11-16-2008, 01:11 PM
Head gasket leaking coolant!!
Today I started up my 93L and noticed the low coolant warning light ON, so I opened up the hood and looked into the coolant tank and it was almost empty. I topped it off with coolant and I noticed fumes coming from front head gasket region and noticed coolant slowly weeping out from from head gasket area.
Should I retorque the heads and see if it disappears?? or do I need to replace the ehad gasket??
thanks,
-Pavan
1995 Alfa Romeo 164Q (136k)/5spd - Mr.Hottie  1993 Alfa Romeo 164L (156k+)/5spd - Mr.Dependable  1992 Subaru SVX (81k)/4EAT - [B]#0211[/B] - 4.44 Final Drive - My Baby
11-16-2008, 01:32 PM
thanks,
-Pavan
I say no brainer front head easy to get to head ganuts so retorque and hope for joy.
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models 91 "Bianco" 164B 5-speed - ALFISTO, 91 Argento aka "Quik Silver" (daughter's) 164B w/AT 1QUIK AG
Winter Sleepers: 93 "Rosso" 164L 5-speed; 91 "Old Blue" 164L w/AT
Rescue projects: Newbie 91 164L "Black Beauty"
Organ Donor 91 Old Nero 164L
SOLD 91 Argento 164L w/AT aka "Quik Silver 2"
11-16-2008, 01:54 PM
thanks Steve, is it just opening the front valve cover and retorqueing the head?
-Pavan
11-16-2008, 01:55 PM
-Pavan
YES it is.
Virginia Beach, VA
11-16-2008, 03:09 PM
Be sure you have your manual with you as you will have to follow the order to re torque the heads, you simply cannot just tighten them down in any random order. All the heads I have done on cars use a cross hatch style torque pattern.
11-16-2008, 03:45 PM
Sure will follow the manual... thanks-
11-16-2008, 05:18 PM
Pavan make sure it is not leaking from somewhere else like from one of the hoses and down the head.
LENARD I buy Alfa Romeo cars
http://www.alfabb.com/bb/forums/alfa...omeo-cars.html
Current
Black 88 Celica Alltrac #2
91 164 L auto, 95 164 LS, 91 164 L, 84 Spider Veloce,
92 164 L 19k miles, 93 164 L auto, 91 164 L auto, 94 164 LS auto,
94 164 LS, 91 164 L, and my baby
95 164 Q4 Recaro six speed (see link)
http://www.cardomain.com/ride/2537319
12-13-2008, 02:54 PM
Ok, I drained all the coolant and oil and retorqued the head and refilled oil and coolant and now the engine doesnt start, it just keep turning, but doesnt start. I am hoping it to get up and running this week, but seems like it wont..
Seems like some coolant went in... wht should I do now  ...
thanks,
-Pavan
12-13-2008, 03:13 PM
Did you possibly get the firing order messed up? Is everything you took off hooked back up?
Go through all you did in a calm manner. It's easy to miss something silly when you are in a slight panic. Where did it seem coolant went?
Paul
The meek shall inherit the rear view mirror.
Alfas owned/own!
81 GTV-6
83 GTV-6
86 GTV-6
87 Milano Gold
88 Milano Verde
91 164S
77 Alfetta sedan
79 Alfetta GTV(smooshed and ground up)
12-13-2008, 03:21 PM
Has the coolant level dropped? I'd pull the plugs and look down the plug holes for coolant. Turn it over by hand with a wrench on the front pulley nut. Set it at the timing mark and using the template check the timing to be sure. How do the plugs look? Rotor and Distributor cap? Also, check the bosch connector on the temp sensor. Sometimes also the coil wire at the coil corrodes.
Richard2
1991 164B Silver Daily Driver
12-13-2008, 03:37 PM
Hmm... these is a lot of gummy or greasy substance on the inside of coolant reservoir. The only thing I unplugged are the spark plug connectors and I plugged them back in. Thts it. Havent checked inside plugs...
-Pavan.
12-13-2008, 03:42 PM
Hello Pavan make sure you did not mix up any of the spark plug wires. Also make sure the AFM is plugged in as well as the Motronic temp sensor on the thermostat housing that is hidden by the upper radiator hose.
Current
12-14-2008, 10:56 AM
Here are some pics inside plugs
doesnt look good to me...
Any suggestions..
thanks,
-Pavan
12-14-2008, 11:02 AM
Looks like you need to replace the plug wheel seals, but not a reason for the no start.
Charles
'91 164L 5 speed 190k miles and counting  -'04 Volvo XC70 -'89 Volvo 244 "the Brick"
Chattanooga, TN - Home of the new VW factory!
12-14-2008, 11:46 AM
are you talking about the seals between head and valve cover?? That brown stuff doesnt look like oil, more like watery stuff.... does this mean some coolant seeped into the head??
-Pavan.
