squeekee-squeekee, driving me batty! - Alfa Romeo Bulletin Board & Forums
Old 05-11-2005, 07:03 PM
modena782002's Avatar
Angry squeekee-squeekee, driving me batty!
I love my 164S!! However, what ruins a thoroughly wonderful driving experience is an annoying squeek that is driving me crazy. 1st gear, Let the clutch out (squeek) beautiful noise to 6000rpm, depress clutch (squeek) into second gear-let out clutch (squeek) back up to beautiful noise, depress clutch (squeek) and so-on. The noise is coming from the clutch pedal spring. Cold weather, warm weather, damp, dry, it does not matter. I have lubed the spring and bushing area above the spring with everything from WD-40, white lithium, regular grease, liquid wrench, and good old 3 in 1 oil. Nothing seems to have any effect on it. As I depress the clutch pedal, with my fingers on the spring, I can feel a vibration on the spring itself, so I don't think that it's the bushing. This has been an ongoing problem that I have lived with for two years now. Would replacing the spring be effective? Are springs even available? Has anyone else had this problem? Thanks for any help.
Nick D'Eri
1968 Fiat Dino Spider 2.0
2003 Saab 9-3 Linear
2004 Ford Mustang V-6 5-speed (daughters car)
2008 Piaggio Fly 50
1977 Peugeot 103 Moped
Former Italians:
1992 164S 2002 - 2008
1981 Spider Veloce 2001 - 2003
1974 Fiat 124 Spider 1979 - 1981
Dad's Former Italians:
1962 Giulietta Spider 1964 - 1969
1969 Berlina 1750 1970 - 1971
Old 05-11-2005, 09:02 PM
Alfissimo Int.'s Avatar
Clutch slave cylinder is going bad. Very simple to replace.
$70 for the part.
It sits on top of the transmission bell housing.
Jason
Jason Minos
<-GT Bertone, Spider, 75, GTV6, 164, all New models->.
http://www.alfissimo.com Alfa Parts
Tel:+1 928-526-0549
Contact@alfissimo.com
jason@alfissimo.com
<1991' 164 QV, White- Recaro>
Old 05-11-2005, 09:44 PM
BlackAlfa's Avatar
Bought my LS last March from the South. It came with sqeaky pedals and a very hard accelerator pedal (I had to almost stand on it to make it went faster ). Stopped along the way at Alfisto Steve's place to do a quick check on things when coming back. Steve sprayed some lube into the cable and that freed it up quite a bit. But the cable has rust inside and it had not been smooth even though I lubed it a few more times later. I eventually changed that cable.
I also suffered from the sqeaky clutch (brake too I think) pedal for many months. Just like what you did, I have tried silicone spray, WD-40, ... But, the sqeak always came back.
The squeaks are gone now and the pedal feel is great ! I have done a few things. I was also suffering from clutch pedal not coming back up. To make the story short, I have changed the clutch slave and the clutch master before the clutch pedal works properly. For the squeak, I have taken all the pedals out, cleaned and re-lubed the pivot area. From what I remember, there's actually some small bearings in there for the clutch pedal. I cleaned and re-greased them. I think the noise was mostly gone after I did that.
Bob
Old 05-11-2005, 10:50 PM
elite38868's Avatar
Send a message via AIM to elite38868
Mine does the same thing and my pedal is harder to push than my neighbor's 91' 164S. Still the slave cylinder?
Also, how hard is it to replace the slave cylinder? Has anyone described the process on the bb?
69' 1750 GTV - XC70 Q4
Old 05-12-2005, 08:16 AM
BlackAlfa's Avatar
IMO, it could be any component along the hydraulic system. Dirt or corrosion on the master and slave cylinders wall that increase friction with the piston seal. The clutch line damper (has that been removed yet?). Old and restrictive rubber clutch hose. Dirty fluid ... Or, it could be the clutch throwout bearing area.
