06-06-2009, 04:37 PM
Speedo malfunction, dead trans
Well as luck would have it the speedo signal disappeared after I had lunch with Robin today. Of course, 2nd gear only as a result (Automatic). No provision to override Alfa's safety program and manually select a more appropriate gear to drive to the service center??? Must I tow this car once again rather than drive 20 miles in 2nd gear?? It seems that the senders have gone the way of the Dodo bird and vanished from the face of the planet. Strange thing is, I just bought a used one to help out an Alfista in the UK who said he couldn't find one there. Sorry Gerry, I may need to use it myself. No previous symptoms, no moisture involved, crawled under the car and verified the sender is still plugged in, unplugged and replugged, tapped side of sender, no change.
Ian
94 LS
06-06-2009, 05:25 PM
War on string is winnable
ian sounds strange
yes if the speedo sensor signal is lost the ecu for the trans will default to safe mode
I dont think that the issue is a bad speedo senser per se, I suspect wiring or mechanical issue with the sensor-- its a chopper assembly, a little wheel goes around and provides a square wave signal. They are relatively bulletproof in my experience
Check the wiring at the connector and again at the ECU =-=
where are you located??
bob
goats
74 GTV with 10548's and Ingram pump --speedo been around at least twice -- needs new oil rings!
1995 LS Q runners Auto Green/tan 216K 100% LCD
1995 LS 5 speed Green /tan 45K Q runners squadra chip 100 % LCD!
Misc parts laying around for 24V and 2Liter!
2004 Tacoma 4 door TRD (wifes car/kid hauler)- 156K
Mission Vsi, Mission Mod 2, - 20+ years of hockey on these!
radio flyer- rusty from disuse!
06-06-2009, 05:49 PM
Fullerton. There was no warning, no indicators. This happened once before when I drove over a carwash that does the underside. Things were OK after drying out, 2 months ago. Then this sudden failure after parking the car and going in for lunch.
06-06-2009, 06:42 PM
If it helps at all in diagnosis, I have no indicator for "ice sport or auto" when I push the switch.
06-06-2009, 08:40 PM
yeah thats normal I think
The current state is a result of the induced fault-- ie , what we need to solveis the speedo sensor signal === Do you have a service manual? Are you comfortable getting deep into this (will be mech trim and electrical, nothing close tolerance / oily)
If you are handy with "stuff" - and have a manual== you can disconnect the sensor from the harness, and find the other side of the harness- by (admittedly faulty) memory it goes to the Motronic ECU under/behind the radio/AC console -- ring this out with a VOM == after, of course, checking the wire that the speedo sensor plugs into (ie visually examine the connector, trace the wire as far as you can, etc).
One other item that MIGHT be a possibility- if you have any heater core leakage it tends to get the Auto Trans ECU with moisture. Again, removing the pass side tunnel shield and getting in there will probably be needed unless you find it on the sender side===
goats
06-06-2009, 08:57 PM
Thanks, guess it's time to buy batteries for the cheap DVOM in my toolbox.
Ian
06-06-2009, 09:39 PM
you can reset maybe??
by disco the battery for a few minutes and see if you can clear the 'safe mode' latch
goats
06-06-2009, 10:19 PM
Goats, I am certainly going to owe you that bottle of vino. Shifting came back, seems to me speedo is reading low, but I'll verify by driving by a local "your speed is" sign.
Mille Grazie
Ian
06-07-2009, 05:36 AM
I have repaired a speedo sender once by cutting open, digging out some resin, and replacing two small electrolytic capacitors. It was a textbook repair case - a check with a handheld oscilloscope showed a strangely-modified square wave (sloping tops to the pulses, amplitude only 0.7 volts), after replacing those capacitors I had a proper square wave with 5 volts amplitude. I have photos somewhere at home but not here with me at the moment.
-Alex
'03 Stilo Abarth Selespeed, '02 Spider V6, '88 Uno Turbo
06-07-2009, 10:36 AM
I'd be interested in seeing the photos if you find them.
Ian
06-07-2009, 12:44 PM
Any joy from hard reset was short-lived. Drove approx 5 miles with everything apparently normal, loud bang from drivetrain and back to no speedometer and 2nd gear only.
Ian
06-07-2009, 12:57 PM
I figured that
The hard reset idea is only to get you to where you can work on it. I would go under the car, and carefully check the wires, connector, etc as completely as you can. You might want to pull the sender but be careful you don;t lose the little gear down insider the transmission=== Steve can tell you how to do it I can;t, never had it out!
I still think the problem is in the wiring not the sender per se
goats
06-07-2009, 06:07 PM
Ian
This does not sound good did speedo drop off to zero and then tranny dowshift to second gear and put your chest on steering wheel? How fast were you going jest before it happened.
Normal default to second gear if you lose signal from sender to speedo and tranny ECU.
Maybe wiring but senders do fail. Myron's 95LS gave him a fit until I found out sender was going bad. Installed new one and never had a problem with tranny since.
Alfa Parts in Berkely list one for 164 A/T tranny as 7624313 another Alfa number for same A/T sender is 60800459. It is different than 5-speed models. Somebody just did a buy it now for one on ebay that I was hoping to buy it for my 91L as sender is intermittent but price was to high. At least on 91 speedo error does not down shift tranny like 24v one does.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models - 91 164L w/AT "Black Beauty I" ALFA4ME; 91 164S Black Beauty II ALFALFA
In 230,000 mile Rehab MY91 "Bianco" 164B 5-speed [My Originale], ALFISTO
Daughter's current ride: Her Granddads 2002 Ford Taurus
Current Car hauler and Parts chaser : 2000 Dodge Ram PU 5.2L V-8
06-07-2009, 06:21 PM
That's what I experienced, but fortunately I was not driving more than about 25-30 at the time. I am the "buy it now" guy, as I have heard these units are no longer available. Yes, the price was high. I wonder why International pulled the listing? Price was still high, but at least available as recently as 2 years ago. I don't put too much stock in Italian component numbering, and am sincerely hoping that this sender is correct. I mean, how complicated could it be? For all intents and purposes it appears to thread on to what is essentially a speedometer cable connection, complete with square cable style socket. Saab uses the 4HP18E trans too, but the sender looks significantly different (#4083804) No idea if it would work, and priced comparably but at least available.
Ian
06-07-2009, 06:49 PM
You bought correct 60800459 sender
Ian
I got ebayer to tell me what real part number on the box was not that 363xxxx number he listed on auction. Hope it fixs your problem my loss your gain if it does.
You need a 26 or 27mm crowsfoot to change sender on A/T model. I bought a 1" (25.4mm) one from Sears and filed it out enough to fit 27mm nut.
As for speedo sender driveshaft/slug in differential case on A/T it is not easily dropped itto tranny like it is on 5-speed as there isn't any set screw you can remove. AT one has a spring clip to hold slug and gear shaft in place.
On 5 speed model's sender nut is 22mm aka 7/8" and as long as you don't remove set screw in differential case not problem changing it either.
Virginia Beach, VA
