009, 08:46 PM
Hopefully there is a logical explanation, such as a crack in a rear light unit and the bulbholder full of water.
If all the lights check out OK, check the illumination of all console items, such as the cigarette lighter. The bulb holder is a little haphazard and I imagine it would be quite easy to have a short circuit there, which is on the same fuse as the tail lights. US cars have four additional side marker lights (I think?) as well as the front and rear lights, so all the more places for possible shorts and water-filled bulbholders.
I think the funniest 'blown fuse' problem I ever solved was a cigarette lighter socket that had been used to store small coins (and was therefore a dead short!)
-Alex
'03 156 TSpark Selespeed, '89 and '92 164 3L V6s (renovation in progress), '88 Uno Turbo SOLD: FIAT Spider and one 164 (the one that worked)...
08-30-2009, 08:09 PM
I've checked all the bulbs and they're fine. I'm beginning to suspect the lighting control unit, but can't find it anywhere, or even ID it. Only marks on it are "A727 558" It has seven pins on the back. Any idea where to buy this? None of the local or specialty auto parts houses has it. Thanks....
08-30-2009, 08:32 PM
I have a good working used one.
Current
09-06-2009, 11:36 AM
I raplaced the lighting control unit (found one locally) and am still blowing fuses. The fuse that immediately fails is the 10 amp fuse in position number 2: Left front marker light and right tail light - Marker light indicator - Instrument panel lighting - Vanity mirror light.
This is driving me crazy. Any ideas?
09-06-2009, 11:45 AM
Vanity mirror wiring maybe? Pull sunvisor or close door on sun visor and see what happens. Just guessing but better to take two asprin before brain surgery is my friend Skip's motto.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models 91 "Bianco" 164B 5-speed - ALFISTO, 91 Argento aka "Quik Silver" (daughter's) 164B w/AT 1QUIK AG
Winter Sleepers: 93 "Rosso" 164L 5-speed; 91 "Old Blue" 164L w/AT
Rescue projects: Newbie 91 164L "Black Beauty"
Organ Donor 91 Old Nero 164L
SOLD 91 Argento 164L w/AT aka "Quik Silver 2"
09-06-2009, 03:09 PM
Somewhere behind the stereo, there is a grey wire that carries the instrument lighting power. Many aftermarket stereos do not use this wire - perhaps it is shorted to ground?
-Alex
09-06-2009, 04:10 PM
-Alex
Now that is a good possibility.
Charles
'91 164L 5 speed 190k miles and counting  -'04 Volvo XC70 -'89 Volvo 244 "the Brick"
Chattanooga, TN - Home of the new VW factory!
09-06-2009, 05:48 PM
Charles
Thanks In my experience, radio wiring (done by some previous owner) is rarely up to any sort of standard. Usually I find cut-off plugs, wires twisted together with tape on, etc. etc. Considering the metal chassis of the radio is stuffed into a tight hole, you can't be too careful.
-Alex
09-06-2009, 10:29 PM
I had an interior light problem on a '63 Volvo (admittedly not even a Volvo 164) caused by a pinched hot wire at the light fixture. Intermittent short to ground. Quite akin to the illumination wiring behind radio suggestion above. Good luck finding it. You could probably disconnect the power leads going to the various lights and see which power feed is Doing The Deed.
Michael
09-11-2009, 09:36 AM
Found the problem. Passenger side visor wire was shorting. Don't need the visor light, so we just disconnected the wires at the local connector and taped up the end. That way we can put a new light/harness in later if we choose.
Thanks to all who helped/made suggestions.
09-11-2009, 09:49 AM
Glad you found my prediction in item 7 above to be the trouble and thanks for reporting you findings.
Many folks ask for help and then never let us know if they ever found the problem or fixed the car.
Thanks again for reporting back to us.
Virginia Beach, VA
09-12-2009, 06:27 PM
Thanks, Steve. You were spot on....
Because of my lack of knowledge of this car I may never make a decent contribution to this forum. The least I can do is update you on what we find.