I would start with the pedal pivot linkage to make sure that's well lube. If you still have problem, then start looking into and replacing hydraulic components.
The slave cylinder is quite easy to change. But a little tricky to bleed it. Best to use power bleeding method.
Changing the master cylinder is a little bit more work. I did a quickie reply on "how I did it" in the 164 forum, you might want to do a search there.
Bob
Old 05-12-2005, 06:55 PM
Thanks for all the input. I really don't think that it's the hydraulics though. The squeek is definitely from the spring/bushing area. In fact, the squeek has a spring sound to it--almost like the spring on a screen door, when stretched too far, but a few octaves lower. I have toyed with the idea of disassembling the clutch pedal, and checking the bushings. Aside from the tight quarters under the dash, how difficult is it to take the clutch pedal out, Bob?
Nick D'Eri
2008 Piaggio Fly 50
Former Italians:
Old 05-12-2005, 07:08 PM
Alfisto Steve's Avatar
Probably bearings 10 are dry:
Virginia Beach, VA
s.patchin@aroc-usa.org
http://www.aroc-usa.org/
Daily drivers: USA models - 91 164L w/AT "Black Beauty I" ALFA4ME; 91 164S Black Beauty II ALFALFA
In 230,000 mile Rehab MY91 "Bianco" 164B 5-speed [My Originale], ALFISTO
Daughter's current ride: Her Granddads 2002 Ford Taurus
Current Car hauler and Parts chaser : 2000 Dodge Ram PU 5.2L V-8
Old 05-12-2005, 08:12 PM
BlackAlfa's Avatar
Yes, bearings 10 are probably either dry, rusted or not rotating. WD-40 is the wrong type of lubricant for them.
Aside from tight quarters, I don't recall any significant problem in taking the clutch pedal out. The only tricky part was in putting pin 6 back. There's just no room to hold that pin and get your hand up there. The trick I finally used was to use a long (several feet long) sewing thread. I threaded it through the hole in pin 6 at one end and used a cotter pin (like a needle) at the other. It was much easier to thread the cotter pin through the assembly (master cylinder fork and pedal) holes. Then I pulled the thread to get pin 6 up to position and use my hand to help it to get in place.
Here's the link to my write-up on changing the master cylinder:
http://www.digest.net/alfa/FAQ/164/f...mID2/3670.html
Bob
Old 05-12-2005, 11:11 PM
Yup, slave cylinder. I am telling you! I sprayed so much lube on that spring to make the noise go away. Then I replaced the Master and slave and no more noise.
jason
PS I still have the old spring on there.
Jason Minos
Tel:+1 928-526-0549
jason@alfissimo.com
Old 09-04-2005, 07:30 PM
elite38868's Avatar
It's most likely your Clutch Master Cylinder. I just did mine and that was the culprit. It's not the bushings in most cases.
Old 09-04-2005, 07:59 PM
mine was the bushing.
1992 164L (sorry i had 91' stated earlier, typo)
Old 09-04-2005, 08:24 PM
elite38868's Avatar
As i said, in MOST cases, it isn't the bushing...
Old 09-05-2005, 06:46 AM
I'm still living with it...doesn't seem to be as bad in warm weather.
Nick D'Eri
2008 Piaggio Fly 50
Former Italians:
  #14 (permalink)
Old 09-05-2005, 11:01 AM
Send a message via ICQ to alphalvr
mine did the same wd40 on the clutch pedal where the arm goes through the rubber bush/bung sorted it for me.
Alfa 164 cloverleaf 12v
Full engine balance @ benalfa
Heads done @ john wilcox competition engines
Autodelta cams
Full 4x3" exit stainless, no cat, no mid box
Poly bushes
Green cotton filter
6 speed box (from gtv)
Highpower systems nitrous injection
  #15 (permalink)
Old 09-05-2005, 11:50 AM
if you did that not too long ago, i would buy silicone spray and spray that instead of wd40
