06-10-2010, 05:34 PM
Some cooling fan testing info for 164
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models - 91 164L w/AT "Black Beauty I" ALFA4ME; 91 164S Black Beauty II ALFALFA
In 230,000 mile Rehab MY91 "Bianco" 164B 5-speed [My Originale], ALFISTO
Daughter's current ride: Her Granddads 2002 Ford Taurus
Current Car hauler and Parts chaser : 2000 Dodge Ram PU 5.2L V-8
06-22-2010, 06:11 PM
Some Alfa 164 cooling fan motor bearing and repair info
Virginia Beach, VA
06-22-2010, 06:13 PM
Serpentine belt idllers bearings info for 24v Alfa 164
http://www.alfabb.com/bb/forums/164-...lfa-164-a.html
Virginia Beach, VA
06-22-2010, 07:00 PM
Alfa 164 Tech Bulletin 40.93.01 Wiring Diagram Corrections - 164S Suspension
Looks like file is to big to load will try to parse.
Virginia Beach, VA
06-28-2010, 05:05 AM
How to pull codes from 164 engine ECU
http://www.alfabb.com/bb/forums/164-...tml#post895656
How to check Alfa 164 Engine ECU for codes
91-93 12v V6 procedure: Alfa 164 Motronic Self-Diagnosis http://www.digest.net/alfa/FAQ/164/diag.htm
94-95 24v V6 procedure: Alfa 164 Motronic M1.7 Self-Diagnosis http://www.digest.net/alfa/FAQ/164/94motron.htm
Virginia Beach, VA
08-12-2010, 02:40 AM
Unsafe find on a installed 164 Master Cylinder
Virginia Beach, VA
08-15-2010, 03:18 PM
I have been reading the links Alfisto Steve has posted for Timing belt replacemnt on 2.5 Alfas, it is very helpfull Thank you. One question for you; in Rick's Cam timing pdf template, it states to use 8"x14" paper at 100% scale setting for printing. All I can locate is legal sizec 8.5" x 14" is than the size he is refering to? I am trying to get this
right the first time.
Thank you for the help.
08-15-2010, 03:22 PM
I guess I made a typo so 8.5 x 14 or two 8.5 x 11 pieces taped together.
Virginia Beach, VA
08-18-2010, 10:10 AM
Looking for break light wire diagram for 164LS.
08-18-2010, 10:26 AM
See page 462 1994 wiring manual. It is a fold out page so pretty hard for me to copy. If you own a 164 you need to get a CarDisc International Ltd. - Alfa Romeo Manuals, Giulietta Manuals, Giulia Manuals, GTV Manuals, Spider Manuals, American Austin & American Bantam DVD if you don't have two volume 900 pages each shop and electrical manuals. If you have a 95 DVD has those manuals, too and much more.
What is your problem no brake lights and if A/T can't get out of park unless you push manual overide? If so cut out little rectangle shunt box in B/L switch wiring at switch and splice wires together and see if you now get brake lights.
Virginia Beach, VA
08-20-2010, 07:58 AM
Alfa 164 V6 exhaust gasket part numbers
Alfa 164 V6 exhaust gasket part numbers going from engine heads to back of car:
60506636 ex manifold to head stamped copper or steel gasket 164 12v V6 (6 ea)
60573536 ex manifold to head square double layered steel gasket 24v (6 ea)
60510306 ex pipe to manifold thin metal layer sandwich style with insulation center gasket 164B/L/S 12v (2 each)
60654239 gasket ex pipe to manifold 164LS/Q 24v (2 each)
60510307 two pipe copper cat inlet copper gasket 164B/L
60805010 or 60571802 two pipe cat inlet gasket 164S One number one piece gasket and other one is two separate gaskets I think.
60573540 front cat inlet gasket 164LS/Q 24v (2 each)
60510816 3-bolt hole rear cat outlet gasket 164B/L (usually copper but maybe composite with flame ring).
82473321 R/H cat outlet copper gasket 164S
82420455 L/H cat outlet steel sealing ring 164S
82407147 sealing steel ring rear muffler to center muffler 164 all and 24v rear cat outlet (1 ea 12v and 2 ea 24v).
Here is thread that started all of this: http://www.alfabb.com/bb/forums/164-...st-gasket.html
Virginia Beach, VA
08-25-2010, 11:13 AM
I added remote starter wire to my Alfa 164 today.
I added remote starter wire to my Black Beauty today. I unwrapped BLACK TAPE off the engine wiring harness on the engine side of the false firewall.
It is the harness with rubber ring that pushes into round hole in false firewall.
There are two black wires in harness and the pin 1 in G151 connector power wire to starter solenoid pin 50 is the larger of the two black wires It is the 2.5mm (AWG 12) wire. I used a Tyco AMP splice tap yellow connector for 12-10 size wire to add a 12 AWG wire pigtail. I can now hook my push button remote start cables to this pigtail and power side of 40A cooling fan fuse bar terminal board.
I will be able to do compression test, etc without having to go in the cockpit and turning on the key and turning key to start position.
This remote start feature also will bepass chassis wiring to starter is something fails besides starter.
Virginia Beach, VA
08-25-2010, 01:09 PM
1991- 93 Alfa 164L and 164S USA ABS Bosch system components
1991- 93 Alfa 164L and 164S USA ABS Bosch system components:
Takes Torx 15 screw driver tip to remove pump cover and harness hold down screws
ECU 0 265 100 051
ABS Harness Alfa 90557 953.04.04.90
ABS Pump 0 265 201 016 with two relays Blue 0 332 204 153 and black 0 332 002 174
Chassis relay 10A 0 332 512 009 and chassis free fuse holder 10A both located to right of glove box under dash panel under a/c outlet near door.
R/R sensor/cable 0265001073
L/R sensor/cable 0265001074
R/F sensor/cable 0265001251
L/R sensor cable 0265001250
Virginia Beach, VA
08-25-2010, 01:12 PM
ABS sensor cables
Virginia Beach, VA
08-29-2010, 11:21 PM
Info on using Marelli tester on Alfa 164 electronic suspension system and 24v models
Info on using marelli tester on Alfa 164 electronic suspension system for 164S/Q and general info on using the tester for other systems mostly on the 94-95 24v models:
http://www.alfabb.com/bb/forums/164-...4s-1991-a.html
Virginia Beach, VA
